Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 09-11-2012, 05:43 AM   #1021
robin325ci
My Ride: Helrot 325Ci
Has anyone tried using the software downloaded from the PA Soft website and used it on the scanner from xcar360? I read somewhere that the 1.4.0 software from the PA Soft website bricks and renders the clone scanners useless.
Post #128
http://forums.bimmerforums.com/forum...1726627&page=6
robin325ci is offline   Reply With Quote
Old 09-11-2012, 06:24 AM   #1022
Tritan84
My Ride: 2002 325i
Read through the majority of this thread, but got confused on the various scanners that were brought up.
Which scanner setup should I get if my main objectives are the following:
-Turn off air bag light
-diagnose and treat/reprogram dsc/abs/brake light
-update dme software
Sent from my ADR6300 using Bimmer App
Tritan84 is offline   Reply With Quote
Old 09-11-2012, 07:01 AM   #1023
Guest021715
Account closed.
Post #128
False, as of current date.
1) Yes
2) Diagnose, not reprogram dsc/abs. Lights are a different module and you can reprogram.
3) No, you need another software package. (INPA/Winkfp/SSS/Progman/NCSexpert)
Old 09-11-2012, 08:09 AM   #1024
Tritan84
My Ride: 2002 325i
1) Yes
Can I just get the INPA/winkfp/sss/progman/ncsexpert program and get my above objectives completed or will I also need PASoft?
Old 09-11-2012, 08:38 AM   #1025
Guest021715
Account closed.
That package would do just about everything that can be done to a BMW. Its much much more complex and difficult to use, plus has the high potention to screw something up if you don't know what you're doing. The installation and understanding of how it works took me a few weeks of reading, and trial/error.
PA Soft is the everyday user's program. It is very thorough in its diagnostic capabilities, and programming is very easy (a few clicks). You only really need to update the DME to eliminate the CEL after installing headers anyways.
Old 09-11-2012, 08:58 AM   #1026
Tritan84
My Ride: 2002 325i
Ok, ill go with PA soft for now. My only concern is that if I need to replace a abs/dsc module, and I purchase a used one, will I need to reprogram it.
Old 09-11-2012, 07:40 PM   #1027
eljay
My Ride: ///M
I've read up to page 9 and didn't feel like reading up to 51 lol, so I'll just ask my question at a risk that it has been answered.
Can I use the software from PA Soft's website together with a cable from this auction? http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem
Or do I have to get the special BMW Scanner 1.4 cable to make this work?
I'd like to change the odometer display from miles to kms, enable mirror tilt to curb on reverse, and remote windows.
Thanks.
P.S. Love the tags on this thread.
eljay is offline   Reply With Quote
Old 09-11-2012, 10:58 PM   #1028
El Polo
My Ride: 99 black 328i
Eljay no this is a different tool. PA soft with their scanner, obd/k-line cable with INPA
Sorry if this post doesn't make sense. I am writing on a cell phone.
El Polo is offline   Reply With Quote
Old 09-12-2012, 05:20 AM   #1029
eljay
My Ride: ///M
Got it. Thank you.
Old 09-12-2012, 06:39 AM   #1030
MT-Adam
My Ride: 540i/6
Hello!
Im thinkin of buy PA soft 1.4 or a tool like that for my E39. Is there any company that sell the real PA soft cheper than 650 dollars, which BMW-Scanner.com does?
Im a bit conserned that if i buy a china-copy from Ebay, there can be some bugs, or maybe hardware faults, which probably can be very bad for the car or pc...
I will probably have some Bimmers in my life, so im thinking that it is smart to get something that i can use for the future. Please give me some advices what to buy.
MT-Adam is offline   Reply With Quote
Old 09-12-2012, 02:35 PM   #1031
haurelio
My Ride: 2001 bmw 325i
Hello!
I dont think you can buy a genuine adapter for that price. The adapter does a great a job, there are no bugs, or hardware faults. you can however mess your car with improper coding/settings even if you use the genuine adapter. now to answer your question, this is a great tool for bmw codes scanner, and do some coding such as alarm, windows, and some other lighting features..
Old 09-13-2012, 04:31 AM   #1032
MT-Adam
My Ride: 540i/6
Ok, well if it does work good, i guess there is no other better cables for the price? Shall i order it from resttools?
Old 09-13-2012, 09:34 AM   #1033
TomTomTuning
My Ride: Black Sapphire ZHP
Just curious, can I disable the checks that are done for the front turn signals? That way I can replace mine with LED's.
Would that prevent the "fast blink" that people occasionally experience?
I'm mainly looking to avoid having to use a resistor, I dislike the idea of crimping one in.
TomTomTuning is offline   Reply With Quote
Old 09-13-2012, 11:20 AM   #1034
Guest021715
Account closed.
I'm 99% sure that would only disable the bulb-out errors on the dash, and not the fast blinking itself (Do E46's even do that?)
Old 09-13-2012, 11:28 AM   #1035
drift.mechanic
My Ride: E46 323i
You can disable the cold bulb check for any bulb, but you will still require the resistor not I have light strobing or quick flash.
By also resetting the bcm to recognize aftermarket xenon's, you don't need a resistor so that you don't have bulb flash/error.
drift.mechanic is offline   Reply With Quote
Old 09-13-2012, 12:21 PM   #1036
TomTomTuning
I'm not sure if E46's do that but I've just read about people having flash blinking when using LED turn signal bulbs. If our cars dont do that, then that's great!
Will it be okay to enable the Xenon option, even though I don't have Xenon/HID's?
I'll order the bulbs and disable the cold check, if I have a flash blink or issues, I'll order the resistor.
Old 09-13-2012, 03:34 PM   #1037
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Yep. Mine did it. Had to jimmy the wires around because the short was somewhere on the front turn signal harness.
Does anybody here know how to disable the CEL related to the secondary air pump? Mine is making a racket and I probably won't get to fixing it until I do my next smog check.
Schlag96 is offline   Reply With Quote
Old 09-13-2012, 04:11 PM   #1038
Guest021715
Account closed.
You can't. Need the BMW Standard Tools package to flash an EU tune in order to remove it.
Old 09-14-2012, 01:59 PM   #1039
vard81
My Ride: BMW 323i auto 2000
Hi bschillberg710,
Have you found a solution? I am having exactly same problem. It can find DME and EGS too. And mine connections looks like yours.
I did research and I think solder for 7-8 pin should help. Please see below: http://pinoutsguide.com/CarElectroni...c_pinout.shtml
Have you double check that you have done it correctly?
vard81 is offline   Reply With Quote
Old 09-15-2012, 01:43 PM   #1040
adaseb
My Ride: 2002 BMW 320i
Will it work with this eBay BMW Scanner tool?
http://www.ebay.ca/itm/BMW-Scanner-1...t_11045wt_1186
adaseb is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
