Rating:
#201 |
Which version of windows 7 do you have? If its professional or better, download something called "windows xp mode" and run everything in there
#202 |
only home premium
#203 |
#204 |
So I uninstalled everything. drivers, scanner program everything. reinstalled it all and evrything seems to be doing fine. I wont be able to try it out till I get home this afternoon. Should I have the cable pluged into the computer b4 I open up the scanner software or plug it into the car first.
plug into car turn key to "on" plug into computer start scanner software thats how I think i will do it. edit as needed |
#205 | |
I download what ever I would need to get it to work on xp or 2000 Like I said i got it all reinstalled right now so Im going to try it out later when I get home then go over to my buddys place. If it doesnt work I take what I downloaded and load it on to there and then reinstall it again. |
#206 |
I'm not sure as I'm still waiting for my cable, but your cable may only be capable of reading the ECU and not the other systems (alarm, ABS, etc). I believe these other systems are on a CAN bus and ECS Tuning is saying this cable can not read that.
Can anyone verify this? |
#207 | |
CAN-bus only does the DME, Transmission(AGS), ABS, and the DSC. Although; it seems I should be able to get into my K-bus so its not a total loss. It seems i will have to get the package from xcar for the CAN-bus but I atleast want to give it a try. Last edited by lakedude90; 02-23-2012 at 12:12 PM. |
#208 |
PA Soft 1.4/BMW Scanner Guide Part 1 & 2
Ok, i finally found a how to guide on some of the features. I hope this helps for some basic features that everyone is looking for. Not sure who this guy is but props for doing this video.
Part 1 ![]() Part 2 Last edited by djray; 02-23-2012 at 04:37 PM. |
#209 |
The Brake Newbie!
Great Find
#210 |
so far at lunch time today went home and i was able to setup the following; need to reseach some more on some other features.
Lighting coding **Double flash - hazards only ZKE3 coding **Automatic locking - 2min after unlocking w/o opening (i dont even want this now that i think about it) ZKE3 coding **Locking condition - i set it for 12km/h (and it didnt work) Need to look into the settings again. ZKE3 coding **Convenient opening/locking |
#211 |
Ordered this the other day...thanks for finding the tutorial!
#212 |
looks like there are different verisons on this software. I'll take a screenshot later on mine, but i remember that it had a 1.4 something with 2009 up on the blue bar up top on the window.
#213 |
Does any know what the following functions are that i underlined?
ZKE3 coding *2 min after unlocking w/o opening ( i figured this one out) ![]() *after starting (lock) its sounds right, but to just be sure - does this mean once i start the car the doors will lock? *after starting (key 1) *after starting (key 2) *after starting (key 3) *after starting (key 4) Selective central locking *Mechanical lock *Remote control, key 1 *Remote control, key 2 *Remote control, key 3 *Remote control, key 4 |
#214 |
would this software be able to do corner light delete?
#215 |
No, but you can do the DRL
#216 |
I dont have DRL.
#217 |
can we make this a sticky thread?
#218 |
Here you go. I forgot i email myself the log from this afternoon.
