Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 06-07-2013, 06:17 PM   #1541
David McMahon
My Ride: '99 E38 740iL
Originally Posted by e46beater View Post
Well back to square one.. PA says everything is working under settings as far as the adapter being plugged in. Plug into car, then usb to laptop... run PA soft..wait for ignition prompt... turn key on wait about 10 seconds and get no IKE or EWS connections.
plugged into the 328i and get the same thing... uninstalled driver and same issue.. both cars on 4 amp charger while attempting..
I bet you probably have but disconnect the charger and connect car as normal then try, other than that I don't know especially as your other car seems to fail PA soft too.
David McMahon is offline   Reply With Quote
Old 06-08-2013, 10:46 AM   #1542
e46beater
My Ride: N63 F10
Trying it again today.. I'm thinking the scanner went bad
e46beater is offline   Reply With Quote
Old 06-08-2013, 02:34 PM   #1543
kwake330xi
My Ride: 03 330xi
*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Trying to run pa soft on windows 7 32bit. I get this
when I plug in the cable to USB Bad cable??
kwake330xi is offline   Reply With Quote
Old 06-08-2013, 02:51 PM   #1544
e46beater
My Ride: N63 F10
Attachment 509971
I gave up using anything but XP.
FYI mines working again.. its intermittent but at least its coming up again.
Old 06-08-2013, 03:20 PM   #1545
David McMahon
Attachment 509971
Check cable and socket, also if you can try a test build of XP, Vista or 7 (32) no need to activate, just needs chipset drivers (normally Intel or AMD) and the driver that came with the scanner.
Old 06-08-2013, 03:21 PM   #1546
David McMahon
At least that's something, perhaps try to narrow it down some more, I would be careful using it while intermittent as you may get half way though a write
Old 06-08-2013, 03:54 PM   #1547
kwake330xi
My Ride: 03 330xi
Can you explain the "test build" a little more? A little over my head with this driver update, etc
Old 06-08-2013, 04:45 PM   #1548
David McMahon
Sorry, what I mean is to get a spare HDD and install a "test" build of XP, ie put in a temporary HDD and a temporary install of XP.
You just need enough drivers to get the cable working.
The whole point is to rule out your existing computers Software load causing the problem.
Old 06-15-2013, 11:03 PM   #1549
effay
My Ride: 323Ci
I plan to order this on friday, is he software compatible with windows 7? I'm mainly interested in little things like my lights flash on lock and unlock, my windows roll up when x2press of lock function. and the clown nose flash when car is locked. maybe little things down the road like door locking at 30mph. but you get the idea.
I plan to order from fleabay. I just want to know if its compatible with windows 7 before I commit to buy, Thanks.
effay is offline   Reply With Quote
Old 06-15-2013, 11:03 PM   #1550
effay
My Ride: 323Ci
double post.
Old 06-16-2013, 06:42 AM   #1551
kenhale13
My Ride: '02 bmw 325xi
@effay u need to do some special things to make it compatible with windows 7, it can be done, do some more searching first cause i dont remember off hand, it involved manually installing the driver i do remember that.
kenhale13 is offline   Reply With Quote
Old 06-16-2013, 08:55 AM   #1552
Foxtrot_Uniform
My Ride: 325Xi
I have installed this on numerous laptop builds of both XP and W7 with only one issue... I messed up the first time I installed it! I wasn't paying attention to the fact that you CANNOT be connected to a Wi-Fi network when it is installed. I had to delete the installation and then reinstall it with the Wi-Fi turned off. When I did that... No issues.
Foxtrot_Uniform is offline   Reply With Quote
Old 06-16-2013, 01:20 PM   #1553
megraham
My Ride: 2001 BMW 325i
Just got my scanner yesterday. Got it to work with windows 7 64 bit and had a few errors. Does anyone see any major problems with the data?
I found very good instructions on getting it to work with windows 7 and took me about 45 minutes but works great. Now I just have to make some changes once I figure it all out.
