Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 06-25-2013, 02:01 PM   #1581
Augster
My Ride: 2008 335i Sport
I'm not sure if Windows XP suffers this same issue, but for me, when I disconnect then reconnect the tool under Win7, I have to exit then relaunch BWM Scanner otherwise it would always complain the "Hardware not ready."
It's rather slow to scan your system.
You have to double-click on the line of the system you wish to examine in more detail (e.g. "DME" or "EGS"), which opens up another window. In that window, you usually then click on the ERRORS button to get to see the error codes and their descriptions (if you can make sense of them).
I wish there was an EXPORT option so you could save the list of error codes in at least a simple text file, if not a CSV (Comma Separated Values) text file, that could then be manipulated or imported into Excel; even a PRINT option would suffice.
Augster is offline   Reply With Quote
Old 06-25-2013, 02:08 PM   #1582
saace7
My Ride: is for chicks
Originally Posted by BB BMW View Post
Yeah...there is so much in the thread, it's hard to find exactly what I'm looking for. It would probably take an hour or more to read it all.
Just looking for some streamlined answers.
start reading then. . .
saace7 is offline   Reply With Quote
Old 06-25-2013, 02:10 PM   #1583
jfoj
My Ride: 330CiC, M5, X5, E93
Likely the speed of the cars hardware and buss??
As I recall PA Soft/BMW Scanner actually stores logs each time iti s used. I cannot recall where the default is, however, you should be able to navigate from the C drive to the PA Soft/BMW Scanner folder and find the logs which are saved in a .txt file format.
Answers in bold.
Old 06-25-2013, 02:11 PM   #1584
BB BMW
My Ride: 04 330ci ZHP
Haaaaa....
I guess you do not have one of these scanners.
But thanks for you input.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
Thomas Jefferson
BB BMW is offline   Reply With Quote
Old 06-25-2013, 02:22 PM   #1585
Augster
Answers in bold.
I will look for those logs... tanks!
Old 06-25-2013, 02:28 PM   #1586
WDE46
My Ride: '13 128i, '04 330Ci
+1
And I do have one of these. I got it up and working under Win7 64 bit with nothing but Google and that thread.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 06-25-2013, 02:38 PM   #1587
BB BMW
Originally Posted by WDE46 View Post
+1
and you don't want to share any suggestions?
Thomas Jefferson
Old 06-25-2013, 02:39 PM   #1588
lmr2wil
My Ride: '00 328Ci
I just received the BMW Scanner 1.4.0. I will be installing it on my laptop running Windows XP.
I would appreciate input from others who have this scanner and what they have done and/or problems they have run in to.
I understand that this software can really cause problems if you don't know what you're doing. To prevent myself from doing this, I would like opinions and suggestions on exactly how to read and reset codes. My CEL light is on due to my CAI filter coming off while driving on a rough stretch of road. I want to reset the codes so the light goes off.
I also understand that there is a problem with running the car battery down.
I've read a lot of info about this scanner, but there is Soooooo much to read, I would just like opinions and suggestions on how to use this to reset codes and maybe reset some default settings like the lights and windows.
You don't get to be cautious and lazy - pick one. I also have one of these scanners. They're not hard to use - but it's worth spending the hour reading a thread to know their capabilities/limitations.
Luke
lmr2wil is offline   Reply With Quote
Old 06-25-2013, 02:41 PM   #1589
trj
My Ride: 325Ci
All you need is to clear the codes?
Here:
Plug in the scanner
Turn the car to Position II
Start the scanner program
Click DME
Click Scan
Click Clear
Exit the program.
Old 06-25-2013, 02:45 PM   #1590
BB BMW
Luke
I am cautious but not lazy.
I am planning on reading everything I can find on this scanner. Didn't think it would hurt to ask others, things they had learned or mistakes made.
Here:
Plug in the scanner
Click DME
Click Scan
Click Clear
Exit the program.
Kinda what I was asking too.
