Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 01-22-2013, 11:53 PM   #1281
Hovs13
My Ride: E46 325ci
Originally Posted by brodaiga View Post
I have wasted 2 hours trying to make this work. All drivers were installed fine. No matter what I do it says "hardware not ready error." Also, it shows the unit as connected when i plug into the computer (green light). When I then plug into the car, light instantly turns yellow and shows as unit is not connected with "hardware not ready" error. Software was installed on Windows xp machine. I have a peake code reader as well and it connects fine. bought from xcar360
wtf
The same happened to me. To resolve i disconnect the scanner from the obd port and reconnect it. Sometimes you have to do this multiple times and you may also have to disconnect and reconnect the usb cable from computer. Seems like its a physical connection issue with the pins.
One you get it working however, when i run the vehicle identification scan i get a FA read error and the scan stops. So far no fix for me. I can run a manual scan of all systems and reprogram features, but for whatever reason the vehicle ident feature fails for me.
Hovs13 is offline   Reply With Quote
Old 01-22-2013, 11:58 PM   #1282
soul rebel
My Ride: E46 M3 Cabrio
Originally Posted by tock172 View Post
I was checking up on my LCM coding and did some experiments. I enabled my US DRLs (the main objective of me plugging PA-Soft into my car), but I also wanted to see what the other options did. I check EU DRLs and the US/EU running lights, but nothing changed. Any ideas?
I checked us/eu box and now all my lights are permanently on while the car is running, even the dash lights. US running lights will enable the high beams at 50% while the car is running... Not sure what the EU Drl does...
Sent from my HTC One XL using Bimmer App
soul rebel is offline   Reply With Quote
Old 01-24-2013, 12:27 PM   #1283
nicoaraalex
My Ride: BMW e46 316i
Hello! I am new to the forum, I just bought a BMW Scanner from ebay, plugged in my BMW 316i e46 (05/1999) and the main reason I bought it is to enable cornering lights (sidemarker_us aktiv - in NCS Expert), but I only have 2 options DLR EU and DLR US, none of them do nothing. Any ideas?
nicoaraalex is offline   Reply With Quote
Old 01-24-2013, 05:06 PM   #1284
mikeetastic
My Ride: lots of 3
noob here with a few Q's..
1: is Xcar still the best place to purchase this?
2: my airbag light can fix (?) by this tool right?
3: i have the square key remote (car is 99), can i program it to open all doors (not just driver) with a single click? pretty annoying for me to press 2X to open all doors..
TIA..
mikeetastic is offline   Reply With Quote
Old 01-24-2013, 06:58 PM   #1285
jcoleman
My Ride: 2004 BMW 330Ci
I own a 2004 BMW 330Ci (E46)... I am looking into getting this... Will this work in my BMW? Will I need to do any modifications? Or will I need to know anything special?
http://www.ebay.com/itm/251177039033
jcoleman is offline   Reply With Quote
Old 02-03-2013, 02:54 PM   #1286
nicoaraalex
I have LCM coding index 28 (e46 316i 1998), is it possible to activate USA Style Cornering using PASoft? And if it is, what do I need to activate?
Old 02-06-2013, 11:59 AM   #1287
wildirish317
My Ride: 2004 325Ci vert
This is not the tool you are looking for. This tool is much more sophisticated and will probably result in you "bricking" your DME or some other controller, which will cost $$$$ to replace.
PA Soft is here: http://www.ebay.com/itm/BMW-Scanner-...item1e76ad8c62
Shop around. I got mine for less than $40, including shipping. PA Soft allows you to change some settings, and you probably won't get into trouble using it. I use it mainly to check and clear SEL codes.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-06-2013, 12:11 PM   #1288
mikeetastic
My Ride: lots of 3
^^ this is cheaper (i think)..
http://www.ebay.com/itm/BMW-Scanner-...c1662f&vxp=mtr
Old 02-06-2013, 12:12 PM   #1289
e46beater
My Ride: N63 F10
Originally Posted by mikeetastic View Post
That's the one i purchased and cannot get to work.
e46beater is offline   Reply With Quote
Old 02-06-2013, 12:15 PM   #1290
wildirish317
Yeah, it's a pain to get it working. I had to restart my computer, go into the setup, and disable the driver signature recognition function. Once I did that, it loaded the drivers and everything works fine.
Old 02-06-2013, 12:16 PM   #1291
e46beater
My Ride: N63 F10
Originally Posted by e46beater View Post
Guys and Gals I just purchased one of these and get the IKE and EWS connection errors. I have a 2000 328i and using the 20 pin connector. I have tried two different laptops and have had the car even on a battery charger with no luck. My pinout seems different from most shown on the site.
7 and 8 are soldered and so are 4 and 5. I have nothing connected to 1 and 2.
Build date is 2011-10-21
8+7 soldered 6 individually connected and 5+4 soldered
Blurry but right to left this shows 16 15 and 14 with individual connections
My issue
Old 02-06-2013, 12:17 PM   #1292
nicoaraalex
^^my issue also
Old 02-06-2013, 12:17 PM   #1293
mikeetastic
My Ride: lots of 3
file a claim (eBay buyer protection) so you'll get your money back..
or you probably just windows drivers..
Old 02-06-2013, 12:18 PM   #1294
e46beater
My Ride: N63 F10
Originally Posted by nicoaraalex View Post
^^my issue also
Woot not crazy then.
Old 02-06-2013, 12:18 PM   #1295
mikeetastic
My Ride: lots of 3
see
Old 02-06-2013, 12:19 PM   #1296
e46beater
My Ride: N63 F10
see
My machines recognize the device is connected and so does PA software... but I'll try anything once lol
Old 02-06-2013, 12:19 PM   #1297
nicoaraalex
It rarely works, only sees IKE LCM EWS and SRS, but after I write something ,it stops working, the next day, works again, cheap chineese crap (I think?!)
Old 02-06-2013, 05:01 PM   #1298
Redflea
My Ride: 2005 330Ci/2003 530i
Can you step-by-step this out? Not sure what you mean by "go into the setup and disable the driver signature recognition function." Which setup, and where did you disable the driver recognition? Thanks...I have one arriving in a bit and I want to be prepared.
Redflea is offline   Reply With Quote
Old 02-06-2013, 05:50 PM   #1299
e46beater
My Ride: N63 F10
From ehow.com
Windows XP
1
Open the Start menu and right-click on "My Computer." Select "Properties."
2
Click on the "Hardware" tab and select "Driver Signing."
3
Select "Ignore -- Install the software anyway and don't ask for my approval."
4
Select "Make this action the system default" and press "OK."
5
Reboot the computer.
Windows Vista
6
Open the Start menu and select "All programs."
7
Navigate to "Accessories" and right-click on "Command Prompt."
8
Select "Run as Administrator."
9
Type "bcdedit.exe /set nointegritychecks ON" in the black window and press "Enter."
10
Windows 7
11
Click on the "Windows" and "R" keys at the same time to open the "Run" box.
12
Type "gpedit.msc" in the Run box and press "Enter."
13
Navigate to "User Configuration," "Administrative Templates," "System," "Driver Installation" on the left pane.
14
Double-click on "Code Signing for Device Drivers" and select "Enabled" in the main part of the window and "Ignore" in the drop-down menu in the "Options" section.
15
Click "Apply," then "OK" and reboot the computer.
Read more: How to Disable Signed Driver Checks | eHow.com http://www.ehow.com/how_7310470_disa...#ixzz2KA6H3kLn
Old 02-07-2013, 11:58 AM   #1300
Redflea
From ehow.com
Windows XP
1
2
Thanks!
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
