Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 11-24-2012, 04:07 PM   #1201
Sshark
My Ride: 328i and Z3
Originally Posted by SHOoff11 View Post
Do I need the 20pin adapter for my '99?
You need the rounded 20pin adaptor
Sshark is offline   Reply With Quote
Old 11-24-2012, 04:10 PM   #1202
SHOoff11
My Ride: 1999 Lexus LS400
Thanks! I plan on ordering both tonight.
Originally Posted by SPDSKTR
You drive a BMW. That means you make $600,000 a year and date supermodels without pointy elbows or hairy arms. Need I say more?
2001 BMW 330ci vert 5-MT Steel Grey/Tannin Red
1993 BMW 325i 5-MT Black/Tan
2010 Chevrolet Silverado 2500HD Z71 Summit White/Black
SHOoff11 is offline   Reply With Quote
Old 12-07-2012, 08:26 AM   #1203
p0lar
My Ride: E46 ///M3
I've also got the dreaded 'No coding data retrieved' error on my '04 M3 (6MT) when trying to connect to the IKE module.
Was anyone able to figure this out apart from luthers and Terraphantm?
If not, there are a few options I would like to have investigated by someone who's familiar with NCSExpert and PA Soft and has an E46 325 or 330 using PA Soft version 1.4.0.9.
My thinking is this, that PA Soft isn't doing anything that NCS Expert can't; thus, if someone could read the NCS Expert config out, save it, then make a change with PA Soft, then read out the NCS Expert config again and run a diff against it, it wouldn't be an issue whatsoever.
Is anyone game to help a fellow coding enthusiast out?
p0lar is offline   Reply With Quote
Old 12-07-2012, 06:43 PM   #1204
SHOoff11
Can I code my '99 with halogens to xenons with aftermarket HIDs for a retrofit to get rid of the errors? I bought the error cancelers, but people say those don't always work. I've been told conflicting things when searching.
Old 12-08-2012, 09:33 AM   #1205
spherehunter
My Ride: 2001 BMW 325i
Running Lights/Auto Lock
I cant seem to get the running lights or the Auto locks using PA Soft on my 2001 BMW 325i. I have gotten everything else to work except this two items. Anyone have any ideas?
spherehunter is offline   Reply With Quote
Old 12-08-2012, 05:43 PM   #1206
SHOoff11
Are pins 7 & 8 bridged on your scanner?
Old 12-08-2012, 06:57 PM   #1207
wildirish317
My Ride: 2004 325Ci vert
Finally received my scan tool today. Ordered it on 11/19 via HK post, so it took less than the month I expected. I tried loading it on my Windows 7 laptop, but could not get it to load the driver. One forum suggests holding down the F8 key during computer boot, and selecting "Disable driver signature recognition". This didn't work on my Windows 7 laptop, but it did work on my Windows Vista laptop.
It's really nice being able to know what codes are actually being thrown, and which ones are still active.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-08-2012, 07:50 PM   #1208
spherehunter
I assume so I was able to enable the alarm and all convenience features.
Old 12-08-2012, 09:59 PM   #1209
rwall
My Ride: 2004 325ci
My car is NOT beeping at 37 degrees. Thank you c-car 360!
rwall is offline   Reply With Quote
Old 12-10-2012, 01:32 AM   #1210
hassmaschine
My Ride: '91 325ix
just use NCS dummy with NCSexpert. there's almost nothing really interesting you can do in PA soft to an E46 M3 cluster anyway.
also, there are things that you can't change in that particular cluster. I'm thinking that's the reason you're getting an error message.
hassmaschine is offline   Reply With Quote
Old 12-10-2012, 01:36 AM   #1211
scarede46er
My Ride: 2001 BMW 325i ZSP
yes. There is a section for that in Pa Soft under LCM.
Old 12-10-2012, 01:38 AM   #1212
scarede46er
The door locks are under ZKE under recoding.
DRLs are under LCM > reprogramming. You need to check both EU and US to have the DRLs else you will only have your parking lights on as DRL.
Old 12-10-2012, 01:58 AM   #1213
p0lar
My Ride: E46 ///M3
You can recode the mileage and/or VIN for replacement or to convert from SMG to 6MT. To my knowledge, that's not possible with NCS Expert/dummy.
There are quite a few of us who are trying to enable the E46 M3 CSL's oil level function in the standard 6MT/SMG E46 M3 cluster.
Old 12-10-2012, 02:10 AM   #1214
TerraPhantm
My Ride: M3 & ZHP
Can't change mileage without an external programmer. I believe the same applies for the VIN.
The rest of the settings in the cluster page are found in NCS Expert
Old 12-10-2012, 02:54 AM   #1215
p0lar
My Ride: E46 ///M3
You can't change the mileage/VIN of the AKMB (IKE) using PA Soft? Hrmn.. You can do it with the ALSZ (LCM).
I think it's just a string of bytes ordinarily grabbed by a specific request. I was going to do a serial dump some day to see how the communication protocol works, but there are just too many other interesting things to do on the MSS54HP at the moment.
Old 12-10-2012, 03:05 AM   #1216
TerraPhantm
My Ride: M3 & ZHP
Yeah the mileage on the AKMB/IKE is protected.
Try for yourself. Backup an EEPROM, change the mileage, and upload. If you read it back, you'll find the mileage won't have changed
(it *may* allow you to increase the mileage, i haven't tested that)
Old 12-11-2012, 12:11 AM   #1217
hassmaschine
My Ride: '91 325ix
you can change it to 6mt and turn on the CSL oil level in NCSexpert but AFAIK you need a CSL coded DME to match it for the readout to work.
you can't change the mileage, up or down. you'd have to desolder the chip and do it the hard way.
Old 12-12-2012, 01:47 AM   #1218
fire730
My Ride: 01 325iT - 04 Burb
Wasted an hour of my life and I can't figure out why this thing still says the adapter isn't plugged in. Any ideas? Removed and reinstalled the program 3 times and it still tells me the same thing.
2001 325iT.
Thanks for any help.
01 325iT ZSP - Koni - Hotchkis - Stoptech
01 525iT - TiAg - Koni - B&G
04 Chevy Suburban - SLP - BlackBear - Belltech
01 330Ci - parts car
16 Chevy Tahoe - Wife's Daily
fire730 is offline   Reply With Quote
Old 12-12-2012, 01:27 PM   #1219
spherehunter
I have selected the door locks under ZKE for some reason still not working. I'll try selecting EU and US and see if it works right now I only have US selected.
Old 12-13-2012, 12:25 PM   #1220
fire730
2001 325iT.
Anyone have any ideas??
Tried it again today and I noticed only the yellow light was working on the OBD adapter. I fiddled with the cable and the green light comes on now but it still tells me its not plugged in. What can I check? I dont have access to another Bmw and I havent really found any fixes by scanning through all these pages.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
