Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 09-20-2012, 08:46 PM   #1061
slocar
My Ride: 323ci
Originally Posted by Patton323I View Post
Yeah I have the OBD 1 under the hood. I just thought that the OBD 2 would have full function on the cars computer. And I didn't feel like searching though 100+ pages at first. Then I searched and found what solidjake had posted. Its all good though.
All cars made in 01 and earlier need the 20 pin adapter.
slocar is offline   Reply With Quote
Old 09-20-2012, 09:05 PM   #1062
JDez
My Ride: 2001 330i
Wrong. My 330 has a manufacture date of 05/2000 and I don't have a 20 pin connector. The easiest way to check is just to look in the drug bin.
Sent from my myTouch_4G_Slide using Bimmer App
JDez is offline   Reply With Quote
Old 09-20-2012, 09:23 PM   #1063
pawelgawel
My Ride: 330CI
^^ true story... had a 2000/05 323 with obd 2 plug
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 09-20-2012, 10:12 PM   #1064
Guest021715
Account closed.
Originally Posted by TonyJ View Post
So you still need to buy other code reader to get engine code? I was hoping this is the all-in-one tool. Too bad.
Why would you need engine codes and "guessing", when this tool will tell you exactly what's wrong, specifically in which module, and with descriptive language?
P-codes are useless in comparison.
Nope.
Even some model year 2000 E46's don't need it.
Old 09-20-2012, 10:14 PM   #1065
drift.mechanic
My Ride: E46 323i
My moms 2000 doesn't have the 20 pin
drift.mechanic is offline   Reply With Quote
Old 09-20-2012, 10:14 PM   #1066
drift.mechanic
My Ride: E46 323i
But my 99 does
Old 09-20-2012, 11:10 PM   #1067
UDown0311
My Ride: '04 330ci ZHP
no lie, the pa soft codes are blowing my mind . i really just want to know why my SEL is on...
and why would this guy ---> http://s16.photobucket.com/albums/b3...annerPart1.mp4 have quite a few more units "recognized" than i do? does it have something to do with the software and how i installed it on W7?
UDown0311 is offline   Reply With Quote
Old 09-21-2012, 01:56 PM   #1068
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Because a lot of the units are for optional equipment. I only have like 10 units on my base 1999 323i
Schlag96 is offline   Reply With Quote
Old 09-22-2012, 12:08 AM   #1069
filipinoise
My Ride: '02 325ci
Got an SES light on the way to school today. Started the car up perfectly fine. Engine ran smooth as butter as it always does, with no idle problems whatsoever. A few minutes in, when the car was heated up to operating temperature, the engine starts to shake ever so slightly. Nothing violent, just a little vibration. Idle starts to drop a bit , then go up, then go back down. No stalling. SES light comes on. I've never gotten an SES before, and the car's been pretty well maintained (so far, in about 11 months/ 5-6K miles, I've done new brake pads, oil change with 5w30, new air filter, new cabin air filter, new spark plugs (BKR6EQUP), new battery, new voltage regulator, VANOS seals, VCG, overhauled cooling system, new belts, pre-cat o2 sensors, and cleaned MAF. Manual transmission fluid replace, differential fluid replace, power steering fluid replace, clean ICV, and replace upper & lower intake boots are coming soon, and I'll be overhauling my suspension shortly. CCV and DISA will be done either next semester or during the summer). Since I had a quiz today (and because I can't manage to miss class), I wasn't able to turn around so I sucked it up & continued to drive to school. About 6-7 minutes later, the SES light goes away and car goes back to idling well with some very slight roughness. Overall, though, it was pretty decent. What the hell? I'm thinking, okay, hopefully it doesn't come back anytime soon (because obviously it would come back, but I don't want to deal with it right now when class is about to start), but I'll still scan the car at home later on in the day and fix whatever is wrong. Well, the way things go, the SES light came back about 10 minutes later. I was able to make it to school, but I'd say barely. The engine wanted to stall, and it was an even bigger nuisance driving uphill and having to apply more gas to get the car to go up or else it'd stall (due to a major loss in power and acceleration). I was at about 1/4 tank of gas. As of right now, I'm just going to take one of my parents' cars to school next week and the week after that - until the problem is resolved. Thank goodness it's Friday.
