Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 10-12-2012, 07:13 AM   #1161
robin325ci
My Ride: Helrot 325Ci
Originally Posted by Custom3 View Post
I been waiting a month for my scanner from 360...if that sh*t comes faulty Im just taking my losses...not bothering with returning it and waiting another month or two for another one. I regret getting it from that site.
Hope yours isnt faulty and I hope when mine arrives it isnt as well
I finally got mine the other day. Ordered from xcar360. It worked perfectly on my laptop running Win 7 Ultimate 64 bit. Definitely worth the wait
robin325ci is offline   Reply With Quote
Old 10-12-2012, 10:42 AM   #1162
Custom3
My Ride: HellRot 330CI
good to know....my tracking status after 2 weeks finally says "arrived at delivery office"....what ever that means...lol...I thought USPS was horrible...Hong Kong Post beats them.
Old 10-12-2012, 11:13 AM   #1163
Custom3
I think it might have arrived at my house....got to check after work.
Old 10-12-2012, 04:56 PM   #1164
Custom3
any one know what the unit software reset does and is it safe to do?
Old 10-12-2012, 06:30 PM   #1165
Custom3
So after clearing old codes these are the ones that stayed.
After doing some research turns out the 4 codes below are normal and are not suppose to be seen. Hidden trouble codes that aren't really any trouble.
DME -> Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
Have no lights on the dash so Im not really worried about the ABS codes. I do need a wheel alignment so that could be why
ABS* -> 5E1A/C0 - CAN DME/DDE Signal Error.
5E19/C0 - CAN DME/DDE, engine torque not adjustable.
5E5B/40 - DSC push button pressed longer than 10 sec or Error.
5DF4/40 - Vehicle power < 9 Volt.
5E43/C0 - Steering angle sensor internal.
Same as the catalyst codes above. Hidden codes that mean nothing
LCM -> 16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
Shadow-memory:
33/01 - Sidelight, front right
38/01 - Sidelight, front left
3E/01 - Rear fog light faulty
Was surprised to see how well my baby is doing. The live reading feature is awesome Defiantly worth the 1 month wait and worth the $40 bucks.
What I have done was the following.
Disabled stolen car key (main reason I got PA soft)
Disabled daytime running lights
Enabled automatic door lock when driving speed reaches 25k (Disabled by dealer 4 years ago)
Enabled all windows to open when holding the unlock key (rear weren't opening since I took it to the dealer 4 years ago, not sure why they disabled that as well )
Enabled the option to close all windows with the lock key (great feature to have)
Old 10-13-2012, 12:09 AM   #1166
robin325ci
I'm getting similar shadow error codes on my DME
Old 10-13-2012, 11:28 AM   #1167
Custom3
I wouldnt worry about it....you got a aftermarket exhaust?
Oem comes with a flap in the back....if removed I think it will show that last code you got. Shadow ones I wouldnt worry about to much.
Old 10-13-2012, 03:00 PM   #1168
robin325ci
I have an aftermarket exhaust, and no flap in the back because my car is a 325
Old 10-16-2012, 08:37 PM   #1169
Grease_Monkey
My Ride: 2000 323ci
CAn someone Please help me.. I cannot get PA soft to open on the laptop I am using for it. I have put the small Cd in and installed the Program, then when i go to use it I get an error message that says "Drivers are not installed for this program" And it sends me to the folder on the cd with the Installation manuals and such. I cant open any of the instructions though! My laptop doesnt recognize the file and asks me what program to use. I have tried EVERYTHING to no avail.. and my Adobe isnt working either.. ANY help would be awesome guys. I just want that airbag light gone!!!
Grease_Monkey is offline   Reply With Quote
Old 10-16-2012, 08:58 PM   #1170
TrippinBimmer
My Ride: Just Fast!
Originally Posted by ac_2007 View Post
Could also get this http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem
Has INPA, DIS, NCS Expert, SSS/Progman. Pretty much every programming option for this car, including ECU flashing.
Does this have WINFKP? So I can DL the Flash and Reflash my EGS?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 10-17-2012, 06:44 AM   #1171
El Polo
My Ride: 99 black 328i
Yes pretty sure it comes with INPA. If it doesn't, that's not an issue as it is somewhere on the internet... Pm me if you can't find it. iirc it was on a Russian website.
Sorry if this post doesn't make sense. I am writing on a cell phone.
El Polo is offline   Reply With Quote
Old 10-17-2012, 07:41 AM   #1172
jfoj
My Ride: 330CiC, M5, X5, E93
Grease Monkey,
To get the drivers to load, you have to have the cable connected to the car.
Old 10-17-2012, 11:38 AM   #1173
Guest021715
Account closed.
Those are engineering codes that do not apply to your car.
They can not be cleared.
Yes.
Old 10-17-2012, 01:26 PM   #1174
Grease_Monkey
My Ride: 2000 323ci
Thanks Jfoj. My problem was that the PC would not automatically recognize the scanner was even plugged in.. I got it to load up just fine after that. I then went out and accomplished EVERYTHING that I wanted in just about 30 mins! HELL YA! Pa soft rocks.. I am sure I will need to fiddle with it a little more to get it right/ As far as some of the coding options. Thanks again guys. Awesome tool to have!
Old 10-20-2012, 11:42 PM   #1175
Grease_Monkey
My Ride: 2000 323ci
Hey fellas, off the top of your head, does anyone know if and how to program lights with this PA soft? I want the corners to be off and only used for blinking,, and use the side markers for the running lights..
Also I would like to be able to use fogs while in Highbeam... Thanks for any help.
Old 10-20-2012, 11:42 PM   #1176
Grease_Monkey
My Ride: 2000 323ci
Old 10-21-2012, 12:01 AM   #1177
trj
My Ride: 325Ci
Not possible with PA soft.
INPA is your friend for this type of coding.
Old 10-21-2012, 02:00 PM   #1178
anton2718
My Ride: 2001 325i
Originally Posted by E46tknv View Post
would this software be able to do corner light delete?
it did for me, i have angels that are connected straight to my corner lights, it turned off my corners but left the angels on, not sure at all how that works
anton2718 is offline   Reply With Quote
Old 10-21-2012, 03:24 PM   #1179
Custom3
you did this PA soft? I didnt see the option for that
Old 10-21-2012, 07:50 PM   #1180
pawelgawel
My Ride: 330CI
changed to one click open all doors and remote close windows
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
