*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread - Page 40 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 07-18-2012, 06:07 AM   #781
RyanHoelzer
My Ride: 04 m3 vert
Originally Posted by freereeder View Post
i am always annoyed by having to press the unlock button to open the back doors and the boot, or pulling the lever twice to open the door. Is there any way to use pasoft to unlock the car when putting in park, or turning off the engine? Or can the auto-locking be disabled?
It should. Mine didn't lock when I got it and I can make it auto lock. So making a car that auto locks not lock should work.
I haven't found a way to make it unlock when turning off the engine yet.
RyanHoelzer is offline   Reply With Quote
Old 07-18-2012, 06:56 AM   #782
Guest021715
Account closed.
I've posted my "auto-locks-at-24km/h" picture about a dozen times in here already, just look it up and uncheck the boxes so it never automatically locks.
I'm not aware of an option to unlock the doors like you described, but you could also just program to have the button pressed once and it opens all the doors at the same time (deselect selective locking)
Originally Posted by Ballistic325 View Post
Great thread and kudos to OP and all other contributors.
I've just spent 2 days reading through 40 pages in this thread before even plugging in my scanner.... only to find a problem, the same as boongsin12 posted below.
Appreciate some help with 2 issues...
1. My scanner seems to read everything except for the DME and some other modules (which are essential!). My key is in position 1 and I have also tried position 2.
2. In order to access the EWS do I need to erase and unlock it? By doing this will it mean that I can successfully code to the EWS? I know this must seem elementary to you all - I would rather ask than make a mistake on this
Please see attached pics for more info.... thanks!
I can't see the pictures (work), neither is your car model listed. If you have a 323/328, you need the 20 pin round adapter, otherwise the pin likely needs to be soldered. Always use PA Soft with the key in position 2.
Old 07-18-2012, 07:44 AM   #783
makecopies
My Ride: Gods Chariot
My PA came 9 pin cable and I need a 16 anybody else run into this problem?
makecopies is offline   Reply With Quote
Old 07-18-2012, 08:14 AM   #784
Ballistic325
My Ride: slow and steady
Thanks AC. The car is a '01 325 sedan, Australian delivery / Euro spec.
I will try again in key position 2.
EDIT: I checked the pins and solders against what others from the same seller have posted including delmarco, my device is the same.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 07-18-2012, 02:34 PM   #785
freereeder
My Ride: BMW 320i
Thanks AC. I had seen those posts, but is looks as if the speed selection is done with option buttons, in which case you can't deselect a speed. But I haven't tried it yet; I'll give it a go this weekend. Mine is a 2001 320i by the way.
freereeder is offline   Reply With Quote
Old 07-18-2012, 02:40 PM   #786
RyanHoelzer
My Ride: 04 m3 vert
Thanks AC. I had seen those posts, but it looks as if the speed selection is done with option buttons, in which case you can't deselect a speed. But I haven't tried it yet; I'll give it a go this weekend. Mine is a 2001 320i by the way.
That's a good point but mine didn't autolock before so there should be a way to unselect. My guess is unselect all of the above Automatic Locking checks and it will clear. Let us know..
Some people have also said that theirs only worked with certain speeds. You could try the different speeds and see if you find one that doesn't work.
Old 07-18-2012, 02:41 PM   #787
boongsin12
My Ride: none
If you bought your reader from xcar360, the pins should be soldered already.
1+ on key position 2. I made this same mistake.
boongsin12 is offline   Reply With Quote
Old 07-18-2012, 03:37 PM   #788
trj
My Ride: 325Ci
Always have the key in position 2 or start the car.
PS: Do not get too adventurous and keep the car in ON(position 2) for a long time(hours). It will drain your battery. So keep the coding time short.
Old 07-18-2012, 04:29 PM   #789
RyanHoelzer
My Ride: 04 m3 vert
Are you saying it came with the round connector, not the trapezoid? Where'd you buy it from? Did it say which connector it was? There's probably an adapter available but all the ones I've seen go from trapezoid to round, the opposite way.
Old 07-18-2012, 06:25 PM   #790
RyanHoelzer
My Ride: 04 m3 vert
I played with it for a while tonight. Mine works with all the speeds and I thought I was stuck with auto locking until I realized all you have to do is uncheck the keys. The speed is tied to which key you have activated so by simply unchecking them the speed setting does nothing..
