Thread Tools Search this Thread Rating: Thread Rating: 434 votes, 4.97 average.
Old 02-23-2012, 08:31 PM   #221
zbi701
My Ride: E46 318i
Originally Posted by lakedude90 View Post
I do see that.........now
CAN-bus only does the DME, Transmission(AGS), ABS, and the DSC.
Although; it seems I should be able to get into my K-bus so its not a total loss. It seems i will have to get the package from xcar for the CAN-bus but I atleast want to give it a try.
It is not advisable to try something on CAN-bus unless you are absolutely sure what you are doing.
zbi701 is offline   Reply With Quote
Old 02-23-2012, 08:54 PM   #222
lakedude90
My Ride: 03' 325i
well the only thing I would really wanna do is re-program my DME since I had an O2 sensor code pop up and have herd sometimes its just the DME.
But either way the cable didnt work so I just might send it back and and buy the stuff from Xcar. Idk yet
lakedude90 is offline   Reply With Quote
Old 02-23-2012, 09:46 PM   #223
e46hektor
My Ride: 2000 323i
that link was a year ago, im sure they made the scanner already bridged, or with no need to bridge it no more, I got mines like 4 months ago , installed the program on a windows 7 starter notebook! with no problems at all, i dont see why it doesnt work for some of yall, mines was installed with no modifications and on the first try., yours looks like its just a plug and play device, if its not the obdII connnector then try the round connector and it should be fine.
alright so I cracked open my cable. When to this link http://forums.bimmerforums.com/forum....php?t=1726627 to see what should be together.
This looks nothing like my cable.....
This is my cable
top with cover
back of of it
so there you have it
I also found this link http://forums.bimmerforums.com/forum....php?t=1622061
This guy has it running on 2 win7 64bit os so Im gonna uninstall and go by those instructions and see hat happen WML
e46hektor is offline   Reply With Quote
Old 02-24-2012, 01:10 AM   #224
TerraPhantm
My Ride: M3 & ZHP
PASoft isn't capable of that. Get an Ediabas interface and use winkfp to flash a euro tune to your car. That'll delete the O2 errors.
Old 02-24-2012, 08:27 AM   #225
lakedude90
My Ride: 03' 325i
Well its not that I want to reflash to a Euro tune. Im know for a fact I dont have enough info on it. I have just read that the DME is very sensitive and that even though a SES light comes on and its saying something about ur O2 sensors, that it may not bee them and that you DME may just need a newer program. But I havent had any problems lately so Im just going to send the ECS cable back and I orderd the Xcar package last night so Ill wait for that to come in. plug it up and see if Ill have to open it up to combine some pins. Was hoping to be able to mess around with it this weekend hey owells.
Thanks for all the help guys I really apprecaite it. hopefully the new stuff wont give me this much hassle lol
Old 02-24-2012, 04:45 PM   #226
djray
djray's Avatar
My Ride: 01 BMW325CI
So went back at it last night as i still can't get my door locks to lock automatically when i drive away. Does anyone using this software know what "Terminal R" means under;
ZKE3 Coding
- Automatic locking
* Locking condition
# Terminal R
# 4km/h
# etc...
djray is offline   Reply With Quote
Old 02-24-2012, 05:39 PM   #227
djray
djray's Avatar
Here's some more useful info on this program. Thanks to BMWcoders.com
Old 02-24-2012, 05:50 PM   #228
trj
My Ride: 325Ci
OP, I am getting the same DME errors on the O2 sensors and ABS wheel sensors.
I checked the 30amp fuse int he e-fusebox for the O2 sensors. The fuses are fine, but those shadow errors are still there. You might want to check the fuse there to eliminate the blown fuse probability.
Please update if you find any solutions to it.
Mine works with the auto lock on 14km/hr(if I remember correctly)
Try setting it a little higher than 4km/hr
Old 02-24-2012, 06:01 PM   #229
djray
djray's Avatar
do you have a factory alarm installed? I just got one a few months ago and then my auto lock went away?
