Rating:
#1301 | |
#1302 |
#1303 | |
![]() Sent from my Galaxy Nexus using Bimmer App Last edited by Redflea; 02-07-2013 at 11:32 AM. |
#1304 |
PA Soft Error Codes
I have found that 5A-D could indicate that the 02 sensors need to be replaced, however does anyone know what code 34 [52] Solenoid valve, exhaust flap, short circuit to negative or open circuit is? I cant seem to find anything on this.
#1305 |
#1306 | |
Sent from my Galaxy Nexus using Bimmer App |
#1307 |
#1308 |
#1309 |
Anyone want to sell a BMW Scanner 1.4.0 interface? If so please PM me. Thanks
#1310 |
Anyone here programming on a car w/an aftermarket radio?
#1311 |
I wish this would allow me to use the second set of headlights...the halogen ones ....to work with the brights.....I hear they do in eu
#1312 |
WOOT!
Finally got my wire from xcar360... I was skeptical at first because I couldn't get the tracking number and then even though it said it was shipped, it was actually waiting for them to package it, but nevertheless, they sent me an e-mail saying not to worry and that normal shipping takes 2-3 weeks so I waited patiently. I configured my computer to run on XP even though I didn't realise that you are able to run it on Win7 light edition or something (pos anyways) while waiting. Ran through the steps as guided (TURN OFF YOUR INTERNET); first installed the disc through advanced options, la la... just following instructions!! Then ran downstairs, jumped inside my car, plugged the wire in, turned off my internet again, ignition on, program loaded.. and scanned it.. BOOM! It works I did NOT have to solder anything or whatever, I guess that issue was fixed and now they are sending out normal, working, without modifications cables... so i'm happy!~ I guess I'll go play around and see what everything means from now on and re read the thread all over again for any tips I've missed! |
#1313 |
Great to hear. Mine is on the way from Xcar, hopefully it will be here soon.
#1314 |
I got mine about 2 weeks ago from xcarGO, it is the newest scanner with cables already soldered, It didn't work in the beginning, it couldn't detect the car and was only able to find 2 modules.
i ordered the 20pin round adapter to hook up the scanner yesterday and it worked like a charm. Turned off my DRL, activated alarm, auto doorlock and one click window roll up. ONCE AGAIN, IF YOU HAVE AN OLDER CAR LIKE 1999-2002, YOU NEED TO USE THE 20 PIN ROUND ADAPTER ONCE AGAIN, IF YOU HAVE AN OLDER CAR LIKE 1999-2002, YOU NEED TO USE THE 20 PIN ROUND ADAPTER ONCE AGAIN, IF YOU HAVE AN OLDER CAR LIKE 1999-2002, YOU NEED TO USE THE 20 PIN ROUND ADAPTER |
#1315 |
It's here!
It works (no soldering)! Happy so far. But have some questions... It arrived today, earlier than expected (ordered on Feb 4). Installed on Win XP laptop, no issues (disabled driver signing). Programmed my car (e39) as first test - enable relock if don't open doors within 2 minutes of unlocking and that worked fine. Then programmed my wife's car (2005 330Ci vert) to enable alarm/tilt sensor I installed recently, and a few other things. But...I can't find (in ZKE, where I expected it to be) settings to move the seats to memory location when unlocking the car. The attached document indicates it is a supported feature on the e46. Anyone know the module where it can be found? Also...anyone w/a 330ci vert want to post their ZKE screen - interested if they are the same. And I captured screens showing all the modules I could scan, this is w/key in position 2. Are more possible w/this scanner? Will I see all I can see w/the key in position 2, or do I have to use both position 1 and position 2 to see the maximum? Thanks! Last edited by Redflea; 02-24-2013 at 01:04 PM. |
#1316 |
just ordered mine with a 20 pin adapter, once it comes in, itll be time to read every page lol
#1317 | |
#1318 |
I didnt know about this function. I will check out mine. Im guessing you tried looking in the Seat Memory Function SMF? If you find it, please post it. Its been a while since I had the scanner hooked up, not sure if I could even get the SMF function.
#1319 | |
I was expecting to find that in ZKE since it's where all the other automatic setting stuff related to unlocking the car is, but looks like I was wrong about that. EDIT: I just checked and when I open the seat memory modules, key in position 1 or 2, they do not provide the "Recoding" button required to get into the settings. So for some reason that is locked out for me. Last edited by Redflea; 02-24-2013 at 10:32 AM. |
#1320 |
I also wanted to know more about the error codes I got on my windows...see attached.
My mechanic diagnosed a problem w/my passenger window not consistently going all the way up as a programming issue, and performed a window reset (basically something like put the window all the way down and hold the button down, put it all the way up and hold the button up). I got the car back and the second time I tried the window it did the same behavior as before going into the shop...put it all the way down, it goes up almost half way then reverses and stops about 1/3 way up. It did that twice in a row. Since then I haven't been able to get it to fail again, but am going to keep trying it. In any case, do the error codes in the attachment indicate that this is a mechanical/part issue, rather than a programming issue? Thanks! |
| Tags |
| bmw scanner, diagnostic tool, error message, pa soft |
| Rate This Thread | |
