*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread - Page 70 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 03-21-2013, 10:22 AM   #1381
E46-Cabrio
My Ride: E46 330CI Cabrio
Originally Posted by Kanji View Post
Hi Guys, for couple of days i am trying to code my wifes 325CIC for comfort features by dashsoft 4 in 1 unit using bmw scanner software. I did everything i wanted except for the auto folding mirror, this mirror area is greyed out so i cannot choose anything. myt car has memory seats electric folding with button feature. But i am very tired of reading forums and couldnt get a solution for that. please help. thx in advance
Well, if you can't code it with pasoft then you need to use NCS Expert.
E46-Cabrio is offline   Reply With Quote
Old 03-21-2013, 02:15 PM   #1382
rekreb
My Ride: Bmw 323i touring
I have a 2000 e46. I just purchased 1.4.0 scanner. I am running windows 7 32bit. I have installed the drivers and software correctly but whenever i plug it to the car i am getting "connection error with ike" problem. I have read about it some say you need to bridge pins 7and8 which I checked it was already bridged and some say any model under 2001 need 20pin plug because you need to plug it the one under the hood not the one under the dashboard . i am really confused .Please direct me.
rekreb is offline   Reply With Quote
Old 03-21-2013, 11:21 PM   #1383
E46-Cabrio
Originally Posted by rekreb View Post
I have a 2000 e46. any model under 2001 need 20pin plug because you need to plug it the one under the hood not the one under the dashboard .
Yes that's correct, if you have the 20-pin plug then use it to read all the modules.
Old 03-22-2013, 01:12 AM   #1384
rekreb
I can actually scan and read the error codes from under the dashboard even thought I get " connection error with ike" so to adjust the features of the car I need to get rid of the error code I believe where I need 20 pin plug right?
Old 03-22-2013, 01:13 AM   #1385
TerraPhantm
My Ride: M3 & ZHP
The dashboard connector will only give you access to the DME and EGS. Any other module will not respond.
20-pin will give you access to all modules.
Old 03-22-2013, 03:09 AM   #1386
rekreb
thank you
Old 03-22-2013, 11:22 AM   #1387
pppham
My Ride: 740il S500 330CiC
One of my key suddenly can not start the car (01 330 vert) after I play around with PAsoft. Is it possible the software (could be my stupid A%%) deactivated the key in EWS? Weird thing is - the one can not start the car can and will start the car within 10s of my other key after starting the car.
Got the key fix. It now crank the car. I did follow AC 2007 recommendations. Thanks
pppham is offline   Reply With Quote
Old 03-22-2013, 11:30 AM   #1388
pppham
Hi AC 2007/Terraphantm - any of you recode/reprogramming EWS using PAsoft?
Old 03-22-2013, 03:14 PM   #1389
Kanji
My Ride: mustang gt
Thx friend, i will try the ncs, i hope i dont mess up
Kanji is offline   Reply With Quote
Old 03-22-2013, 10:31 PM   #1390
Joshwa1234
My Ride: 2003 330I Sedan
Help
If anybody could tell me what these mean that would be great as I have no clue... and possibly how to fix it. Thanks in advance.
Name:	auc sensor.jpg
ID:	496653   Click image for larger version
Name:	error pa soft.jpg
Joshwa1234 is offline   Reply With Quote
Old 03-23-2013, 08:40 AM   #1391
trentcdrums
My Ride: BMW 323i Sedan
That windows 7?
Old 03-23-2013, 10:16 AM   #1392
Joshwa1234
Yes it is windows 7......
Old 03-23-2013, 12:21 PM   #1393
trentcdrums
Anyone know if it will work with windows 98
Old 03-23-2013, 01:29 PM   #1394
Guest021715
Account closed.
What exactly are you trying to do? You can change around a few features which are available from the options list, however you cannot change the software version of the unit itself.
This is the AUC sensor, it decides when the outside air is too dirty for you to breathe and recirculates cabin air:
There is a foam-like sponge inside of it which needs to be cleaned/replaced. Search threads made by "dmax", he has a step by step DIY regarding the fix.
Old 03-23-2013, 03:49 PM   #1395
Joshwa1234
Nice that takes care of the one what about the other AIC sensor still not coded yet?
Old 03-23-2013, 05:00 PM   #1396
E46-Cabrio
That's your rainsensor (Automatic Interval Control)
Maybe you need to code it with ncs expert/sss/dis.
Old 03-23-2013, 05:40 PM   #1397
Joshwa1234
Uh huh my windshield wipers work as in slow themselves down and speed themselves up and start when there is water on it so I have no clue now lol
Old 03-24-2013, 03:37 PM   #1398
ShootyzGruve
My Ride: 2003 325i
I Just used my scanner for the first time to try and disable the comfort feature on my windows. This faulted during a rain storm overnight and I came outside to a fully opened car that now has soaked carpets. Anyhow, I was able to disable the comfort feature via Key Fob, but no option came up to disable the mechanical lock action of the comfort feature. Im seeing screenshots of peoples software and the Comfort feature via mechanical lock shows up as an option. For what its worth I was not able to access most modules besides ZKE and maybe a couple others. Any idea why the mechanical lock route for comfort feature doesnt show up?
Thanks!
ShootyzGruve is offline   Reply With Quote
Old 03-27-2013, 04:44 PM   #1399
jM2.me
My Ride: BMW
If someone could upload their EEPRom for sunroof module (sedan), I will be very thankful. Only with PA Soft I was able to figure out why sunroof had issues and died on me.
jM2.me is offline   Reply With Quote
Old 03-28-2013, 08:38 AM   #1400
Gasturbine
My Ride: 2005 330ci Cabrio
Will ship my scanner for you to use.
Most of us want to make one change, or otherwise make changes that are permanent. At least I did.
So I was thinking...since my scanner just sits in my garage, I would be willing to ship it to another forum member...you can make your changes, then ship it back...all you do is pay for shipping.
Heck, if we can get a few people interested, we can arrange it to be shipped directly to the next member.
You will need to PM with your real contact/mailing info, and a phone number I can call to confirm.
Would include the BMW scanner w/ Pa Soft 1.4.0 & cable, as shown below.
What do you think?
Gasturbine is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
