Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 08-29-2013, 02:02 PM   #1761
Imanewbie
My Ride: is my crack.
*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Originally Posted by DylanFulton7 View Post
Got mine in the mail yesterday, installed the software on the laptop (running XP) and that went fine. I plug the scanner into the OBDII port and get "Connection error with IKE". After some searching I found that I need to solder point 7 & 8, so I open the scanner up to find that they came already connected. I've done a ton of searching to come up with no definitive answer. When plugged in I am able to view live data but I can't click on "Car Ident" or get into coding any features. This is so frustrating after waiting over a month to get it and now it isn't working. Please help!!
Solder pins 1 and 2 and it will work.
Imanewbie is offline   Reply With Quote
Old 08-29-2013, 02:30 PM   #1762
DylanFulton7
My Ride: Audi S4
I'll give it a shot tomorrow morning and report back. Thanks so much for the info!
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Supercharged 328Ci - SOLD
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
DylanFulton7 is offline   Reply With Quote
Old 08-30-2013, 01:04 PM   #1763
DylanFulton7
My Ride: Audi S4
I soldered pins 1 & 2 but nothing changed, having failed that I've ordered a 20-pin round adapter. Hopefully that'll solve the problem, thanks for the help guys!
- Jeremy Clarkson
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
Old 08-30-2013, 02:02 PM   #1764
IROCa325
My Ride: 90Z/02 525i/03 325i
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Originally Posted by IROCa325 View Post
if you don't have one you can use a jumper to work around it. See this thread at post #20. http://forum.e46fanatics.com/showthr...hlight=pa+soft
If you haven't already ordered the 20 pin u can save yourself the $$ by reading the post linked in my quote above
Sent from my C771 using BimmerApp mobile app
Thirty was so strange for me. I've really had to come to terms with the fact that I am now a walking and talking adult. C. S. Lewis
IROCa325 is offline   Reply With Quote
Old 08-31-2013, 11:57 AM   #1765
DylanFulton7
My Ride: Audi S4
I've already ordered the adapter but it wasn't very expensive so it's not much of a bother. I tried jumping 20-2-17 and I can now view my car identity without any errors but I still am unable to click on "coding data" any ideas?
- Jeremy Clarkson
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
Old 08-31-2013, 12:08 PM   #1766
DylanFulton7
My Ride: Audi S4
After trying to reconnect about 10 more times I've been able to get into coding data! Finally something worked!
- Jeremy Clarkson
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
Old 09-01-2013, 11:48 PM   #1767
Chum
Chum's Avatar
My Ride: OB Facelift E46
Does anyone have instructions on how to install the BMW 1.4.0 Scanner software onto a computer running Windows 7 Home Premium?
Chum is offline   Reply With Quote
Old 09-02-2013, 12:11 AM   #1768
Foxtrot_Uniform
My Ride: 325Xi
Just install but make sure that you turn OFF your wifi during installation!
Foxtrot_Uniform is offline   Reply With Quote
Old 09-02-2013, 01:30 PM   #1769
mrmaico
My Ride: 04 ZHP, 05 R1200 GS
IIRC, this is the info that helped me get it done on my Windows 7 32 bit machine.
Post # 7........
http://forums.bimmerforums.com/forum...4#post23146094
mrmaico is offline   Reply With Quote
Old 09-03-2013, 06:27 PM   #1770
Chum
Chum's Avatar
Post # 7........
Thanks for the link mate.. Will give that a go.
Old 09-05-2013, 08:31 AM   #1771
Chum
Chum's Avatar
I got the software installed fine and hooked up the computer to the car this evening.
I get a connection error ews and ike. In addition a lot of the modules cannot be found. It does however read my vin and mileage.
I have an 03 E46. Car is hooked up to battery charger. Pins 7&8 are not soldered. Is that my problem?
Old 09-05-2013, 04:48 PM   #1772
ti317
My Ride: 02 330ci coupe 5 spd
Doesn't sound like you should need to. Check all cable connections, and try again. Reboot if necessary.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 09-06-2013, 07:38 PM   #1773
Chum
Chum's Avatar
Tried a fresh install of scanner software, rebooted system and all cable are connected fine.
Still get a connection error for ike and ews.
As stated previously, it can read my dme and a couple others. But mostly it's 'not found'.
Old 09-06-2013, 08:07 PM   #1774
IROCa325
On my 03 325i #7&8 pins had to be soldered to access those modules
Old 09-12-2013, 04:46 PM   #1775
KDML105
My Ride: 325xi
Originally Posted by zx5rider View Post
How come m3s headlights and corners don't flash when the alarm goes off? They do on my 330 but not m3.....?
Originally Posted by trialNerror View Post
I've read that some are able to have their headlights flash when the alarm is activated. Can someone point me in the right direction? I've tried selecting low and high beams in the ZKE5 module to no avail. My indicator lights flash, but I can't get the headlights to flash. Thanks in advance for any guidance.
I'm having the same issue that zx5rider, trialNerror, and some others earlier in this thread have mentioned but haven't come across any solutions in my searches. I don't have the OEM alarm on my 2003 325xi, but my clown nose flashes more rapidly when I activate the alarm by holding the trunk lid release button on the key fob so the DWA seems to be going off... just not with the headlights and warning lights, too. Is there another setting or prerequisite elsewhere that I need to activate?
Thanks in advance!
Name:	ZKE after.png
KDML105 is offline   Reply With Quote
Old 09-12-2013, 05:17 PM   #1776
TerraPhantm
My Ride: M3 & ZHP
I do not think this works this way.
Likely far more complex to translate the PA Soft/BMW Scanner codes to generic OBDII codes.
Not many, it any of the these codes translate to standard OBD codes based on the descriptions PA Soft/BMW Scanner displays.
When I get home, I can get the error table from BMW's software. I have the table for the MSS54 already, but some of the MS43 codes are different
Old 09-14-2013, 03:31 PM   #1777
nicoaraalex
My Ride: BMW e46 316i
Is there way to remove Parking light check? I have installed angel eyes and removed the park light. Here's how my LCM looks like:
nicoaraalex is offline   Reply With Quote
Old 09-14-2013, 03:58 PM   #1778
kcanete
My Ride: 2003 530I
Any one in phoenix az have pa soft I could use for 30 minutes
Any one in phoenix az have pa soft I could use for 30 minutes I would even bring a 12 pack
kcanete is offline   Reply With Quote
Old 09-18-2013, 08:42 AM   #1779
adaseb
My Ride: 2002 BMW 320i
So is this what I need?
http://www.ebay.ca/itm/BMW-Scanner-1...25af537&_uhb=1
adaseb is offline   Reply With Quote
Old 09-18-2013, 12:18 PM   #1780
mrmaico
Originally Posted by adaseb View Post
Yup. Looks like prices have been coming down some.
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
