Thread Tools Search this Thread Rating: Thread Rating: 435 votes, 4.97 average.
Old 05-15-2013, 11:42 AM   #1481
lszlszx
My Ride: 1.8T, XC70
Originally Posted by El Polo View Post
Completely different things, but can do many common things. The INPA suite is way more advanced and way less user-friendly. It is BMWs standard tool and can do pretty much everything, including breaking stuff if you are not careful.
Thanks for the info! Sounds like I am better off with the 1.4 and maybe upgrade to the INPA once I have more experience.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-15-2013, 11:01 PM   #1482
turbotalon1g
My Ride: '02 330i
anyone?
The disks sent to me were damaged.
Also I was thinking if we could make this a sticky and maybe update the first post with all the important and basic information about this software and it's uses.
turbotalon1g is offline   Reply With Quote
Old 05-15-2013, 11:01 PM   #1483
turbotalon1g
My Ride: '02 330i
Scratch that the seller emailed me a torrent link
Old 05-17-2013, 02:16 PM   #1484
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Originally Posted by TerraPhantm View Post
It's all codable stuff. My M3 flashes its highbeams and corners when the alarm is going off
I have the option selected and it doesn't. Same with my friends m3.
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 05-17-2013, 02:20 PM   #1485
Guest021715
Account closed.
Post a screenshot of your options checkbox.
May require a prerequisite to activate.
Old 05-20-2013, 12:12 PM   #1486
Punto GT
My Ride: E46, E87, Punto GT
Hi guys,
on my e46 I activated the DRL through the scanner 1.4 and using other software (NavCoder) I turn on the headlights soft while driving without headlights.
I've done this on several e46, but now I have problems with a e46 2001, the DRL active U.S. scanner, but the lights do not come on ....
you think it is a problem of different LCM (not arranged) on the two cars?
this is the result on my e46
This is the screen when I log on to my LCM and those prepared for DRL
http://forum.e46fanatics.com/attachm...4&d=1362553293
instead this screen when I log on to the LCM e46 2001
http://forum.e46fanatics.com/attachm...3&d=1362553175
sorry for my english
Punto GT is offline   Reply With Quote
Old 05-20-2013, 12:12 PM   #1487
Punto GT
Hi guys,
Old 05-20-2013, 12:20 PM   #1488
Guest021715
Account closed.
^ Two different version of the program.
Check both EU and US Daytime running lights options and see if it works.
A European-spec LCM will sometimes not have the DRL option altogether.
My 2001 cannot have the DRLs activated because I switched to European LCM version.
Old 05-20-2013, 12:33 PM   #1489
Punto GT
thanks, I'll try!
Updating the firmware of LCM or replacing it with a newer one could solve?
Old 05-20-2013, 12:37 PM   #1490
Guest021715
Account closed.
Originally Posted by Punto GT View Post
thanks, I'll try!
You have to change to US version of LCM most likely.
Try checking both DRL boxes using PA Soft first though.
Old 05-20-2013, 12:43 PM   #1491
Punto GT
I'm sorry, can you explain how to do well?
Old 05-20-2013, 12:46 PM   #1492
Guest021715
Account closed.
Ask terraphantm, he helped me.
Old 05-21-2013, 10:06 AM   #1493
vbfronkis
My Ride: 2001 325iT
Can someone explain this gearbox difference on my car? IKE (correctly) reads manual while the EWS reads automatic. Can I change EWS to match without issue?
Name:	Screen Shot 2013-05-20 at 1.32.06 PM.png
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 05-21-2013, 11:54 AM   #1494
vbfronkis
My Ride: 2001 325iT
Originally Posted by Stiggles View Post
As for the "Automatic", your car is a US model which has the clutch safety switch (you have to push in the clutch to start the engine). This for some reason is categorized with the automatic transmission in the EWS. The feature can be disabled and the reading would come up as "manual". I don't recommend getting rid of the feature for obvious safety reasons.
Nevermind. Trolling through this massive thread and found my reason why EWS says automatic.
2001 325iT, manual
Old 05-21-2013, 01:52 PM   #1495
David McMahon
My Ride: '99 E38 740iL
Ordered mine from xcar360 today with the 20-pin cable for my '98. Looking forward to it and am going to "read until I puke!" Is there a good place start to start reading?
David McMahon is offline   Reply With Quote
Old 05-21-2013, 01:58 PM   #1496
vbfronkis
My Ride: 2001 325iT
Unfortunately most of the thread is about not being able to get the software working, not realizing the ODC module receives power from the vehicle and not the USB cable, and not being able to find their options because they're idiots. I've been through 45 pages so far and really the only posts I pay attention to are ones with screenshots as I skim.
2001 325iT, manual
Old 05-21-2013, 02:01 PM   #1497
David McMahon
Ok, I'll take my time and learn up on it, no panic (yet) as car is working thankfully.
Old 05-21-2013, 02:23 PM   #1498
vbfronkis
My Ride: 2001 325iT
You looking to do something specific? I've just learned up a whole bunch and can help out. I just recoded a bunch of stuff on my car.
2001 325iT, manual
Old 05-21-2013, 02:27 PM   #1499
David McMahon
99% health of the car at least at first, (codes etc) then possibly use it to code options such as windows going up when I press lock (sometimes works, sometimes not)
Old 05-21-2013, 02:39 PM   #1500
vbfronkis
My Ride: 2001 325iT
Ok cool. The health bit is easy. Plug it in, let it scan fully. It'll take a minute or two to go through your car's systems. Simply, if the scan comes back green, great. No errors. If it's yellow, it's an error that was there but isn't presently. Some errors will stick like that forever, may take time to clear, or you can clear it manually with the software and they'll be gone. Don't be surprised if some stick after clearing it. I think it's just how BMW's done the software so that some of the more important codes never fully clear and you have a history of the car.
Red. The bad stuff. These are things you should look at pretty closely. I'd had a sensor or two reporting low voltage. I also had scanned when my car ignition was turned to 'on' but without the engine running. After scanning again with the engine running I got some better results. So I've now taken to scanning/coding with the car on. (Also because the battery with drain if the engine's not on, limiting your coding session.) Having scanned with the engine turned over, it looks like I've got a sensor or two that need addressing.
On to the fun stuff. This is where you should wing through the thread and just look for screenshots. Those posts will help you figure out how to program the windows up/down from the remote, flashing the corners when you lock, changing your locks from selective to one push, euro double-blink hazards etc. Keep in mind that a lot of these options can look different than the screenshots due to differences in software.
Also, I notice your 98 E46 in your info. You're going to likely have fewer programming options for lighting than newer E46s.
Good luck!
2001 325iT, manual
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
