Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 03-21-2012, 09:41 PM   #401
Guest021715
Account closed.
Originally Posted by Blind_Shooter View Post
i know this thread is a few days old but, i ordered my pa soft scanner 1.4.0 and got it running on windows 7 but it doesnt read anything but the DME and EGS says fail on IKE and EWS. anyone else have this problem from xcar360? is this bc i need to solder the 7 and 8 pins. was under the impression i didnt need to on the new ones
Your 2000 323i requires the 20-pin round adapter to have access to the other modules.
Old 03-21-2012, 10:34 PM   #402
jfoj
My Ride: 330CiC, M5, X5, E93
http://www.amazon.com/OBD-OBD2-Conne...2387259&sr=8-1
Old 03-22-2012, 07:48 AM   #403
CoClimber
My Ride: 87 325is, 04 330XI
Yeah, when I got my cable, I also ordered the round adapter. Looked all over my engine compartment trying to find the connector only to realize that my 2004 didn't have one. At least I can use it to talk to my S50 engine in my E30.
Still haven't recalibrated my steering angle sensor. I downloaded INPA but haven't had a chance to install it. Does anyone know if the PASoft cable will work with INPA? If it won't, I'll just have my indy shop reset the sensor for $45.
CoClimber is offline   Reply With Quote
Old 03-22-2012, 07:59 AM   #404
Guest021715
Account closed.
It won't. 2 different interfaces.
Old 03-22-2012, 08:12 AM   #405
lakedude90
My Ride: 03' 325i
alrighty so I have loved being able to check things myself but now I have a few question.
In the light coding whats the diffrence between cold/hot check and whats "BC message"?
What is the Xenon with HVAC down on the bottom
and is there anything on pages 2/3 that we can go into? When ever I run a scan I just seem to stop it after page 1 cause alot of the stuff on 2,3 it cant seem to get into.
lakedude90 is offline   Reply With Quote
Old 03-22-2012, 08:13 AM   #406
lakedude90
My Ride: 03' 325i
Originally Posted by Hollywood516 View Post
I have one for sale... I am running windows 7.. doesn't work and i don't know all that much to go thru the trouble of trying to set up xp as backup O.S or whatever.
Did you ever sell it because if not I finally got mine to work and Im running win 7 64bit if you still need some help
Old 03-22-2012, 08:15 AM   #407
CoClimber
This is disappointing. I'm wondering about the real value of this cable. Glad I didn't buy it from PASoft. That would be way too much money to make my lights flash when I set the alarm.
I did find it funny that the car throws an error if the gas and brake are pressed at the same time. Doesn't BMW know about heel-toe shifting?
Old 03-22-2012, 08:27 AM   #408
Kayoige
My Ride: 2000 323I
Im going to need your help soon. Mine should be here in a couple weeks.
Kayoige is offline   Reply With Quote
Old 03-22-2012, 08:30 AM   #409
Guest021715
Account closed.
It doesn't
Old 03-22-2012, 08:34 AM   #410
lakedude90
My Ride: 03' 325i
http://forums.bimmerforums.com/forum....php?t=1622061
I used this and it worked very well. there were a few diffrent minor diffrent things. Although you might have to use a diffrent usb serial convert option. If your first choice doesent work and the usb port become inactive all you should need to do is conect to the internet and roll back the driver and it should like normal again.
Old 03-22-2012, 03:48 PM   #411
fcychan
My Ride: BMW E46 M3 Vert
Do I need that 20 pin cable?
I just ordered the from Scanner 1.4 from xcar360.com. Do I also need to order the 20 pin round cable for a 2003 E46 M3 Convertible? Thanks for helping out an E46 newbie/E90veteran
fcychan is offline   Reply With Quote
Old 03-22-2012, 03:54 PM   #412
CoClimber
If you have the 20 pin diagnostic port under the hood, I would think you would need the 20 pin round cable. I'm not near my Bentley to look it up. My 2004 330XI did not need the 20 pin cable.
Old 03-22-2012, 04:20 PM   #413
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Nope!
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-22-2012, 05:24 PM   #414
jfoj
fcychan,
You should have considered this -
http://www.xcar360.com/bmw-dash-scanner-3-in-1.html
Or this which has INPA as part of the package -
http://www.xcar360.com/bmw-diagnostic-interface.html
INPA and the PA Soft/Dash Scanner is a pretty good overall mix of what most folks really need.
Old 03-22-2012, 09:03 PM   #415
drivesacrj
My Ride: 2000 323i
Yaay!!! Got mine today from China, installed with no problem on Vista 32 bit, I was coding stuff within minutes!! Got my OBC stalk working, coded my newer LCM and removed the tamper dot, coded double hazard flashers...I was like a 6 year old with a new toy! Couldn't delete the corners though, I think I need a newer LCM (the one I have now is from an 03).
Overall, for thirty-something bucks I think its a really good deal.
Quick question: what exactly are "side lights". Are front side lights the corners or the side blinkers? And what are rear side lights?
drivesacrj is offline   Reply With Quote
Old 03-22-2012, 09:07 PM   #416
Guest021715
Account closed.
fcychan,
That's probably a good solution in you don't want too much hassle with the $36 (now $40+?) kit from the Romanian seller. It would make for an easier install.
But at $185, I'd say the few hairs I've pulled out trying to make the cheaper kit work properly were worth it.
Old 03-23-2012, 08:11 AM   #417
fcychan
Thanks for all that info!
I really appreciate all that info... all great stuff
fcychan,
Old 03-23-2012, 10:59 AM   #418
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Just got my kit and it came with fresh software on a CD and my PA Soft Scanner had a build date of 10.21.2011 and the 1+2 and 7+8 pins were soldered and jointed to allow the extra re-coding of the convenience features. Which I had lots of fun with.
I only paid $36 for my kit on March 8th, 2012 and it arrived March 19th 2012 shipped from TAIPEI, TAIWAN to BROOKLYN NY 11236.
Already Soldered at 1+2 and 7+8 to allow for fun a.k.a convenience options re-coding!
Fresh Software!
delmarco is offline   Reply With Quote
Old 03-23-2012, 11:06 AM   #419
jfoj
Delmarco,
You dog, I have tracked a number of orders and they all go via New York before they work they way out the rest of the US, so this is why you probably got yours a bit quicker? The rest of us may take as long as 2 weeks?
Did you update your software from the PA Soft website or is what you are showing what came on the disc?
I have not checked lately but what you show is the most recent as I recall?
Old 03-23-2012, 11:10 AM   #420
jbeurotech
Regional Sponsor
US the software from the site Last time I talked to the developer he is working on software that will kill the clones when hooked up to software from his site. That would be funny IMHO!!!
Seth Thorson
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