Thomas Jefferson
Old 06-25-2013, 05:22 PM   #1591
lmr2wil
My Ride: '00 328Ci
Of course it doesn't hurt to ask... and I'm not trying to be an ass. I'm only suggesting that the long threads, although long, contain lots of useful info toward what you're hoping for. Another thread that I found quite useful toward this is http://forum.e46fanatics.com/showthread.php?t=935613.
Luke
Old 06-25-2013, 05:43 PM   #1592
Foxtrot_Uniform
My Ride: 325Xi
OP... You WILL want to read through that thread. There is a ton of good info. Yes, it will take a while but it will be worth it!
Foxtrot_Uniform is offline   Reply With Quote
Old 06-25-2013, 09:21 PM   #1593
faber
My Ride: 2003 325 Cic
Just posting a "me too!" to subscribe to this thread (is that how I do it?).
I bought the scanner siftware and hardware a few weeks back. The guy I bought it from told me of some of the cool things I could do with it (have the clown nose flash, flash the headlights when locking/unlocking, have the locks lock at 5 mph, etc.) but I've gone through the codes in the Bentley book and can't figure out which flags to un/set.
Off to spend an hour or two reading the suggested threads...
faber
My first, but not my last.
faber is offline   Reply With Quote
Old 06-26-2013, 09:47 AM   #1594
Drexellake
My Ride: 05 330ci Convertible
I have this and was able to program to close my convertible top with the key fob. But the windows don't roll up.
Does anybody have a fix for this?
Drexellake is offline   Reply With Quote
Old 06-26-2013, 01:10 PM   #1595
BB BMW
Luke
Thanks...
Just thought I'd ask some members that use this, what they have done and/or problems that they ran into. I guess there is no "Cliff Notes" here.
Thomas Jefferson
Old 06-26-2013, 02:38 PM   #1596
Wes van v
My Ride: BMW 318ti
Hi guys I have read through probably 65 of the pages on here I now have a busting headache lol and are resorting to asking for help.
I have this tool and the software that comes with it
http://www.ebay.com/itm/BMW-USB-OBD-...item3a7f4d88ea
I have a park light error after installing aftermarket angel eye rings and wiring them up to replace the parks. Obviously it now throws the error as the resistance of the original parks were more than the angels. I need to code out the park bulb check. Where do I find that? I have looked but am at a point where I'm scared to do anything as I can't find what I need to do. I am honestly sorry if this is somewhere in this forum but i feel like if i get pointed in the right direction I could figure it out.
Anyone else done this before with NCS Expert?
Wes van v is offline   Reply With Quote
Old 06-29-2013, 03:25 AM   #1597
sillieidiot
My Ride: '06 AW 330ci
Originally Posted by megraham View Post
Any issues known using the scanner with an 06 325. It works great on my 2001 but I hooked it up to the 2006 and a window came up stating to turn on the ignition then it wouldn't hook up to the car.
Is there actually a step by step on the order of starting the scanner.
We had it plugged in then the laptop was started and the ignition was turned on but couldn't get it to hook up with the car.
I assume that the 2006 is still an E46. Am I correct?
Any step by step instructions on starting the scanner?
it depends. is it a 325ci? if it's the sedan, then no, since its an e90. if it's a coupe, then it should work fine.
Old 06-29-2013, 10:28 AM   #1598
BB BMW
Here:
Plug in the scanner
Click DME
Click Scan
Click Clear
Exit the program.
OK, I tried that. The DME shows as not found.
I did the scan and found only SRS with a read error.
Nothing to clear. I didn
t get that option.
Thomas Jefferson
Old 06-29-2013, 10:57 AM   #1599
trj
My Ride: 325Ci
Just Received my BMW Scanner 1.4.0 - PA Soft
You might want to check if the pins are soldered. I don't know the PIN numbers. Check that thread. There are people who had the same issue.
Old 06-29-2013, 11:21 AM   #1600
jfoj
Post a picture of the OBD port end of the cable.
Where did you purchase this and how much did you pay for it?
Post a link to the product, this would be helpful.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