BMW Scanner v1.4.0.7 (14.01.2009) - P.A.Soft, 2008 HW: V144Bn9 Time: 12:18:41 PM 2/23/2012 |
#219 |
# ERRORS IN UNITS
--------------------------------------------------------------------------------------------------------------------------- Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY --------------------------------------------------------------------------------------------------------------------------- DME -> 7.511.570 19 53 1 error / 6 errors EGS -> 7.514.265 2H 12 no errors EWS -> 6.905.670 03 08 no errors ABS* -> 6.750.364 04 0.0.0 5 errors LEW -> 6.750.126 04 03 no errors A/C -> 6.914.009 24 06 2 errors SRS -> 6.912.123 10 30 no errors IKE -> 6.910.264 10 21 2 errors LCM -> 6.907.951 10 20 2 errors / 4 errors ZKE -> 6.907.663 11 16 no errors / no errors MFL -> 0.000.000 01 09 no data RAD -> 6.909.882 32 11 no errors SZM -> 6.914.733 02 03 no errors / no errors SHD -> 6.910.471 05 27 no errors SPMFT -> 6.913.364 02 02 no errors / 1 error SPMBT -> 6.913.364 02 02 no errors / 1 error SMF -> 8.263.135 07 0B no errors # ERRORS DETAILS - DTC(hex)/PARAM(hex) --------------------------------------------------------------------------------------------------------------------------- DME -> E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich Shadow-memory: - E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich - 5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative - 5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative - 5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative - 5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative - 34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit ABS* -> 5DA0/C0 - Wheel speed sensor front right electrical faulty. - 5E43/C0 - Steering angle sensor internal. - 5DA3/C0 - Wheel speed sensor front right start recognition v_comparison. - 5D93/C0 - Wheel speed sensor front left start recognition v_comparison. - 5DF4/40 - Vehicle power < 9 Volt. A/C -> 1C/44 - AUC sensor - 1E/42 - AUC heating IKE -> 11/44 - Thermal oil-level sensor - D7/81 - Tank sensor 2 LCM -> 16/01 - Turn lights switch / wire, short circuit to ground 17/01 - High beam / headlight flasher switch, short circuit to ground Shadow-memory: - 33/01 - Sidelight, front right - 38/01 - Sidelight, front left - 3C/01 - Licence plate light - 3E/01 - Rear fog light faulty SPMFT -> Shadow-memory: - 02/02 - Low voltage mirror-heating SPMBT -> Shadow-memory: - 02/02 - Low voltage mirror-heating # SCAN END Last edited by djray; 02-23-2012 at 07:18 PM. |
#220 |
now this is the after i cleared the errors.
# ERRORS IN UNITS --------------------------------------------------------------------------------------------------------------------------- Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY --------------------------------------------------------------------------------------------------------------------------- DME -> 7.511.570 19 53 no errors / 4 errors EGS -> 7.514.265 2H 12 no errors EWS -> 6.905.670 03 08 no errors ABS* -> 6.750.364 04 0.0.0 5 errors LEW -> 6.750.126 04 03 no errors A/C -> 6.914.009 24 06 2 errors SRS -> 6.912.123 10 30 no errors IKE -> 6.910.264 10 21 1 error LCM -> 6.907.951 10 20 no errors / 3 errors ZKE -> 6.907.663 11 16 no errors / no errors MFL -> 0.000.000 01 09 no data RAD -> 6.909.882 32 11 no errors SZM -> 6.914.733 02 03 no errors / no errors SHD -> 6.910.471 05 27 no errors SPMFT -> 6.913.364 02 02 no errors / 1 error SPMBT -> 6.913.364 02 02 no errors / 1 error SMF -> 8.263.135 07 0B no errors # ERRORS DETAILS - DTC(hex)/PARAM(hex) --------------------------------------------------------------------------------------------------------------------------- DME -> Shadow-memory: 5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative 5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative 5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative 5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative ABS* -> 5DA0/C0 - Wheel speed sensor front right electrical faulty. 5E43/C0 - Steering angle sensor internal. 5DA3/C0 - Wheel speed sensor front right start recognition v_comparison. 5D93/C0 - Wheel speed sensor front left start recognition v_comparison. 5DF4/40 - Vehicle power < 9 Volt. A/C -> - 1C/44 - AUC sensor - 1E/42 - AUC heating IKE -> - 11/44 - Thermal oil-level sensor LCM -> Shadow-memory: - 33/01 - Sidelight, front right - 38/01 - Sidelight, front left - 3E/01 - Rear fog light faulty SPMFT -> Shadow-memory: - 02/02 - Low voltage mirror-heating SPMBT -> Shadow-memory: - 02/02 - Low voltage mirror-heating # SCAN END |
| Tags |
| bmw scanner, diagnostic tool, error message, pa soft |
| Rate This Thread | |
