Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 03-02-2013, 09:28 PM   #1341
wildirish317
My Ride: 2004 325Ci vert
Originally Posted by Aedion View Post
do i need to replace my pre and post cat O2 sensors?
No. When these go, they will give you an O2 sensor fault that will not stay cleared. Your DME codes are in the "Shadow Memory". My experience is that these can be ignored.
Too many people freak out when they run the scan and get a few (or a bunch) of errors. Then they start buying and replacing parts. I've had my check engine light come on, and then go off again before I can get home to run a scan.
Use the scanner as a tool, not an advisor. If you get a code, and you notice no difference in the way your car drives, clear the code and see if it comes back. If something is really needing attention, you will probably notice a change in performance. Then the code will point you in the right direction.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-04-2013, 12:21 AM   #1342
spacemaster
My Ride: E46 328i
Yes. I search and searched...
Does anyone know what these codes and what I need to check and replace.
DME -> Shadow-memory:
85/08 - Signal, CAN ASC 3
23/12 - Activation, relay, secondary-air pump
3E/12 - Activation, solenoid valve, secondary air
7E/12 - Activation, solenoid valve, tank-leak diagnosis pump
7F/02 - Activation, solenoid valve, suction-jet pump
Thanks in advance...
spacemaster is offline   Reply With Quote
Old 03-04-2013, 12:21 AM   #1343
spacemaster
My Ride: E46 328i
Old 03-04-2013, 12:42 AM   #1344
Akonion
My Ride: Mercedes C230
Just ordered one of these for about $34 canadian in anticipation for when I sell my merc for an E46.
Do I need any specific hardware to run this? Was thinking of buying a decently powered netbook (or Win7 Tablet) to be a dedicated BMW diagnostic computer.
2007 W203 C230 Kompressor <---- SOON TO BE RID OF
2006 E46 330Ci or R171 SLK <---- MUST ACQUIRE
Akonion is offline   Reply With Quote
Old 03-04-2013, 02:43 AM   #1345
travie46
My Ride: 02 325i
Same problem here !
I don't know what is wrong because my scanner was working with no issues, the last time that i used the scanner was 2 weeks ago and today show me connection error with IKE & EWS. Last week I installed angel eyes but i don't think it's the problem with the errors. any idea ??
What happens in Vegas, stays in Vegas
travie46 is offline   Reply With Quote
Old 03-04-2013, 11:55 AM   #1346
trj
My Ride: 325Ci
If you want to buy a netbook and make it a BMW diagnostic computer, I'd say buy a used one with windows xp 32 bit.
This will not only support BMW scanner but also, INPA, DSS, Winfpk and all.
Old 03-04-2013, 11:57 AM   #1347
scarede46er
My Ride: 2001 BMW 325i ZSP
They are shadow codes used to track a car's history. Do not worry about them.
Old 03-04-2013, 11:57 AM   #1348
scarede46er
Originally Posted by travie46 View Post
Same problem here !
Does the same to me. The only solution is to unplug and replug the scanner multiple times before it begins reading it.
Old 03-04-2013, 12:08 PM   #1349
SHOoff11
My Ride: 1999 Lexus LS400
Is there any way to remove the speed governor? I'm not planning on doing it, but I just wondered if this software was capable of that.
Originally Posted by SPDSKTR
You drive a BMW. That means you make $600,000 a year and date supermodels without pointy elbows or hairy arms. Need I say more?
2001 BMW 330ci vert 5-MT Steel Grey/Tannin Red
1993 BMW 325i 5-MT Black/Tan
2010 Chevrolet Silverado 2500HD Z71 Summit White/Black
SHOoff11 is offline   Reply With Quote
Old 03-04-2013, 12:11 PM   #1350
scarede46er
Not with this software.
Old 03-04-2013, 12:12 PM   #1351
SHOoff11
Thanks for the reply
Old 03-04-2013, 01:32 PM   #1352
gselsidi
My Ride: 2005 325i M56
Can I use a dcan cable with pa soft?
gselsidi is offline   Reply With Quote
Old 03-04-2013, 07:52 PM   #1353
travie46
My Ride: 02 325i
I gave up. I uninstalled and reinstalled the software and same errors, looks like the scanner is not plugged but it shows the orange light, pin 7 & 8 are soldered together. Like i said before scanner was working.
--Looking for someone in vegas to try their scanner in my car--
Old 03-04-2013, 11:28 PM   #1354
frocake22
My Ride: 2002 330ci
I bought my scanner off xcar last October and it worked at that time and went to go use it again a couple weeks ago and when connected it keeps saying "hardware not ready" I've tried installing software on another pc running xp And same problem. Anyone have a solution?
frocake22 is offline   Reply With Quote
Old 03-04-2013, 11:55 PM   #1355
travie46
My Ride: 02 325i
You will need to plug the usb with the scanner ( no plugged to the car ) your computer has to detected the usb/scanner and install the drivers )
Old 03-05-2013, 02:07 AM   #1356
Akonion
Brilliant, thanks for the input.
Good ol' IBM thinkpad with an SSD swap = perfect utility laptop!
Old 03-05-2013, 05:35 AM   #1357
spacemaster
My Ride: E46 328i
Really ? But I can't clear them.
Old 03-06-2013, 01:49 AM   #1358
anton2718
My Ride: 2001 325i
alright so i got LED corners but i cant get them to work cuz i dont have a hot check option, ive done my friends cars and they had a cold/hot check option but mine just has cold check, is there a way to make the led's not throw an error?
anton2718 is offline   Reply With Quote
Old 03-06-2013, 02:01 AM   #1359
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
Anyone interested in a scanner 1.4? Pm me
tnhl1989 is offline   Reply With Quote
Old 03-06-2013, 02:01 AM   #1360
anton2718
My Ride: 2001 325i
or is there a way to go from the first screenshot (my menu) to the second one which most other bimmers ive connected to seem to have, or is there another menu i can go to to make my LED corner lights error free
ID:	494053   Click image for larger version
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
