Thread Tools Search this Thread Rating: Thread Rating: 435 votes, 4.97 average.
Old 07-31-2012, 02:51 PM   #901
daxmax
My Ride: 320d E46
Scanner not working, "Privileged instruction"
Hi guys.
I have a 1999 E46 320d. I recently purchased the BMW Scanner 1.4 and connected it to the under-the-hood connector using a 16 pin-20 pin adapter. When I plug it in to the laptop, I dont see the green USB light being lit. The Orange light is lit from the time it's connected to the car. The computer says the USB device is working properly and the software detects the adapter (says adapter is plugged in and the little box is green).
However, that is as far as it goes. When I click the 'continue' button, error messages pop up. The first one says 'External exception C000001D' and then every second a new error message pops up saying 'Privileged instruction'.
I'm running the software on a Windows XP laptop. I even tried the regedit 'delete PAsoft' trick, but to no avail.
Have I been sold a lemon? Does the Green LED need to be lit continuously?
What do I need to do to get this software to run?
Cheers
daxmax is offline   Reply With Quote
Old 07-31-2012, 04:03 PM   #902
iowna330xi
My Ride: is not yet fast.
Tried to read all post but need a definite answer re: PPPPP on cluster
I recently used Carsoft 6.5 on a 99 323i, I just reset the airbag light but now my cluster shows PPPPP error code. Will PA 1.4 eliminate this code and restore my odometer reading. Btw everything works fine in the cluster except for the PPPPP on the lcd.
iowna330xi is offline   Reply With Quote
Old 08-01-2012, 12:20 AM   #903
daxmax
My Ride: 320d E46
BMW Scanner not working + error messages
Hi guys.
Cheers
Old 08-01-2012, 08:11 AM   #904
SpoonerDee
My Ride: 2005 E46
There is a huge giant thread on this topic. Ask in there.
SpoonerDee is offline   Reply With Quote
Old 08-01-2012, 08:45 AM   #905
daxmax
My Ride: 320d E46
I tried but didn't get any response, so thought there may be a better chance on an individual thread.
Old 08-01-2012, 09:06 AM   #906
Guest021715
Account closed.
I don't recall how it works with the under hood connector, however my scanner has a red LED constantly on from the moment its plugged in the OBD2 port.
Try reinstalling on another laptop, make sure its running a 32-bit OS, and that your key is turned to position 2 (run).
Old 08-08-2012, 10:46 PM   #907
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
What kind of USB cable do you need to hook up the computer to the car?
lllRazorlll is offline   Reply With Quote
Old 08-09-2012, 04:12 PM   #908
Kmoy2002
My Ride: 2002tii, 540i, 330i
Not sure if you're trolling but did you not even bother to read this thread?
Kmoy2002 is offline   Reply With Quote
Old 08-09-2012, 04:26 PM   #909
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
The obd connector has a firewire cable on its end and a usb on the end that goes into the comp.
Schlag96 is offline   Reply With Quote
Old 08-09-2012, 08:04 PM   #910
lllRazorlll
Modded ///Member
My Ride: '00 328i
Okay, thanks! Where is the port in the car located?
Old 08-10-2012, 10:48 AM   #911
trentcdrums
My Ride: BMW 323i Sedan
Top right of the car when your looking into your hood. Round piece that screws off.
Old 08-10-2012, 10:49 AM   #912
trentcdrums
Or top left. For my 323i 2000 it's top left
Old 08-10-2012, 01:13 PM   #913
hassmaschine
My Ride: '91 325ix
PPPPP means a checksum error. You could try reflashing it in INPA.
hassmaschine is offline   Reply With Quote
Old 08-10-2012, 01:51 PM   #914
lllRazorlll
Modded ///Member
My Ride: '00 328i
Is this it?
Old 08-10-2012, 02:52 PM   #915
mrmaico
My Ride: 04 ZHP, 05 R1200 GS
That's it. Newer models have it under the dash and shaped different.
mrmaico is offline   Reply With Quote
Old 08-10-2012, 06:26 PM   #916
lllRazorlll
Modded ///Member
My Ride: '00 328i
Sweet, what's the cable called also?
Old 08-11-2012, 01:57 AM   #917
slocar
My Ride: 323ci
Search for "Bmw 20 pin adapter"
slocar is offline   Reply With Quote
Old 08-11-2012, 12:40 PM   #918
lllRazorlll
Modded ///Member
My Ride: '00 328i
Awesome, I found it. I'll let you guys know how it goes down.
Old 08-13-2012, 09:56 AM   #919
makecopies
My Ride: Gods Chariot
I keep getting the msg........Drivers not installed.
But I did install them. What am I doing wrong here?
makecopies is offline   Reply With Quote
Old 08-13-2012, 09:56 AM   #920
makecopies
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
