Thread Tools Search this Thread Rating: Thread Rating: 434 votes, 4.97 average.
Old 01-07-2012, 01:08 PM   #41
trj
My Ride: 325Ci
Originally Posted by ccagle View Post
Thanks. I'll give it a try tomorrow.
Here is the link:
http://forums.bimmerforums.com/forum....php?t=1622061
It will give you step by step instructions on what to do. I am still waiting for my cable to arrive
Old 01-07-2012, 04:18 PM   #42
forzam
My Ride: 04 325Ci
How is this scanner different from getting a Peake R5/FCX-3-16?
forzam is offline   Reply With Quote
Old 01-07-2012, 04:22 PM   #43
Foxtrot_Uniform
My Ride: 325Xi
I think the Peake tool just allows you to read and reset codes... Not recode options.
Foxtrot_Uniform is offline   Reply With Quote
Old 01-07-2012, 04:26 PM   #44
forzam
My Ride: 04 325Ci
So this can read everything the Peake tool can?
Old 01-07-2012, 04:28 PM   #45
bugra
My Ride: 330i
yes,and more than that.
bugra is offline   Reply With Quote
Old 01-07-2012, 04:29 PM   #46
hassmaschine
My Ride: '91 325ix
I think all you need for Win7 is the proper usb/serial driver. I have an XP laptop to use for this though.
anyone know - can PA Soft 1.4 synch an EWS unit to a different DME? I know BMW says you cant, but I also know that it can be done. I don't have an EWS unit to try it on but I might pick one up.
Gotta figure out what I'm doing wrong with the MSS54.. trying to read the memory, I get a lot of errors and junk data. but everything else seems to work perfectly.
hassmaschine is offline   Reply With Quote
Old 01-07-2012, 04:39 PM   #47
forzam
My Ride: 04 325Ci
I was ready to shell out $150 on the Peake. Looks like I'll be getting this instead!
Old 01-07-2012, 04:45 PM   #48
Guest021715
Account closed.
Could also get this http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem
Has INPA, DIS, NCS Expert, SSS/Progman. Pretty much every programming option for this car, including ECU flashing.
Old 01-07-2012, 05:06 PM   #49
trj
My Ride: 325Ci
or this
http://forum.e46fanatics.com/showthr...light=fs+cable
Although I got bmw scanner 1.4. I only need to do some coding and not mess with something that I am not familiar with.
PS: thanks ac_2007 for you help in choosing the cable Although I bought it from ebay for a little cheaper
Old 01-07-2012, 05:42 PM   #50
Guest021715
Account closed.
Originally Posted by trj View Post
or this
Its not so much the cable, but that seller provides all the software, video tutorial how to install it, and has a track record for excellent support. Looking to flash my car to the EU2 tune.
PA Soft will do most, if not more than typical owners will ever need though.
Old 01-07-2012, 05:48 PM   #51
Foxtrot_Uniform
My Ride: 325Xi
AC... What will the EU2 do for you? I assume that is a European setup?
Old 01-07-2012, 05:51 PM   #52
trj
My Ride: 325Ci
Agreed ac_2007, PA soft will do what typical owners will ever need. But you can mess up whole lot even with PA soft lol. You are going to get more PMs from me on PA soft usage, though
Thinking to get an old laptop just for the car now. Have to see how PA soft acts with windows 7 64 bit loaded in virtual box in a mac, then I will go for the other softwares and cables.
Old 01-07-2012, 06:07 PM   #53
stevenluczynski
My Ride: Is Steel Blue
Has anyone bought this?
stevenluczynski is offline   Reply With Quote
Old 01-07-2012, 06:44 PM   #54
Guest021715
Account closed.
It will disable monitoring for post cat O2 sensors, which I deleted because I'm running headers. Could also remove the SAP and not trigger a CEL
Sent from my LG-P999 using Bimmer
Old 01-07-2012, 08:50 PM   #55
trj
My Ride: 325Ci
Got my scanner in the mail today. Damn snow, can't test it
Will install it in windows 7 in virtual box in mac and see. Will post the results when the snow ends
Old 01-07-2012, 09:16 PM   #56
Bostonbeast
My Ride: 2009 Yamaha R6
I just bought this a few minutes ago. Thanks ac2007 for the link!
I already have PaSoft but it's capabilities are somewhat limited.
Bostonbeast is offline   Reply With Quote
Old 01-07-2012, 11:27 PM   #57
stevenluczynski
Let me know how it goes!
Old 01-08-2012, 01:49 AM   #58
Guest021715
Account closed.
Lol, np. I'd like to disable my corners and keep fogs enabled while using flash to pass as well. PA can't do that.
Side note, what temperature are the fog bulbs in your sig?
Old 01-08-2012, 03:30 AM   #59
Bostonbeast
Will do!
Yeah I've been playing around with PaSoft a bit and it looks like you can cause some serious problems if you don't know what you are doing. I mainly bought that suite for NCS Expert which I think has the ability to reset any module to its default settings without a backup. So basically it is "safer" coding than Pa Soft.
I got the bulbs from DDM tuning because I was ordering a bumper from there as well. I heard their bulbs are sht but these are pretty good. When I ordered them they just said 9006 - Yellow, so I don't know the exact temp, and I just looked on their website and they don't seem to be on there anymore. But I did compare them to the 3000k fog light that was still on the car and it looked exactly the same in terms of color. So if I were to guess I'd say 3000k (it could possibly be 2500k though).
Old 01-08-2012, 08:37 AM   #60
ccagle
My Ride: 02' 325i
I assume they make coats in your area!! Put one on and get out there!!
ccagle is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