Scanned the car via PA Soft (v1.4.0.9) and under DME, here's what I had:
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> E4/F1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
E3/F1 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
F2/B5 - Misfire, cylinder 5, misfiring with cylinder cutout (Misfire CARB_A), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F1/B5 - Misfire, cylinder 4, misfiring with cylinder cutout (Misfire CARB_A), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F3/B4 - Misfire, cylinder 6, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
EE/B4 - Misfire, cylinder 1, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F0/B4 - Misfire, cylinder 3, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
3F/14 - Control unit self-test 3
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
Cleared them, and resulted in these:
DME -> Shadow-memory:
Wasn't able to take the car out for a drive after that, though. Anyone have any ideas?
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
filipinoise is offline   Reply With Quote
Old 09-22-2012, 12:09 AM   #1070
I M Legend
My Ride: M3
Can PA soft eliminate the need for a resistor when installing interior LED lights?
I M Legend is offline   Reply With Quote
Old 09-22-2012, 12:19 AM   #1071
TerraPhantm
My Ride: M3 & ZHP
01s don't. Only 323s and 328s need the adapter.
Old 09-22-2012, 01:21 AM   #1072
UDown0311
So even the DME unit could possibly not be available, even on an 04? Seems like the newer the model the more options you would have, right?
@filipinoise - I had similar issues and pulled an engine code (not using PA software) that said I was misfiring. I changed out all the plugs, cleaned the MAF sensor, the throttle body, ICV, and replaced the DISA (it was literally falling apart which was probably the source of the problems). After that, light went off and stayed off.
Old 09-22-2012, 11:04 AM   #1073
slocar
My Ride: 323ci
To my knowledge the only thing you can do with interior lights using pa soft is turn the fade on/fade off on and off ... not sure if that helps any
Old 09-22-2012, 11:32 AM   #1074
joegr
My Ride: 2002 325i
I have stuff not showing up on mine that I know I have, like ABS, Auto AC, EML, ...
I looked inside the adapter, and the two pins on the end are bridged together.
joegr is offline   Reply With Quote
Old 09-22-2012, 12:43 PM   #1075
Guest021715
Account closed.
Shadow-memory:
From the codes, it would be saying that your pre-cat O2 sensors are to blame. However, I somewhat doubt this since both bank 1 and 2 codes showed up - that is, unless you replaced with cheap aftermarket sensors.
Check if you have any vacuum leaks from the lower intake boot, and if you recently washed under the hood, water could've gone on the coil packs.
The shadow codes that remained after you cleared everything are just engineering codes. They don't apply to your car, and you can't clear them, just ignore those.
I programmed a 323 without the 20 pin adapter.
There seems to be a cutoff date in late 1999/ early 2000 production date when the under-hood connector was discontinued. 323/328s included.
Old 09-22-2012, 01:04 PM   #1076
I M Legend
My Ride: M3
yeah I looked through the menu and didn't see any other option. thanks!
Old 09-22-2012, 05:18 PM   #1077
Noodle555
My Ride: M3 Cabriolet
My car threw an SES light so I thought I would buy the BMW Scan tool to read the code. Got everything working fine but when I run the scan it does not find the DME, which is where I think the code would be stored.
Am I doing something wrong? I used the latest software on the PA Soft site. Has anyone else had this problem?
The tool found a bunch of minor errors and I was able to switch off my DRLs.
Pins 7 & 8 already soldered together.
M3 Vert TiAG/Blk - with every option
Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners
Mods ready to install: Paddle Upgrade | ZCP Rotors | CF Interior Trim
Noodle555 is offline   Reply With Quote
Old 09-22-2012, 09:10 PM   #1078
joegr
My Ride: 2002 325i
Yes, DME isn't found for me either. (2002 325i)
Old 09-23-2012, 08:05 AM   #1079
carborn
My Ride: E46,E91
I've tested several cars as yours (with ECU MS43) and DME was found on all cars. I think it can be because of adapter. I'm using genuine one from Pasoft and there was no problems - DME or DDE is visible every time.
carborn is offline   Reply With Quote
Old 09-23-2012, 09:15 AM   #1080
TonyJ
My Ride: E46 330i
Mine also cannot see DME. I bought from xcar360. Anyone else bought from them can see DME?
TonyJ is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
