Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 08-21-2013, 09:40 PM   #1741
IROCa325
My Ride: 90Z/02 525i/03 325i
Originally Posted by buguyed View Post
Has anyone ever bought or used one of these cheapo cords on amazon and downloaded the PA Soft? Or is it strictly VW applicable?
http://www.amazon.com/OBD2-Diagnosti...d_bxgy_e_img_y
And can it be opened up to solder 7 & 8 or should I buy this little gem as well?
http://www.amazon.com/Elandpower-S-E...=pd_sim_auto_4
Thanks everyone!!
NO, you must use the BMW scanner dongle for the pa-soft software to interface with car.
Originally Posted by Arirang View Post
So I tried using the virtual machine that Microsoft provides but I still get an IKE and EWS error. I was wondering if it was a problem with my soldering? Also, the green light only flashes for a quick second as I'm putting the usb in and doesn't stay on.
Soldering appears correct... are you using the 20 port under the hood and the 20 to 16 pin adapter?? I believe you'll need it for your 2000 E46, if you don't have one you can use a jumper to work around it. See this thread at post #20. http://forum.e46fanatics.com/showthr...hlight=pa+soft
Thirty was so strange for me. I've really had to come to terms with the fact that I am now a walking and talking adult. C. S. Lewis
IROCa325 is offline   Reply With Quote
Old 08-22-2013, 04:32 AM   #1742
Arirang
My Ride: 2000 323i
Thanks! I'll give that a try and see if it works. I've been seeing people reporting to use the 20 pin obd but I thought I didn't have one until I found it today haha
Arirang is offline   Reply With Quote
Old 08-22-2013, 07:07 AM   #1743
nicoaraalex
My Ride: BMW e46 316i
This may help, see below:
Thanks a lot m8, I also have read that they can only be cleared with special BMW Scanners, like the ones they're using at the dealer, GT1 and stuff, but they don't bother me.
nicoaraalex is offline   Reply With Quote
Old 08-22-2013, 04:25 PM   #1744
Nitrius
My Ride: BMW E46 328i 2000
Originally Posted by Nitrius View Post
Hello,
Got the BMW Scanner and a 20 pin adapter, tried to connect it to my car, but got connection error with ike and ews, did some searching and it looks like am not the only one with this problem, but am not sure how to solve it, i've read a lot of people talking about soldering pin 7 and 8 together.
Anyway, here is a picture of my unit(not sure if i need to solder or not..):
Got it working. After not thinking about the device for a while, i decided to try to solder together pin 7&8 as i've read some place, and that worked, finally!
Nitrius is offline   Reply With Quote
Old 08-27-2013, 11:53 AM   #1745
nicoaraalex
Found an error code at DME (171, check fuel supply system). I've cleared it and after 30 kilometers or something it appears again. Any thoughts? Car is been running fine, except for slight idle variation 850 +/- 50-100 rpms. MAF sensor was changed a month ago with a brand new BOSCH.
Old 08-27-2013, 11:53 AM   #1746
nicoaraalex
Found an error code at DME (171, check fuel supply system). I've cleared it and after 30 kilometers or something it appears again. Any thoughts? Car is been running fine, except for slight idle variation 850 +/- 50-100 rpms. MAF sensor was changed a month ago with a brand new BOSCH. Anybody knows why my Check engine light doesn't light up at all, except when i do a cluster test?
Old 08-27-2013, 12:06 PM   #1747
Brad W
My Ride: 2003 330ci
nicoaraalex - I can't answer your question, but I have a sub question to your issue.
For anyone that knows, when looking at the screenshot from nicoaraalex - how do you translate the codes you see there to the codes index found in the service manual and all over the internet (the Pxxxx codes)
thanks
ZPP, ZSP, ZCW
Brad W is offline   Reply With Quote
Old 08-27-2013, 12:08 PM   #1748
nicoaraalex
thanks
It's AB [171], on the internet its P0171 or P0170, you just take the DECIMAL (171) number, not the HEX (AB).
Old 08-27-2013, 01:14 PM   #1749
Brad W
My Ride: 2003 330ci
ah, ok, that makes sense, thanks
ZPP, ZSP, ZCW
Old 08-27-2013, 09:07 PM   #1750
fire730
My Ride: 01 325iT - 04 Burb
I was never able to get mine to work. And I don't want to buy another broken scanner.
But I do want my DRLs turned off real bad.
Are people having better luck with the recent purchases of these?
01 325iT ZSP - Koni - Hotchkis - Stoptech
01 525iT - TiAg - Koni - B&G
04 Chevy Suburban - SLP - BlackBear - Belltech
01 330Ci - parts car
16 Chevy Tahoe - Wife's Daily
fire730 is offline   Reply With Quote
Old 08-27-2013, 11:01 PM   #1751
CharlzO
My Ride: 2000 328ci
Got mine recently, the cable from a fellow member (newer style), downloaded the software, and bought the 20 PIN adapter for my car. I did toy with turning the DRLs off on mine, and had no problem with it. Just decided that with my lights, I didn't like not having them on, so I left alone. But didn't seem to have any problem with it .
CharlzO is offline   Reply With Quote
Old 08-28-2013, 04:17 AM   #1752
Nitrius
Well i bought mine about 2 months ago(dx.com), and it didn't work right out of the box, i had to bridge the connection between 7&8, and after that it's been working nicely.
Btw, what is DRL?
Old 08-28-2013, 04:53 AM   #1753
David McMahon
My Ride: '99 E38 740iL
Btw, what is DRL?
DaytimeRunningLights
David McMahon is offline   Reply With Quote
Old 08-28-2013, 06:46 AM   #1754
jfoj
My Ride: 330CiC, M5, X5, E93
I do not think this works this way.
Likely far more complex to translate the PA Soft/BMW Scanner codes to generic OBDII codes.
Not many, it any of the these codes translate to standard OBD codes based on the descriptions PA Soft/BMW Scanner displays.
Old 08-29-2013, 01:08 PM   #1755
DylanFulton7
My Ride: Audi S4
*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Got mine in the mail yesterday, installed the software on the laptop (running XP) and that went fine. I plug the scanner into the OBDII port and get "Connection error with IKE". After some searching I found that I need to solder point 7 & 8, so I open the scanner up to find that they came already connected. I've done a ton of searching to come up with no definitive answer. When plugged in I am able to view live data but I can't click on "Car Ident" or get into coding any features. This is so frustrating after waiting over a month to get it and now it isn't working. Please help!!
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Supercharged 328Ci - SOLD
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
DylanFulton7 is offline   Reply With Quote
Old 08-29-2013, 01:15 PM   #1756
El Polo
My Ride: 99 black 328i
this is because you use the obd port under the steering. You have to use the 20pin round port under the hood to get access to all modules. Unless you rewire your 16pin obd port to include the missing line.
El Polo is offline   Reply With Quote
Old 08-29-2013, 01:15 PM   #1757
nicoaraalex
If it's under 2001 or 2000, you need to connect it to the 20pin connector under the hood.
Old 08-29-2013, 01:20 PM   #1758
Brad W
My Ride: 2003 330ci
hmm, you seem to be correct.
pcode p0171 is "P0171 System too Lean (Bank 1) "
ZPP, ZSP, ZCW
Old 08-29-2013, 01:25 PM   #1759
nicoaraalex
So, who is right eventually? 171 Check, fuel supply system, isn't the same with P0171? The description of it might be different.
Old 08-29-2013, 01:59 PM   #1760
Imanewbie
My Ride: is my crack.
If its pre 7/2000 you need to connect under the hood, or if you have a 20 pin under the hood at all you need to.
Imanewbie is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
