Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 04-01-2014, 02:56 PM   #1981
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by CNels View Post
I will be watching this closely.I ordered a copy also,but not being a 'computer guy', I am hoping it is a user friendly software
It's not really.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-01-2014, 05:12 PM   #1982
Mr330iM
My Ride: 2002 330i M
I have the red cog of death and it was due to a voltage issue the Indy shop reset it a while ago nd it went away for months now it's back I have pa soft how do I go about resetting it ?
Mr330iM is offline   Reply With Quote
Old 04-01-2014, 05:42 PM   #1983
NoGuru
My Ride: 2002 330ci, 335is Le
Double click on the DME or whatever codes you get after the scan.
Click the errors box and it will tell you what the errors are.
Then click clear errors and it should be gone.
Take a note of what errors you get so you can possible resolve them.
NoGuru is offline   Reply With Quote
Old 04-01-2014, 05:43 PM   #1984
Mr330iM
TClick image for larger version
These are the errors I get ... Nothing in dme
Old 04-02-2014, 10:17 AM   #1985
Dazza335iC
My Ride: '02 330Ci, '92 345iC
I'm having the same problem, my DME is listed as "not found".
Here's my scanner, looks much different than the one in the original post:
Do pins 7 & 8 still need to be soldered, even on this new config?
Dazza335iC is offline   Reply With Quote
Old 04-02-2014, 11:09 AM   #1986
NoGuru
Do you have the key turned to position 2?
Or just start the car and run the scan, it would have to pick up the DME.
Old 04-02-2014, 11:52 AM   #1987
Dazza335iC
See my post on the previous page with screenshots, but yes the car was running and 80% of the modules were "not found".
Old 04-02-2014, 12:13 PM   #1988
NoGuru
Originally Posted by Dazza335iC View Post
I just got my 1.4.0 scanner yesterday. I hooked it up, and got this.
Why won't it read 90% of the modules? I know my car has a DME (duh), so why won't this thing recognize that it's there? Does the key need to be in a specific position to read certain modules? (I did it with the engine running). It's a 5/02 build date 330ci which, IIRC, means I don't have the 20-pin round connector under the hood. How do I get this to read the rest of the modules? Do I need to solder the 2 pins on the scanner, as is shown here? http://forums.bimmerforums.com/forum...de-car-options
I can't see the pics because I am at work, but you have an 02 330CI same as me.
All I had to do it assign the drivers to read the software, which it looks like you have already done, it should work.
Only thing I can think of is what driver did you assign it, serial to USB?
Old 04-02-2014, 12:16 PM   #1989
WDE46
I would say that pins 7 and 8 should be soldered. Where did you buy your scanner?
Your scanner should be showing EGS and DME, but most of the other ones may not be present. PDC for example, you probably don't have so it will not appear. I have none on the third page also.
Old 04-02-2014, 03:03 PM   #1990
Dazza335iC
resettools.com, I used the link in post#1 of this thread.
I soldered pins 7 and 8 together, I'll try it again when I get home tonight!
Old 04-02-2014, 03:05 PM   #1991
Dazza335iC
Also, how do you do things like change the window functions (roll up/down with the key), change the security system to flash the red light, etc? I can't find any of the tick-box style screens I've seen posted by other's in screeenshots. Does anyone have a manual, or a link to a good post, where it explains the menu structure and available options?
Old 04-02-2014, 04:12 PM   #1992
NoGuru
Click on ZKE, Coding Data, and recoding, this will show what you can set.
Old 04-02-2014, 05:01 PM   #1993
WDE46
Most everyone here buys from xcar360.com. That could explain the differences.
Old 04-02-2014, 08:44 PM   #1994
gr9120
My Ride: E46 330i
For my case, when the DME is "missing", it was a simple case of the plug not sitting properly in the connector. Just re-seat the plug and the DME and EGS shows.
Hope this helps.
gr9120 is offline   Reply With Quote
Old 04-07-2014, 09:17 AM   #1995
Dazza335iC
I'm unable to clear several codes from both the DME and ABS modules, even though I've replaced the faulty parts. They're stored as 'ghost' codes but won't go away :/
Old 04-09-2014, 02:55 PM   #1996
Linx
My Ride: '02 BMW 325iT
Hi everyone. I was following this thread way back when it was about 7 or so pages long. I see it's grown into a monster. Being that I really don't have the time to go through and TRY to remember where I left off and try to catch up, I'm hoping someone can help me. I had installed the software on my laptop running Windows 7 (64). Everything was working fine but last night I got my SES light and ofcourse my laptop took took a **** on me. Turns out the processor is bad and so looking for a new laptop. I've seen a few laptops I like but they're only running Windows 8. Has anyone successfully installed and used this software on Windows 8? Any info would be greatly appreciated as I need to pick up a new laptop no later then tomorrow. Thanks.
Linx is offline   Reply With Quote
Old 04-09-2014, 03:49 PM   #1997
eneka
My Ride: 2003 325i
Works great on my laptop with 64bit windows 8.1. There's a guide some where on how to get the correct drivers installed
eneka is offline   Reply With Quote
Old 04-10-2014, 12:08 AM   #1998
turbotalon1g
My Ride: '02 330i
Great thread here, I have my romanian diagnostic cable for sale with software. INPA, Progman, all that stuff. I think $30 paypal and shipped is fair, if not make an offer.
turbotalon1g is offline   Reply With Quote
Old 04-15-2014, 09:05 PM   #1999
Oldboy
My Ride: E46 M3
This guide: http://forum.e46fanatics.com/showthr...windows+64+bit is what I used to get PA Soft up & running on my Windows8 64bit. I was written for windows 7, but it worked for me. And, doesn't the Romanian software require a keycode?
Oldboy is offline   Reply With Quote
Old 04-18-2014, 01:43 PM   #2000
Strykr24
My Ride: 2000 328Ci
Exactly the info I was looking for. My ultrabook has 8.1 (with virtual box) so I was worried that it wouldn't work. Thought about running XP on the VB but everythign I've read said it wouldn't work.
Strykr24 is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