Im just trying to see if there is anything that i maybe not checking off that needs to be checked off under the "Automatic locking".
Right now i have it set to
"Automatic locking"
- After starting (lock)
Locking condition
- 8km/h
But nothing is happening.
Old 02-24-2012, 06:05 PM   #230
trj
My Ride: 325Ci
No I do not have factory alarm installed, but I coded my car for the factory alarm to get the clown nose blink and the lock/unlock blinks.
I know if I add a siren or a piezo buzzer, it will make noise just haven't done it yet.
Since you say that the lock feature went away after installing the alarm, it might be creating an issue.
Try disabling the alarm remote/key all and set the auto lock after certain speed only and see if it works.
You will narrow down the issue and then we can see further.
Old 02-24-2012, 06:19 PM   #231
djray
djray's Avatar
True, i just dont want to disable the alarm and it not work again. I need to find the screen that had an alarm code? If there is one there, do i need that to reactivate? I saw the screen somewhere while just going thru the program.
I guess i'll findout this weekend but thats a good idea.
Can anyone chime in and lets us know if you have a factory alarm and your auto locks work as well?
Old 02-24-2012, 07:31 PM   #232
Guest021715
Account closed.
Below are my settings for the alarm, notice the 24km/h selection for auto locks. That is the only option that worked.
There are a tonne of posts about PA Soft.
Old 02-24-2012, 07:54 PM   #233
jfoj
My Ride: 330CiC, M5, X5
In order to get auto door locks working, you need to have the Keys enabled under Automatic Locking I believe??
As for Terminal R, I am just guessing, but I would assume this means Reverse detection??
Any yes, I have a factory alarm in multiple cars and Auto Lock works when configured properly. Also you can get Auto Locking without the Alarm installed or enabled.
Old 02-24-2012, 08:13 PM   #234
djray
djray's Avatar
Ah! Thanks!
But why does yours say ZKE5 and the one i have is ZKE3?
Also, you have under "Automatic Locking" you have all (5) checked? Is that for the key memory function?
Again, tomorrow i will get into this alot deeper with screen shots to compare so we and everyone that has this can come with a easier DIY with this program and its features.
Old 02-24-2012, 08:55 PM   #235
Guest021715
Account closed.
Originally Posted by djray View Post
Ah! Thanks!
I have all 5 checked because that's what works for me. I only have two keys, however each set could be considered anything from 1-4 depending on how this program reads it.
You are probably using a different algorithm than me, which is why you have different options listed. I should consider myself lucky because it seems my car uses one which has most, if not all, of the features.
Just look at the top right screen of each module's menu (DME, IKE, etc.). It'll show you what algorithm is used.
Old 02-25-2012, 02:37 AM   #236
zbi701
My Ride: E46 318i
Dude, your adapter is not compatible with Pasoft. There is no FTD chip in it. You need to get the adapter specifically for Pasoft BMW Scanner 1.4. Pasoft require special interpreter chip in the adapter to communicate with the car modules.
Old 02-25-2012, 10:28 AM   #237
I M Legend
My Ride: M3
can this activate the triple flash?
I M Legend is offline   Reply With Quote
Old 02-25-2012, 10:49 AM   #238
mojako
My Ride: bmw
I hate Xcar360. They took my payment knowing that they don't have the cable available.
Now that I've been demanding for refund, it's taking them ages to reply.
mojako is offline   Reply With Quote
Old 02-25-2012, 12:07 PM   #239
DougL3NC
My Ride: 2000 323Ci
I'm in the same boat. I paid through Paypal, so I guess I'm going to dispute it.
Sent from my N860 using Bimmer App
DougL3NC is offline   Reply With Quote
Old 02-25-2012, 12:51 PM   #240
TerraPhantm
My Ride: M3 & ZHP
Question
PASoft cannot update modules period though. Procedure is the same for flashing US and Euro tunes
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
