*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread - Page 29 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 05-17-2012, 12:34 AM   #561
slocar
My Ride: 323ci
Tried to code auto lock today without success. I can only select the option to lock after starting with each of the keys and to lock automatically if not open in 2 min .. The speed sensitive locking conditions are all grayed out and i cant select anythig. Any words of advice? Its a zke5 if that helps any.
slocar is offline   Reply With Quote
Old 05-17-2012, 12:50 AM   #562
Guest021715
Account closed.
The only speed option that seems to enable auto locks is 24km/h.
Old 05-17-2012, 12:48 PM   #563
slocar
My Ride: 323ci
I kinda got that from reading this thread, but the issue I have is that even the 24 km/h option is grayed out and not selectable. Is there something else I need to enable before I get to it or is my ZKE just like that?
Old 05-17-2012, 01:05 PM   #564
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
It depends on the software version on your ZKE which options can be changed as the tool (scanner software) is not complete for all module software versions... and not all software/hardware versions have the capability for all features. You might be able to flash your ZKE with winfpk or maybe it will be supported in a future version of the scanner software.
Basically from what I understand you are modifying the module's non-volitile memory with PA soft, kind of like using hex editor to patch a compiled windows executable. All of this has been done through reverse engineering, so not all of everything is complete, and that is why the real software is frequently updated and costs $$$. The creators have had to do reverse engineering on multiple module versions.
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 05-17-2012, 01:26 PM   #565
Guest021715
Account closed.
Post an actual screenshot of your options. Don't censor anything on the image except your vin if you must.
Old 05-17-2012, 01:35 PM   #566
TRIPLE_O
My Ride: E46 Coupe
slocar, are you using the full version and not the demo version?
Also which pin port are you connecting to the car with?
________________________________________
BMW Coding, PM Me For Details
3 Series Owners Manuals
http://www.bmwsections.com/docs/3series/
For Sale (Exterior Lights)
_________________________________________
Originally Posted by gonzaga707 View Post
My boyfriend left on vacation and left me his 95 328i for me to use while he is gone. He had 2 keys, I lost both of them this week...
..sincerely Jenny
TRIPLE_O is offline   Reply With Quote
Old 05-17-2012, 02:33 PM   #567
MadLow
My Ride: 2004 330CI
can anyone tell me under the light coding section what the hot check, cold check and BC messages functions do ?
Thank you.
MadLow is offline   Reply With Quote
Old 05-17-2012, 04:41 PM   #568
hanna
My Ride: BMW 328i
Can you monitor auto transmission temperature with PA Soft scanner?
hanna is offline   Reply With Quote
Old 05-17-2012, 11:19 PM   #569
slocar
My Ride: 323ci
20 pin underhood connector as the car is a 2000 and wont connect using the OBD2 connector; using the full version. I'll try to post the screenshot in the morning.
Thanks for all the help so far guys.
Old 05-18-2012, 02:13 AM   #570
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
Think im gonna go with AC_2007 suggestion and then report back. Is there a seperate thread on that unit btw?
Originally Posted by ac_2007 View Post
Could also get this http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem
Has INPA, DIS, NCS Expert, SSS/Progman. Pretty much every programming option for this car, including ECU flashing.
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 05-18-2012, 08:02 AM   #571
slocar
My Ride: 323ci
Alright guys, here's what I'm working with as far az ZKE goes:
Old 05-18-2012, 10:52 AM   #572
Guest021715
Account closed.
Ignore the red outlines, check all the same boxes for Automatic Locking and see if it enables the Locking Condition radio buttons:
Old 05-18-2012, 11:08 AM   #573
slocar
My Ride: 323ci
I've tried and it doesn't enable those buttons; unless I have to check all those, re-code, then get back in and maybe they'll enable ... though I don't see why that would be the case.
Old 05-20-2012, 07:54 PM   #574
Marinerd
My Ride: 04 xiT, 09 328i
Just bought this. Can't wait to get started. A lot of programming I wanna do.
Marinerd is offline   Reply With Quote
Old 05-20-2012, 09:00 PM   #575
e46hellrot
My Ride: e46
ordered mine 3 weeks ago. still dont have it
e46hellrot is offline   Reply With Quote
Old 05-20-2012, 10:02 PM   #576
steve.k
My Ride: 05' 325Ci, 13' WRX
Doors Auto Locking
Hi guys,
i ordered my scanner the other week and it just arrived. got it working no dramas.
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
I managed to get the indicators to blink upon lock/unlock and i also disabled the rear windows from opening upon holding the unlock button on my key.
I would like some help with three things;
1) My airbag light keeps coming on/off when someone is sitting in the passenger seat.. ive read the codes and this is what came up:
Does this mean i need to replace something? is it a big job or can i DIY?
2) How do i get the car to auto lock? Now i know that E46's have this option, but i tried to enable it by pressing '2 min after unlocking w/o opening' and i also enabled Locking Condition - '24 km/h' as someone posted it will only work at that speed..? Both of these boxes were ticked but nothing happened so i put it back to 'Terminal R'. This is what it looks like right now:
3) Upon lock/unlock i would like my low beams to come on (if possible). In the above picture i selected 'Low beam lights' under Alarm, but nothing happened. Was that the right thing to do?
And just in case the LCM coding has anything to do with this i took a screen shot of that too.
Any help would be highly appreciated,
Thanks guys!
steve.k is offline   Reply With Quote
Old 05-22-2012, 08:10 PM   #577
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
On the LCM module as pictured above, what does the "PWM" value mean?
Also, can you adjust how long your headlights stay on when you use the driveway courtesy function (pull the high beam stalk back).
JetBlackE46 is offline   Reply With Quote
Old 05-22-2012, 08:44 PM   #578
Guest021715
Account closed.
Thank you.
Hot check = will check to see if those bulbs are working when they're on.
Cold check = LCM sends small pulse of voltage to check if the bulbs working when they're off
BC messages = what you see on your dash if you have the BC stalk (mpg, average speed, temp, etc.)
Originally Posted by stevie.k View Post
Hi guys,
Passenger seat occupancy detector is the obvious issue. Search for the DIY.
Scroll up and look at my screen shot. You'll note the obvious difference, which is that you didn't check any of the "After starting" check boxes
Not possible as far as I know. You can set your corners to flash when you unlock (as you have), but that seems to be the extent to which the optical confirmation goes.
If you checked "low beams" for alarm, that just means they'll flash if you trigger the alarm. Hold the trunk release button for 5 seconds and you'll see. Sidenote, I'd just check the high-beam option for the alarm.
Thanks guys!
Old 05-22-2012, 08:51 PM   #579
Sanchjer
My Ride: 323i e46 SOLD!
Just going to throw this out there (don't attack me) haha, can't seem to find the answer, maybe I'm not looking hard enough. Will this programmer work with a MAC??
Sanchjer is offline   Reply With Quote
Old 05-22-2012, 09:34 PM   #580
jaymemaurice
With vmware/windows, yes. Bunt not native under macos
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
