Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.36 average.
Old 12-24-2012, 12:43 PM   #1241
trj
My Ride: 325Ci
Originally Posted by bimer21 View Post
How can i disable my amber light when switching the on!? I just need then to blink when indicator is on thats all
If you are referring to the turn signal lights being ON with the headlights, it cannot be done with PAsoft. You will need NCS for that.
Old 12-24-2012, 12:59 PM   #1242
bimer21
My Ride: stick 325i
Yea were those and thanks for the info
bimer21 is offline   Reply With Quote
Old 12-25-2012, 02:57 AM   #1243
UDown0311
My Ride: '04 330ci ZHP
i tried using this scanner tool but i couldn't get passed the OS complications,; so i went out and bought another brand, OBDCOM.
if anyone has any experience with this PM me, maybe we can help eachother out.
UDown0311 is offline   Reply With Quote
Old 12-25-2012, 02:04 PM   #1244
fire730
My Ride: 01 325iT - 04 Burb
This tool seemed good at first but it seems like the last group of us that bought them can't get them to work.
01 325iT Sport Package Hellrot
04 Chevy Suburban - Modded - My Daily
08 Chevy Suburban - Modded - Wife's Daily
fire730 is offline   Reply With Quote
Old 12-26-2012, 08:23 PM   #1245
tommy d
My Ride: 2005 330i
I ordered mine from Xcar360 on 11/29, said it was shipped out by HK post 12/13 and still waiting for delivery.
Edit: Picked it up from the Post office today 1/2/2013, needed a signature.
Current Vehicles in my stable:
2005 BMW 330i - 94K miles
2005 Mazda Tribute s - 90K miles
1998 Ford Taurus SE - 103K miles
1987 Ford Mustang LX 5.0 - 230K miles
tommy d is offline   Reply With Quote
Old 12-29-2012, 07:21 AM   #1246
chowdarygm
My Ride: BMW 318i E46 (1998)
Scanner tool help needed
i am new to BMW. i have done lot of reading and got the scanner tool and everything setup very easily. but i am having the below problems and need your help on this. (please don't blast me like posting without reading or being noob. everybody is a noob at starting)
tool connected to car fine and gave some errors. some i was able to click on clear semi-confidentally but some i couldnt dare to. can you tell me if i can clear these errors??
also i have below problems, any help is appreciated
- even when i reprogram for optical acknowledgement when i unlock and lock, the lights are not blinking when doing the same
- i want to auto lock the car when it reaches 8kmph but the option is disabled, how to enable it?
- i am unable to reset the oil service, getting the error message "unable to reset oil service", why ?
- after first scan i was able to see 6 errors in DME module. but when i reopened the tool, the scan says that it couldn't find DME, what happened ? :O . car works fine anyhow.
Thanks for your help in advance
ID:	483849   Click image for larger version
ID:	483850   Click image for larger version
ID:	483851   Click image for larger version
ID:	483853   Click image for larger version
ID:	483854   Click image for larger version
ID:	483855   Click image for larger version
chowdarygm is offline   Reply With Quote
Old 12-29-2012, 08:09 AM   #1247
miweber929
My Ride: 02 330xi
You know that you have to connect the OBD connector to the car with the ignition on for the final drivers to load??
You may just need to go in and delete the driver and try to reinstall just the driver?
Originally Posted by tjyak50 View Post
Using some driver trickery I got it to work on a w7 PC, but on the next try it failed.
On my XP laptop i loaded and it failed, reloaded and used a different USB port and it succeeded and repeated.
Concur with the delete and reinstall following the exact instructions and using the S/W that came with the gizmo.
Originally Posted by miweber929 View Post
Swear I did that but I will try again.
Re-did the complete setup, had the car on for the driver install and still nothing, same errors that it can't find the IKE and DME modules. XCar offered me to send it back (after a ton of confusing emails) but I'm trying to decide if its even worth it. Took almost a full month to get here, figure 2 months to get the repaired unit back.....
Any other lower priced options that might actually work?
miweber929 is offline   Reply With Quote
Old 12-29-2012, 04:40 PM   #1248
shovelit
My Ride: 03 325xi
You need to check the box at the top right that says "DWA".
Then check the optical confirmation boxes.
It needs to "think" the car is equipped with the factory alarm.
shovelit is offline   Reply With Quote
Old 12-29-2012, 06:01 PM   #1249
tech4tech
My Ride: e46, 325i
>> how to enable it?
Basically this setting is "per key", so you need to check-mark "after starting key 1 through 4", *then* select the desired speed it will lock at.
tech4tech is offline   Reply With Quote
Old 01-02-2013, 12:34 PM   #1250
chowdarygm
>> how to enable it?
thank you...will try that and let you know if it worked.........
any help with the oil reset ?
Old 01-02-2013, 02:41 PM   #1251
tech4tech
My Ride: e46, 325i
I haven't tried the oil reset with PA Soft, but yeah, the software is buggy and doesn't always work. For example, I couldn't clear the codes history (inactive codes) from some of the modules.
BTW, oil service reset is really easy to do manually:
http://forum.e46fanatics.com/showthread.php?t=331
Old 01-02-2013, 02:43 PM   #1252
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
What you're referring to are probably engineering codes which cannot be cleared.
Stiggles is offline   Reply With Quote
Old 01-05-2013, 11:28 AM   #1253
tech4tech
My Ride: e46, 325i
These are non-active codes from the code history marked in yellow. On some modules they erase just fine, but some do not. For example, I had my car on a dyno for smog test, which set off the wheel speed sensor codes. I cannot erase these non-active "yellow" codes with PA Soft -- they are just sitting there in code history. Same for the ABS code.
Old 01-06-2013, 09:35 AM   #1254
jmejiaa
My Ride: 2002 M3
Can I disable rear bulb out errors with this?
jmejiaa is offline   Reply With Quote
Old 01-06-2013, 09:48 AM   #1255
shovelit
My Ride: 03 325xi
Yes.
Old 01-06-2013, 09:50 AM   #1256
jmejiaa
My Ride: 2002 M3
Yes.
Thanks, I'm having issues and I might just disable them instead of messing with resistors.
Pretty tought for the LED's to really die on me anyway I would assume.
Old 01-06-2013, 10:02 AM   #1257
shovelit
My Ride: 03 325xi
You may have to disable the cold and hot bulb checks for LED's. Not sure though.
Old 01-06-2013, 12:34 PM   #1258
Marinerd
My Ride: 09 328i
Yes. You just have to disable the cold check on it. I just put mine up for sale HERE and I used it for exactly the same thing your trying to do. It works fine, just don't have the car anymore.
Marinerd is offline   Reply With Quote
Old 01-06-2013, 02:39 PM   #1259
jmejiaa
My Ride: 2002 M3
Thanks, I actually bought the adapter a while back, just haven't used it much.
Old 01-10-2013, 09:13 AM   #1260
katajama
My Ride: E46 Coupe
I just received my BMW Scanner 1.4 from HK and I have promblem with it
I installed it and everything went well.. drivers etc found. Software starts but it wont find my E46. I connected adapter to my dashboard.
"Scan" donīt find anything
When I opened adapter, connected PINS are:
1
4&5 (together)
7&8 (together)
16
Any ideas? Any help?
katajama is offline   Reply With Quote
bmw scanner, diagnostic tool, error message, pa soft
Rate This Thread
