Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 04-09-2013, 02:01 PM   #1421
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Originally Posted by pppham View Post
Hi jaymemaurice, connected under the hood for my 740.
Okay, then check the round cable's female pins to make sure they are not spread too far open. Loose females haha.
Especially pin 15, 18 and 20
http://forum.e46fanatics.com/showpos...64&postcount=7
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 04-09-2013, 02:12 PM   #1422
unclebob12
My Ride: '02 330ci
Originally Posted by Daerve View Post
It's almost certainly why it won't work. Find the fault that keeps blowing the fuse.
When I plugged the scanner on yesterday I was getting a oil level sensor error. Fuse 30 is also associated with that sensor. Could that be why it keeps blowing?
unclebob12 is offline   Reply With Quote
Old 04-09-2013, 02:12 PM   #1423
pppham
My Ride: 740il S500 330CiC
jaymemaurice, at first I thought it was pin connection. However, I connected to my 01 330 CiC, I can get to the live data in DME and also it found my SRS (using USB - OBD connector). I did checked into the the 20 pins end to make sure and no soldeingr for those pin inside were lose.
pppham is offline   Reply With Quote
Old 04-10-2013, 08:16 AM   #1424
unclebob12
My Ride: '02 330ci
I just changed the fuse while the car was running. Now the fuse does not blow anymore but my BC button still does not work.... What cant it be?!?!? I'm getting frustrated now...
Old 04-10-2013, 05:27 PM   #1425
unclebob12
My Ride: '02 330ci
I GIVE UP!!!!! First I fixed fuse issue. It does not blow anymore. I pulled every fuse and they are ALL good. I overnighted a BRAND NEW shift lever with the B/C option just in case it was that. I plugged in the bmw scanner from pa soft and unchecked the on board computer box. Installed the the stalk/lever. RE-coded the car by checking the on board computer, and it STILL does not work. All i see is the time and nothing else. If i unplug the outside temp sensor, the outside temp comes up where the time was. I cannot go back to the time unless i reset the cluster with the software. WTF is going on??
Anyway someone PLEASE HELP!
Old 04-11-2013, 05:07 AM   #1426
jasonatx
My Ride: 2001 325i
has anyone used this to swap from a m54b25 to a m54b30, if so which menu option was selected or changed? tia
jasonatx is offline   Reply With Quote
Old 04-12-2013, 09:09 AM   #1427
flyinraven
My Ride: E46 323i
Desperate! IKE EWS connection error!
Hi,
Thank you all for all the tips offered on this forum. I have just received my scanner. I tried to use it on my 2000 323i round port (OBD I) and all I got was just the same old ike and ews connection error, and no modules were found. I trawled through so many pages in this forum and other forums over the last few days to no avail. My cars does not have the OBD II port.
1. I learnt that there is no need to solder 7&8 as i'm using the OBD I port under the hood.
2. I did attach the scanner to the cable that connects to the OBD I port.
3. I have the drivers installed on Windows 7 Home Premium (following another forum's tips) and the software is showing that the drivers are alright.
4. I even tried plugging in before starting software, after starting software, unplugging and replugging a zillion times... to no avail
I am wondering if it is the scanner's wiring issue as it is so different from the others. I'm out of options. Please help.....
flyinraven is offline   Reply With Quote
Old 04-12-2013, 09:32 AM   #1428
unclebob12
My Ride: '02 330ci
Originally Posted by flyinraven View Post
Hi,
It's located under the driver's dash on the left, to the right of the hood release latch.
Old 04-12-2013, 10:02 AM   #1429
flyinraven
My Ride: E46 323i
I did check the whole area, to no avail. Only the OBD I port is existent under the hood. I think in Australia they don't have the OBD II being enforced in legislation since 1996 and thus they did not make it a definite fixture till mid/ late 2000. My car was manufactured in early 2000 .
Old 04-12-2013, 10:11 AM   #1430
unclebob12
My Ride: '02 330ci
Okay then your out of luck.
So let me get this straight, you can open the software without no "Hardware Not Ready" message, read the car but no modules are showing up?
Old 04-12-2013, 10:21 AM   #1431
SUHLeen
My Ride: 2005 Saleen Mustang
Originally Posted by SUHLeen View Post
On my menu for light coding, it only shows Cold Check, I don't see Hot Check like most people's lighting menu. I'm doing this to avoid the flickering with my LED bulbs. Also, my DME does not show up (this is because the pins are not soldered, I'm assuming), could that be the same reason for the hot/cold check?
Bump....
- Phil
11 335is - TT 7 spd DCT daily :)
05 Saleen Mustang - forged, stroked, blown,... and on some juice
01 BMW 330ci - Totaled by some bish!
Financial Help
SUHLeen is offline   Reply With Quote
Old 04-12-2013, 10:23 AM   #1432
flyinraven
My Ride: E46 323i
Yes, drivers and hardware in the greens, clicked "continue" then "Car ident" or "Scan" brought up 2 windows, "Connection error with IKE" and "Connection error with EWS". The 3 pages just indicated all modules "not found". I hope there can be a solution....
Old 04-13-2013, 06:11 AM   #1433
flyinraven
My Ride: E46 323i
I have found the solution. Just solder pins 7 & 8 no matter what was said elsewhere in the forum. After that it worked perfectly. Credit to the people at bmwclubmalaysia.
Old 04-14-2013, 08:00 PM   #1434
clarkson23
My Ride: 325i
Can the scanner program keys?
clarkson23 is offline   Reply With Quote
Old 04-14-2013, 08:40 PM   #1435
haurelio
My Ride: 2001 bmw 325i
no, it can however apply settings to the keys that are already programed
Contact me if you need to unlock your phone.
Also can code your car
Old 04-14-2013, 08:42 PM   #1436
clarkson23
My Ride: 325i
How would I get the key programmed?
Old 04-14-2013, 09:39 PM   #1437
jM2.me
My Ride: BMW
I might be slightly wrong here, but ews has 5 key codes pre-programmed. When you order a key from bmw they program it with un-used key code. Then they enable the key in EWS, which I think you can do with PA Soft.
jM2.me is offline   Reply With Quote
Old 04-17-2013, 06:21 PM   #1438
danf01
My Ride: 2004 325i
Just FYI, we have an enterprising individual in town using the auto parts area of craigslist
to do BMW recoding. He charges $40 min.
danf01 is offline   Reply With Quote
Old 04-17-2013, 06:21 PM   #1439
danf01
My Ride: 2004 325i
Old 04-23-2013, 07:30 PM   #1440
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Would anyone be willing to email me a copy of the cd? My laptop died and I cant find my cd. I still have the cable though. I just got a M3 and I moved my alarm from the 330 so it would be nice to have. Thanks.
Sent from my SCH-I605 using Bimmer App
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