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
EWS -> 6.905.670 03 08 2 errors
ABS* -> 6.750.364 04 0.0.0 3 errors
LEW -> 6.760.232 04 04 2 errors
A/C -> 6.914.009 24 06 1 error
SRS -> 6.905.491 01 06 no errors
IKE -> 6.906.897 10 20 1 error
LCM -> 6.907.950 10 20 no errors / 10 errors
ZKE -> 6.907.663 11 16 4 errors / 2 errors
MFL -> 0.000.000 01 09 no data
RAD -> 6.909.882 32 11 no errors
SZM -> 6.911.667 01 02 no errors / no errors
SHD -> 3.852.379 05 27 no errors
SPMFT -> 8.386.427 02 01 1 error / 3 errors
SPMBT -> 6.913.364 02 02 no errors / 3 errors
SMF -> 8.263.133 07 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
EWS -> 33/05 - Toleration of changing code increased, key 3
0F/3F - Power on reset
ABS* -> 5E43/C0 - Steering angle sensor internal.
5DF4/40 - Vehicle power < 9 Volt.
5E1A/C0 - CAN DME/DDE Signal Error.
LEW -> 09/79 - No CAN message (ASC)
04/21 - 90 degrees difference of wiper too large (Adjustment operation)
A/C -> 1C/04 - AUC sensor
IKE -> D7/81 - Tank sensor 2
LCM -> Shadow-memory:
34/11 - Brake light, left
35/03 - Brake light, right
36/04 - Turn indicator, front left
37/11 - Turn indicator, front right
3B/02 - Sidelight, rear left
3D/01 - Sidelight, rear right
3F/1F - Turn indicator, rear left
40/04 - Turn indicator, rear right
41/03 - Low beam, right
42/02 - Low beam, left
ZKE -> 27/3F - Central locking system Relay Locking Driver's door: Contact for opening has open circuit or Contact for closing is sticking
3D/01 - Central locking system: Short circuit or Open circuit at Motor Tailgate
38/02 - Wiper: Pump for Window washing or Container is empty
0A/01 - Power window: Open circuit Motor or Relay Passenger door
Shadow-memory:
90/23 - Battery Voltage: Open circuit
95/02 - Repeat blocking: Power window
SPMFT -> 04/01 - Mirror-moving-switch, interruption
Shadow-memory:
00/01 - Low voltage ( U < 8,5 Volt )
02/8B - Low voltage mirror-heating
04/01 - Mirror drive, potentiometer plausibility
SPMBT -> Shadow-memory:
02/61 - Low voltage mirror-heating
# SCAN END
The LCM is showing a lot of light issues but all of them work. What exactly is shadow memory that is listed?
megraham is offline   Reply With Quote
Old 06-16-2013, 02:58 PM   #1554
David McMahon
never mind
Old 06-16-2013, 05:43 PM   #1555
Foxtrot_Uniform
My Ride: 325Xi
The way it was explained to me was that the shadow memory items are things that wouldn't be picked up by a regular BMW shop scan. The PA Soft scanner picks them up though... I wouldn't worry about shadow memory.
Old 06-16-2013, 06:19 PM   #1556
Guest021715
Account closed.
Shadow memories are old errors that have not, or cannot be cleared from the system, I would note all of these Errors down (you have here!) and clear them, the ones that come back are the ones to look at, but keep the old ones as history.
Indeed I believe BMW has shadow memories to maintain a history of the car.
You're making things up.
Shadow codes are errors which have been registered at one point, but are not currently active. There are also a small portion of engineering codes which cannot be cleared because they don't apply to your car.
Ex.) Exhaust flap solenoid shadow code can't be cleared on my car because I don't have one.
Old 06-16-2013, 08:07 PM   #1557
David McMahon
Information was correct, best of my knowledge and after reading on this forum.
Trust me, I'd never "make up" something on a car forum, but if I did it would be something along the lines of "omg look at my new M3"
Old 06-16-2013, 08:14 PM   #1558
effay
My Ride: 323Ci
Thank you Kenhale, my laptop has windows 7 only so I was hoping it would work!
and bigrick when your using PA soft after you install you must have WIFI on though right|?
Old 06-16-2013, 09:46 PM   #1559
Guest021715
Account closed.
I misread your wording, my mistake.
Shadow (yellow) codes which come back after clearing all codes are engineering codes. Active (red) codes cannot be cleared until the problem is fixed, such as the airbag.
Old 06-16-2013, 09:56 PM   #1560
David McMahon
I'm going to have a look again tomorrow, fantastic tool.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
