Thread Tools Search this Thread Rating: Thread Rating: 435 votes, 4.97 average.
Old 03-24-2012, 02:57 PM   #441
MadLow
My Ride: 2004 330CI
hey delmarco...i was only able to get the window displayed on your screenshot for the light coding...how am i able to code my hazard lights to double flash in that window?
i dont see the option for warning lights blink 2 times
Originally Posted by delmarco View Post
funny you should say this!
Firstly to answer you: It will work and has worked especially in cases where folks retro'd RCR tails on to a prefacelift tails and got the mid bit to lite up a brake or running lamps.
Now the fun stuff...I saw the coding on the PA Soft allows the option for the tail lamps to be modified to do various things.
MadLow is offline   Reply With Quote
Old 03-24-2012, 03:20 PM   #442
Guest021715
Account closed.
If you don't see the option for the double impulse hazards.like I posted in my screenshot, then your car can't do it. Its because your LCM uses a different programming algorithm
Sent from my LG-P999
Old 03-24-2012, 05:06 PM   #443
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Been looking all weekend but can't seem to find on my PA Soft:
1. How do you code the fog lamps to stay on with the high beams-on and high beams-flash?
2. How do you code the HVAC unit? for Auto-On mode. Mine is already set to auto-on but I want to know how to code it off or on.
delmarco is offline   Reply With Quote
Old 03-25-2012, 02:21 AM   #444
Guest021715
Account closed.
Can't do either of those with PA Soft.
Also, do you have a link to any information regarding the piggyback wiring for rear fogs? I'd like that to be my next project.
Old 03-25-2012, 02:43 AM   #445
delmarco
Don't really remember the link but I know people either just do it via the RCR Depo kits which come prewired to light up the fog lamp as a brake lamp or they run one wire thru the trunk lid to the passenger side tail lamp power-on wire for the brake.
Old 03-25-2012, 06:14 AM   #446
jmejiaa
My Ride: 2002 M3
It was easy for me. I paid $36 for my kit on March 8th, 2012 and it arrived March 19th 2012 shipped from TAIPEI, TAIWAN to BROOKLYN NY 11236.
Where I bought my kit.
I used Google Search and picked the $36 seller.
yeah I got drama on the LCM. My pass. side reverse tail lamp bulb is out and both the front turn signal sockets are shorting because of water damage.
Also having an euro LKM faceplate from a non-xenon car on the usa LCM module-body that originally came on my xenon car and having dual fog lamps on a USA spec car generates like 4 other errors. They seem to clear and return when the LCM is used but no issues are observed.
This thread is awesome, I've had people want up to $150 to code my car. In the past, with my VW cars people would help out and do this stuff free..
Anyway, I ordered one so now I might be able to help out other members too!
Delmarco, thanks for posting this.. It's one of those sites I probably would have never ordered from.
jmejiaa is offline   Reply With Quote
Old 03-25-2012, 09:53 AM   #447
alpine003
My Ride: BMW
After some trial error, I was able to get it working on 64 bit windows 7 home edition.
Just ordered led bulbs without resistors(except turns) as I could just turn off the bulb check functions now. LEDs should outlast the car so don't really need to worry about checking it.
Also found out my dealer purposely shut off the DWA alarm interior sensor and tilt sensor to falsely fix an issue I was having before related to the doors failing to unlock sometimes when parked at a grade.
In addition to "recode" option, I see "reprogramming". Has anyone done anything yet with this option?
alpine003 is offline   Reply With Quote
Old 03-25-2012, 02:44 PM   #448
Guest021715
Account closed.
I have RCR depo tails. How are they prewired for the rear fogs, you mean they have the bulb socket already drilled through?
Old 03-25-2012, 03:45 PM   #449
delmarco
yeah...I had a thread a few years ago about it....
I forgot how it worked but this picture below should give you an idea:
Old 03-25-2012, 03:50 PM   #450
Fajitas
My Ride: 04 E46
Can you please explain how you got it to work with windows 7 64?
Fajitas is offline   Reply With Quote
Old 03-27-2012, 04:16 PM   #451
alpine003
My Ride: BMW
http://forums.bimmerforums.com/forum....php?t=1622061
I had to do somethings a bit different from this set of instructions.
You need to download the correct drivers regardless to begin with from the link.
However, within the control panels > system > device manager
I opened up the "other devices" section which reveals "BMW Scanner" with a ? next to it since it can't find a suitable driver. You'll want to right click and update this driver manually. Specify that it's a USB Controller and then manually load the driver from where you saved the updated drivers by pointing to it. IIRC, the filename you'll want to select is ipdBus.inf or something like that.
After that you should be set.
Old 03-27-2012, 04:23 PM   #452
Fajitas
My Ride: 04 E46
Awesome, thank you very much!
Old 03-30-2012, 11:52 PM   #453
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
Can this let you adjust your passenger mirror while in reverse so that it doesn't tilt all the way down?
JetBlackE46 is offline   Reply With Quote
Old 03-30-2012, 11:56 PM   #454
ccagle
My Ride: 02' 325i
You don't need it to do that... Just move your mirror selector to drivers side and it won't move anymore. No software needed
ccagle is offline   Reply With Quote
Old 03-30-2012, 11:58 PM   #455
JetBlackE46
Modded
Thanks but I want to adjust how much it tilts, not stop it from tilting completely when I put it in reverse.
Old 03-31-2012, 12:02 AM   #456
ccagle
My Ride: 02' 325i
Ahhh ok. Sorry I misunderstood. I don't recall 100% but I'm pretty sure I haven't seen the option in mine.
Old 03-31-2012, 12:34 PM   #457
delmarco
You can. I just did this yesterday. I wanted to see the curb better and have it tilt lower.
I turned off the tilt by sliding the control switch to the passenger mirror and made the mirror as low as possible then slide the control switch to the drivers mirror (which turned back on the tilt function). Put the car back into reverse and the mirror was tilted lower.
Old 03-31-2012, 03:42 PM   #458
MMMGP
My Ride: 325iT, 1997 M3 Sedan
I finally got my PAsoft from X360car.com. I installed it on an old netbook with XP that I had laying around and went out to the car to program. I have a 9/04 build touring (NAV & PDC) and I too did not have the option to double flash parking lights. Maybe this came on 330is only?
MMMGP is offline   Reply With Quote
Old 03-31-2012, 03:46 PM   #459
Guest021715
Account closed.
Has to do with the production year. My 2001 325 has the option.
Old 03-31-2012, 03:57 PM   #460
MMMGP
What algorithm is your LKM using?
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
