*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread - Page 83 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 07-05-2013, 12:11 PM   #1641
ti317
My Ride: 02 330ci coupe 5 spd
Originally Posted by matt0 View Post
This is the current one I'm using, works fine.
http://www.ebay.com.au/itm/ELM327-Bl...884ecc7&_uhb=1
Thanks but didn't realize you were in Australia. Thanks anyway, it is apparently Chinese so I can probably find it in the U.S.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 07-05-2013, 08:53 PM   #1642
trialNerror
My Ride: '03 M3
64 bit installation
For those of you having difficulties installing PA soft on 64 bit machines, the instructions at the following link worked like a charm for me on Vista: http://forum.e46fanatics.com/showthread.php?t=942966
trialNerror is offline   Reply With Quote
Old 07-05-2013, 08:59 PM   #1643
trialNerror
My Ride: '03 M3
Headlights on with alarm?
I've read that some are able to have their headlights flash when the alarm is activated. Can someone point me in the right direction? I've tried selecting low and high beams in the ZKE5 module to no avail. My indicator lights flash, but I can't get the headlights to flash. Thanks in advance for any guidance.
Old 07-05-2013, 09:05 PM   #1644
Mad_Scientist
My Ride: '04 325Ci
i just want my radio to stay on until i open the door.. dang.
Mad_Scientist is offline   Reply With Quote
Old 07-05-2013, 10:42 PM   #1645
Imanewbie
My Ride: is my crack.
I don't get why so many people have issues with these? They are all the same, as long as it can read/write. I just purchased a $4 Bluetooth one from ebay which I've been using without issue.
I will explain what you don't understand. If your car is built 6/2000 and earlier than you need an adapter for the 20 pin BMW plug under the hood. Your $4 Bluetooth adapter won't work with them. the scanners are not all the same, some have the pins soldered and some don't. Mine did not have pins 7&8 jumped and it did not work at all until I soldered them together with a 20pin to obd2 adapter plugged in under the Hood. School is over now.
Imanewbie is offline   Reply With Quote
Old 07-05-2013, 10:45 PM   #1646
Imanewbie
Also your cheap Bluetooth adapter that gives you generic codes does nothing close to what a BMW scanner will do for you.
Old 07-06-2013, 09:48 AM   #1647
matt0
My Ride: 318i n46 e46, e34 M5
I bluetooth it to my laptop and run the software which gives me all the options that are being discussed in this thread. As long as it's read/write and not just read you should be able to do the same without an issue.
matt0 is offline   Reply With Quote
Old 07-06-2013, 09:51 AM   #1648
matt0
School is over now? Really...
If your car is pre 6/2000 and has the 20 pin connector is that still running the same ODB protocols?
Old 07-06-2013, 12:46 PM   #1649
NWFLBimmer
My Ride: 01 330i / 07 M Coupe
I need some advice. I have a working copy of PA Soft 1.4. I now own a 2007 BMW M Coupe. Yesterday we installed headers on my S54. 30 miles later I got my CEL. Does anyone know if I can delete the O2 check? Or something?
NWFLBimmer is offline   Reply With Quote
Old 07-06-2013, 01:57 PM   #1650
IROCa325
My Ride: 90Z/02 525i/03 325i
Not with PA soft. Believe it's possible to do so for the post-cats with INPA or NCS but I belive the pre-cats(if you don't have them) are needed by the DME for fuel trim.
Post-cats can also be can be "fooled" with an emulator, you can read about it here: http://forum.e46fanatics.com/showthr...light=post+cat
Not sure if there is a way to get around the pre-cat sensors, maybe some else will chime in, or try a advaced search in titles ony for "Cat sensor delete" or start a new thread in the General E46 forum. I'm sure your not the only one that has delt with this, Youll be able to find help there for sure!
PS. Luv your beaches down there, we have been coming down there twice a year for over 20 years and will be back in August!
Thirty was so strange for me. I've really had to come to terms with the fact that I am now a walking and talking adult. C. S. Lewis
IROCa325 is offline   Reply With Quote
Old 07-08-2013, 05:58 AM   #1651
ti317
If you have Xenons, the lows will not flash and the highs may not flash unless you have the car programmed to turn on the halogen brights long with the Xenon high beams. I'm not sure if PA soft can program high halogens long with Bi-Xenon. I decided to stay away from it after reading all of the posts on piracy and intellectual property.
Old 07-08-2013, 06:29 AM   #1652
Foxtrot_Uniform
My Ride: 325Xi
If there was a legitimate issue with copyright they would have taken this thread down. Let's not even get into that crap again.
Foxtrot_Uniform is offline   Reply With Quote
Old 07-08-2013, 12:18 PM   #1653
Nitrius
My Ride: BMW E46 328i 2000
Hello,
Got the BMW Scanner and a 20 pin adapter, tried to connect it to my car, but got connection error with ike and ews, did some searching and it looks like am not the only one with this problem, but am not sure how to solve it, i've read a lot of people talking about soldering pin 7 and 8 together.
Anyway, here is a picture of my unit(not sure if i need to solder or not..):
Nitrius is offline   Reply With Quote
Old 07-08-2013, 12:34 PM   #1654
David McMahon
My Ride: '99 E38 740iL
Originally Posted by Nitrius View Post
Hello,
Mine worked after charging the battery overnight, also I had disconnected the battery to charge, so try that also.
David McMahon is offline   Reply With Quote
Old 07-08-2013, 02:01 PM   #1655
ti317
I dunno man, I just don't need to hassle.
Old 07-08-2013, 02:17 PM   #1656
IROCa325
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Hello,
7&8 are not bridged in your pic. I would bridge them, uninstall the re-install the program and be sure your hooked up to the obd port with the ignition in position2 b4 trying again. That's what worked 4 me and mine looks identical to your pic
Sent from my C771 using BimmerApp mobile app
Old 07-08-2013, 03:02 PM   #1657
Tgodvgreyboy
My Ride: 2001 325i
BMW 1.4 scanner, turning off DRL
Does anyone know how to turn DRL off with the scanner?
Tgodvgreyboy is offline   Reply With Quote
Old 07-08-2013, 03:29 PM   #1658
Zell
Zell's Avatar
My Ride: so turbo wow
http://bit.ly/170h9f2
Old 07-08-2013, 04:52 PM   #1659
bumere46
My Ride: E92
I don't think it can be done. I tried on my mine and it didn't work.
bumere46 is offline   Reply With Quote
Old 07-08-2013, 05:35 PM   #1660
Guest021715
Account closed.
Usually I'd yell at you.
Access the coding menu for the LCM module, and uncheck the EU & US running lights options. Top right corner.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