Old 07-18-2012, 08:47 PM   #791
cyberlando
My Ride: 2002 M3
i bought mine from whatever 360 and it doesnt show me live data for m3 is anyone else having this issue?
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 07-18-2012, 09:33 PM   #792
steve.325i
My Ride: 2003 325i
Originally Posted by RyanHoelzer View Post
I had to play with the lock settings but set up like this I have all locks locking and unlocking with 1 press, and auto locking at 28 km/h. The 1 touch locking is the settings that are "Entr. aid". The One-touch functions settings let me put the top up and down from the remote.
I haven't found a way to unlock when turning the car off yet. Not sure it's possible on these cars at this point.
'Entr. Aid' on my car caused my window to down when I opened tha car door and then it would go back up when the door was closed. I was not able to find any explaination about this feature.
I have all of my option under 'Selective locking functions' set to 'No' which disables 'Selective' unlocking.
steve.325i is offline   Reply With Quote
Old 07-19-2012, 02:20 AM   #793
Ballistic325
Thanks for the help and the info. I should myself for not using key position 2. So me.
Feedback:
1. My doors now auto lock at 12kmh
2. Harzards flash on un/lock
3. I was able to view and clear any present codes and now I can monitor for codes in the future
4. After coding the IKE I get the following error (I know the oil level sensor is bad already!):
Any ideas on how to clear that error? It is BF[191].
Questions:
1. How do I reset the ASG (auto gearbox) adaptations using the software? I know there is a key / ignition sequence for it.
2. There are 5 or 6 shadow codes that immediately reappear on the DME. Is it correct that these are to be ignored? I am just checking the first post to see if they are the same codes...
3. Question re access to the EWS still stands as per previous post. Do I erase and unlock?
Thanks...
EDIT: Here are the codes that I am getting on the DME. The 5A/5B/5D codes are apparently supposed to be "unread" but the rest could be problems. Any input appreciated.
DME -> 08/B2 - Air mass flow sensor signal, short circuit to negative or open circuit
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
85/08 - Signal, CAN ASC 3, timeout elapsed
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
I can help with
* RTABs
Old 07-19-2012, 02:35 AM   #794
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Hey Ali good to hear you got it all sorted. I always have my key in position 2 and engine running when doing these diagnostics. Funny things and errors happen whenever there is the slightest drop in voltage so I've found it best to always have the engine running so voltage is stable.
I don't think there is a way to delete the DME shadow memory. I've got the same thing with my DME where there are no current errors but about 15 shadow memory error that always show up.
Shannon.
shannon1 is offline   Reply With Quote
Old 07-19-2012, 05:43 AM   #795
bAby norAA
My Ride: 01 BMW 330i
We really should find a way to make a sticky with the relevant info in this thread so the next person who stumbles across it doesnt have to read 40 pages of posts with only 10-12 actual posts with info on the software.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 07-19-2012, 08:26 AM   #796
shannon1
shannon1's Avatar
My Ride: 2001, 318i
+1
Shannon.
Old 07-19-2012, 08:50 AM   #797
shanneba
My Ride: 2003 330Ci
Also the ODB socket always has power, if the OBD adapter has any LEDs, they will stay on as long as it is attached to the connector also draining power from the battery.
Join BMWCCA
Old 07-19-2012, 09:57 PM   #798
mikeson
My Ride: 99 323I
I have a question.
I installed the soft and can get this window.(as below)
Originally Posted by delmarco View Post
I have both and ran both. Here are the visual results (looks the same I guess):
new:
And when I click ZKE I could get this kind of window.
Accord...
But how can I get this window?
I clicked 'Read memory' and it asked me which number to which number.
and afraid to click other button.
Anyway, how can I get below window?
thank you.
Below are my settings for the alarm, notice the
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 07-19-2012, 10:29 PM   #799
Cuda12
My Ride: '99 C43/'04 330I SMG
I am trying to get the scanner to work. I purchased it from xcar360 and downloaded the drivers. The 7,8 pins are soldered. I plug it in and the ignition is set at #2 but nothing happens. I am running Windows 7 and it is for an "04 330I. I read this entire thread and cannot figure out the hiccup. Any help would be greatly appreciated.
Cheers
Cuda12 is offline   Reply With Quote
Old 07-19-2012, 10:37 PM   #800
RyanHoelzer
My Ride: 04 m3 vert
Originally Posted by mikeson View Post
I have a question.
thank you.
Click light coding
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
