Old 12-24-2011, 12:29 AM   #1
Barneyhyphen
My Ride: 2004 M3 Convertible
Bump in hood right above the power steering resevoir?
1999 323i stick. JUST had a new hood etc fitted, following a small accident.
Old hood had a fairly good sized (1/4" tall, 3/4" dia) "bump" (reverse dent) in the surface of the hood, exactly in line with the cap of the power steering fluid resevoir,
Padding on the underside of the hood is also damaged in the same place, as well as right above the top of the oil dipstick AND the round fingerpull/handle of the dipstick is also cracked.
Before replacing the hood, we had "thought" the bump had been caused by someone leaving a spanner (wrench), socket, screwdriver or the like, on top of the resevoir, after working on the engine, and shutting the hood down on it.
BUT, the same dent has now appeared, withing 6 weeks of the new hood being fitted!!!!!
Could this be a bad/broken driver's side engine mount? Allowing the engine to lift on the driver's side when under load?
We observed the engine last night, when revved but stationary but the engine appeared to "lift" only perhaps 1/8", not nearly enough to do the damage.
Maybe under load the "lift" would be greater?
Apply hand brake, foot heavily on the foot brake, hood open, stand AWAY from the front of the car and have "helper" drop the clutch whilst observing the engine "lift"?
Any input &/or thoughts would be most appreciated. Thanks.
BH
Barneyhyphen is offline   Reply With Quote
Old 12-24-2011, 12:47 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
I am more thinking the guy dropped the hood down with the rubber stopper removed.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-24-2011, 01:32 AM   #3
Barneyhyphen
On the old hood and the new hood? possible I suppose.
What would you suggest broke the dip stick finger pull? Just seems too coincidental to me? These two pieces appear to be the highest two parts of the engine immediately under the hood.
BH
Old 12-24-2011, 02:47 AM   #4
jasonbimmer
BH
no way one could break the dipstick pull because the airbox is higher.
the dipstick can be hard to remove he might pulled too hard?
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-24-2011, 05:47 AM   #5
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
the engine could be jumping around on bumps too.
Cant you see the condition of the engine mounts? With a 99 you might want to just change themm anyways though. How many miles?
Drew@Swift Motorworks is offline   Reply With Quote
Old 09-10-2012, 10:45 AM   #6
Barneyhyphen
Sorry for 8 month delay in responding!!
It WAS the mounts. Would never have thunk it but there it is. All now resolved.
Might be a piece of info worth posting somewhere permanent, for anyone else discovering seemingly unexplainable bumps in the hood?
Thanks all the input.
BH
