Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.36 average.
Old 01-10-2013, 11:57 AM   #1261
e46beater
My Ride: 00 328i
Originally Posted by fire730 View Post
This tool seemed good at first but it seems like the last group of us that bought them can't get them to work.
I agree, mine seems to be pinned correctly, connects to the car but has no access.
e46beater is offline   Reply With Quote
Old 01-10-2013, 01:21 PM   #1262
BavarianBorn
My Ride: 2005 3.30i ZHP
Originally Posted by miweber929 View Post
Re-did the complete setup, had the car on for the driver install and still nothing, same errors that it can't find the IKE and DME modules. XCar offered me to send it back (after a ton of confusing emails) but I'm trying to decide if its even worth it. Took almost a full month to get here, figure 2 months to get the repaired unit back.....
Any other lower priced options that might actually work?
Hi MIweber,
I am having the same problem. I bought mine from newegg (looks exactly the same as XCAR). I just started a thread on it as well.
I have accessed and cleared errors perfectly in all other modules, but DME not found.
I have soldered pin 7+8, which did not help. I am considering trying another software, but apparently I need another cable as well. INPA is the top of the list.
Also hoping to try my scanner on a co-workers 02 to see if DME scans.
Please keep posted on any progress and I will do the same.
BavarianBorn is offline   Reply With Quote
Old 01-10-2013, 04:00 PM   #1263
trentcdrums
My Ride: BMW 323i Sedan
Originally Posted by BavarianBorn View Post
Hi MIweber,
Are you Hooking up from under the hood?
Old 01-10-2013, 09:10 PM   #1264
BavarianBorn
Mine is a 2005 and I believe there is no connection under the hood if you are referring to the round 20 pin.
Old 01-14-2013, 04:15 PM   #1265
canelane
My Ride: 04 330ci
Cant beleive I just read every page. ac_2007 for all his patience and help. And to everyone who has helped as well.
People....read, read, read. The same questions have been asked so many times it rediculous. Yes it will work with windows7.....LOL Ten bucks someone will ask that qestion in the the next 20 posts...
I was trying to find if there was a manual for everything this does. Quite a few asked but I never saw it. I hope I didnt miss a page (there are 64 of them).
Xcar360, since you are a sponsor, do you have or will you put out a manual? Im sure most all of us would like one.
By the way....what is the best oil to use......LOL
canelane is offline   Reply With Quote
Old 01-14-2013, 04:17 PM   #1266
e46beater
My Ride: 00 328i
I wish I could just get mine to connect
Old 01-15-2013, 12:03 PM   #1267
katajama
My Ride: E46 Coupe
Originally Posted by katajama View Post
I just received my BMW Scanner 1.4 from HK and I have promblem with it
I installed it and everything went well.. drivers etc found. Software starts but it wont find my E46. I connected adapter to my dashboard.
"Scan" donīt find anything
When I opened adapter, connected PINS are:
1
4&5 (together)
7&8 (together)
16
Any ideas? Any help?
Anyone?!?
katajama is offline   Reply With Quote
Old 01-15-2013, 12:08 PM   #1268
trentcdrums
Anyone?!?
You need to connect under the hood
Old 01-15-2013, 12:25 PM   #1269
TRIPLE_O
My Ride: E46 Coupe
What year is your car? Do you have the round adapter under the hood?
Anyone?!?
Do you have the round adapter under the hood? If so, use that one.
________________________________________
BMW Coding, PM Me For Details
3 Series Owners Manuals
http://www.bmwsections.com/docs/3series/
For Sale (Exterior Lights)
_________________________________________
Originally Posted by gonzaga707 View Post
My boyfriend left on vacation and left me his 95 328i for me to use while he is gone. He had 2 keys, I lost both of them this week...
..sincerely Jenny
TRIPLE_O is offline   Reply With Quote
Old 01-15-2013, 05:24 PM   #1270
fire730
My Ride: 01 325iT - 04 Burb
i wish i could just get mine to connect
^this^
01 325iT Sport Package Hellrot
04 Chevy Suburban - Modded - My Daily
08 Chevy Suburban - Modded - Wife's Daily
fire730 is offline   Reply With Quote
Old 01-15-2013, 08:53 PM   #1271
wildirish317
My Ride: 2004 325Ci vert
When I run the scan, my car identification results are:
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008 HW: V14rFeG Time: 6:19:33 PM 1/15/2013
FA coding : /-------- IKE --------\ /-------- LCM --------\
Chassis : E46 E46
Model : 323ci 323ci
Type key : BW33 BW33
Engine : M54B25 M54B25
Gearbox : Manual Manual
VIN : PG97515 PG97515
Time criterion : 0903 0903
Paint code : 0430 0430
Upholstery code : N6HC N6HC
FA-stream : 024194139545BF8B74D3 024194139545BF8B74D3
4144D0B96A2341041041 4144D0B96A2341041041
04104104104104104104 04104104104104104104
1042118E149141249649 1042118E149141249649
46525554A38535544D86 46525554A38535544D86
145115156545D3518455 145115156545D3518455
4905524554D455541651 4905524554D455541651
05945565505964565D45 05945565505964565D45
994976156124D84D2614 994976156124D84D2614
55855361759949565948 55855361759949565948
00 00
My issue is that it identifies my car as a 323. I have a 2004 325iC convertible. What gives?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
wildirish317 is online now   Reply With Quote
Old 01-16-2013, 12:51 AM   #1272
katajama
My Ride: E46 Coupe
No I don't have
Old 01-16-2013, 12:00 PM   #1273
canelane
My Ride: 04 330ci
Katajama, if your car is left hand drive, look under the dash next to the trunk release/hood release. There should be a rectangular cover over the obdII port. Pull down on the cover and plug in the scan tool.
