Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 01-08-2012, 03:00 PM   #61
LD330XI
My Ride: '09 335i
I just ordered the one from ebay. I should have it sometime next week. Now I just need to get my old laptop up and running. I figure if I can code my car once it already paid for itself. If by the time I get it no one has reported back, I will. thank you ac_2007 for the link.
LD330XI is offline   Reply With Quote
Old 01-08-2012, 03:20 PM   #62
ccagle
My Ride: 02' 325i
I'm trying mine in about an hour with Windows 7 and the drivers from the link above.. I'll let everyone know how it goes... "fingers crossed"
ccagle is offline   Reply With Quote
Old 01-08-2012, 03:42 PM   #63
Guest021715
Account closed.
^ Remember to disable all network hardware while installing. Otherwise you'll have a nightmare like Pedi.
Old 01-08-2012, 03:57 PM   #64
Foxtrot_Uniform
My Ride: 325Xi
This is just during the installation, correct? Once installed you can have the wifi on can't you?
Foxtrot_Uniform is offline   Reply With Quote
Old 01-08-2012, 04:05 PM   #65
trj
My Ride: 325Ci
Originally Posted by ccagle View Post
I assume they make coats in your area!! Put one on and get out there!!
yah they do and went to parking lot at night. Ppl must have thought I'm stealing my own car but couldn't get it to work with windows 7 64 bit
I know there is a way to do it, I had installed the FTDI drivers from the same website for generic OBD cable before by making some changes in PId and all but just got impatient and loaded another virtual machine with xp in mac.
Works.
Disabled DRLs and read some codes.
Will do more research see what I can do with it.
Old 01-08-2012, 04:46 PM   #66
ccagle
My Ride: 02' 325i
Got mine to work with windows vista and 7.... That's the good news!!!! Now I have no clue how to program what I need!! LMAO.... Instructions would be nice...
Old 01-08-2012, 04:51 PM   #67
Guest021715
Account closed.
Yes.
Go into each module and look for "Coding" or "Programming Data".
If you post up what you're trying to do, there's probably one of my screenshots up already.
Old 01-08-2012, 04:53 PM   #68
ccagle
My Ride: 02' 325i
Thanks!! Trying to "enable" lights to flash upon locking at the moment
Old 01-08-2012, 05:06 PM   #69
Foxtrot_Uniform
My Ride: 325Xi
It gives you the option of lights, headlights and high beams I think...
Old 01-08-2012, 09:48 PM   #70
ccagle
My Ride: 02' 325i
I got it. Thanks again. After an hour of messing with it, I also killed my battery!!! Didn't expect that though. So just a word of caution, careful on the timeframe while coding!! Haha
Old 01-09-2012, 02:32 AM   #71
trj
My Ride: 325Ci
windows 7 64 bit? what drivers did you use? or what changed did you make if you had to in the driver installations process.
Old 01-09-2012, 06:42 AM   #72
ccagle
My Ride: 02' 325i
Originally Posted by trj View Post
Here is the link:
http://forums.bimmerforums.com/forum....php?t=1622061
It will give you step by step instructions on what to do. I am still waiting for my cable to arrive
I'll give credit to TRJ for posting the above link... Follow the instructions from post #7 in the link above to a tee! VERY IMPORTANT TO DISABLE YOUR WIRELESS OR NETWORK CONNECTION. It did not work until I did.
Old 01-09-2012, 11:13 AM   #73
trj
My Ride: 325Ci
I gave you the link and I was not able to install it myself lol. May be because I was on Virtual machine on mac.
But I got it to work in XP.
Old 01-09-2012, 11:57 AM   #74
ccagle
My Ride: 02' 325i
Too funny!! Well it worked for me on my Vista and 7 laptops so I can use either!! Thanks again!!
Old 01-09-2012, 02:33 PM   #75
trj
My Ride: 325Ci
64 bit?
May be I am running on virtual machine on mac that is the reason.
I got it to work once before with the generic OBD II, will need to dig deep and make some changes on Pid and all. If I get it done I will post it so everyone else can use the steps.
For now I am using it on XP
Old 01-09-2012, 08:49 PM   #76
snobitall_ron
My Ride: 1999 323i (e46)
scanner 1.4 from xcar360 not working
i tried to install it but dont know how to start. im using xp and I tried to connect the device through usb but it couldnt find any hardware. is there any step by step to install?
snobitall_ron is offline   Reply With Quote
Old 01-09-2012, 08:57 PM   #77
Bostonbeast
My Ride: 2009 Yamaha R6
The hardware gets its power from the car not the computer so make sure everything is connected and your key is at least in position 1. Follow the pdf provided on the CD.
Bostonbeast is offline   Reply With Quote
Old 01-10-2012, 01:55 AM   #78
snobitall_ron
I tried to plug the scanner through usb but no detection, no found new hardware.
Old 01-10-2012, 02:17 AM   #79
Bostonbeast
What obd port are you using? Your car, like mine, requires that we use the round 20 pin port under the hood. So you need an adapter. But I don't think using the wrong port would cause it to say no hardware found. Just follow the PDF on installation instructions exactly the way it says on the cd provided. So I'm assuming you have installed the necessary drivers right? And the network and wireless connection is disabled?
Ebay link for 20 pin adapter:
http://www.ebay.com/itm/280745678014...84.m1439.l2649
Old 01-10-2012, 02:37 AM   #80
snobitall_ron
I havent install anything yet. it says on the manual connect the scanner to usb port on the laptop it the new hardware wizard will pop out. but on my case nothing coming out.im still on part of installing the scanner on my aptop. i have windows xp no interenet connection.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