OR....type in BMW OBD port location on google and use the image tab.....
Old 01-16-2013, 12:45 PM   #1274
katajama
My Ride: E46 Coupe
well... Thats not problem. I sure can find obd connector under the dash, but the problem is that bmw scanner can't find car at all. Connector is connected but software cant find anything with scan.
Old 01-16-2013, 01:00 PM   #1275
trj
My Ride: 325Ci
What Operating system are you using?
Is your problem, the computer not finding the car or computer not finding the scanner? The computer should give you an indication of USB device connected when you connect the scanner to the car and and turn the car ON.
Also, does the light on the scanner turn ON when you connect to the OBD port? The lights are there but may be covered with the BMW scanner sticker. Just peel it a little and check. The lights should turn RED when you connect the scanner to the port, and Green when its doing some work(I believe).
You might have a OBD port issue or the scanner itself is not working, or the USB cable is defective.
Try any other OBD scanner on the port to see if you can read anything. That will isolate the issue, whether its a OBD port issue or scanner issue.
Also, check the fuses. Not sure about e46 but other cars do have OBD port fuse. So, make sure your OBD port is getting proper power by checking the fuses.
If you car is 01+ there will not be a round connector under the hood.
I am running bmw scanner on macbook with xp loaded on parallels. When I connect the scanner to the car, I get a pop up whether I want to use the device with xp or mac, I choose xp and I get the USB device notification on the system tray on the XP.
Old 01-19-2013, 05:16 PM   #1276
DA
My Ride: Z4 e85
I just read the entire thread
I want a cookie
to sum up:
Yes it will run on windows7 32 bit (64bit sure after a lot of dicking)
You can't turn off cel coming from deleted secondary air pump
No it will not do a EU flash
you can reset dme adaptations
pins 1+2 and 7+8 need to be soldered on what ever unit you buy
It's Ilegal to brake the law
It will not run crysis
it will pass emissions
your errors are your own
This thread sums up everything
http://forum.e46fanatics.com/showthr...613&highlight=_nr_
DA is offline   Reply With Quote
Old 01-21-2013, 10:54 AM   #1277
glacket
My Ride: 2002 BMW 330i
I am having the same issue but i cannot connect to the LCM. But i am wondering if there might be an actual problem.I just purchased the bmw scanner from new egg as well. the same one pictured above. It was not finding hardly any modules. i was able to find almost everything by sodering the 7+8 pins together but i still cannot connect to the LCM. I tested this with the same results on windows 8,7 and xp. The IKE is giving a data filing difference error to the LCM. Is it a logical assumption that there could be an actual connection problem with the LCM module and thats why i cannot connect with it and thats why the IKE has the error because it sees null values from the LCM that obviously wouldnt match the DATA on the IKE?
IKE -> BE/C8 - Data-filing difference to central light module (LCM)
BF/C8 - Internal fault, EEPROM checksum, coding incorrect/incomplete
glacket is offline   Reply With Quote
Old 01-21-2013, 06:43 PM   #1278
fire730
I've never gotten a red light on the scanner when it was connected to my OBD port. Only 2 green lights. And I have hooked other scanners to the port and they worked fine so I know the car isn't the problem. I guess I need to try a new USB cable and check to see if pins 7 + 8 are soldered together.
Old 01-22-2013, 02:35 PM   #1279
brodaiga
My Ride: 330ci Supercharged
help!
I have wasted 2 hours trying to make this work. All drivers were installed fine. No matter what I do it says "hardware not ready error." Also, it shows the unit as connected when i plug into the computer (green light). When I then plug into the car, light instantly turns yellow and shows as unit is not connected with "hardware not ready" error. Software was installed on Windows xp machine. I have a peake code reader as well and it connects fine. bought from xcar360
wtf
brodaiga is offline   Reply With Quote
Old 01-22-2013, 03:10 PM   #1280
brodaiga
are the lights supposed to be illuminated on the scanner?
bmw scanner, diagnostic tool, error message, pa soft
Rate This Thread
