Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 10-25-2013, 11:42 PM   #1801
bimmeupscotty
My Ride: 2000 323i
Originally Posted by JuniorT View Post
Never mind. I got it!
What was the fix?
bimmeupscotty is offline   Reply With Quote
Old 10-25-2013, 11:56 PM   #1802
bimmeupscotty
My Ride: 2000 323i
Way too many issues with these scanners. Some people on here make it seem like it wrecks their bimmer more than helps her out... is there any solid set up to use? v1.4.0 and XP seems to be the best with the least amount of issues. I wonder what it has to do with (?), and if there's certain years and models it works best on? Just kinda seems too broad for a single scanner to work on 15 years worth of models... I really wouldn't want to mess up my ECU with these Chinese pos... any feedback from a credible source on these things? I bought 1, downloaded the software bc the disc it came with wouldn't run, i plugged it in, scanned 1/20 of what it said it would, came up with missing scans, so i returned it and got my money back immediately. I even paid the $50 for the better one on eBay... yuck. Wish I could trust them and get one that would work for alarm, windows, keys, deleting codes... any advice?
Old 10-26-2013, 01:30 AM   #1803
NumbaOneNewb
My Ride: 2003 330CI Silver
Use inpa NcsExpert ediabas. Funny how that setup with a $40 kcan and dcan cable supporting every bmw obd2 compatible and if you have an ads adapter support even older ones all across the board
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 10-26-2013, 01:31 AM   #1804
NumbaOneNewb
And it was normal for majority of the modules not to show up. On e46 very few shows up beyond page 1, and it's normal
Old 10-26-2013, 11:35 PM   #1805
bimmeupscotty
My Ride: 2000 323i
so E46 wont have all the same features as newer bimmers. OK that makes sense. Know of any that ARE good for E46 year 2000? I want all the features (alarm, windows, keys, deleting codes) or as many as I can get for cheap!
Must just be the year of the vehicle? I dont remember many cars back then having many computerized features being able to program and stuff. Hell Y2K was that year lmao
Old 10-27-2013, 04:10 AM   #1806
NumbaOneNewb
*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Oh I see what's going. When you had the pa soft, were you connecting to the port under the hood? Yeah I realize you have an obd 2 port but that does not allow full access to all modules. It was there for emission testing and decorative. I am sensing you didn't because you would need the adapter cable to convert the obd2 to that other port
Old 10-30-2013, 04:51 AM   #1807
adaseb
My Ride: 2002 BMW 320i
Should I be worried about these errors
adaseb is offline   Reply With Quote
Old 10-30-2013, 04:53 AM   #1808
adaseb
I also have an aftermarket alarm and starter so i guess it explains these other errors
Old 10-30-2013, 02:28 PM   #1809
robin325ci
My Ride: Helrot 325Ci
Hi guys,
I tried scanning my car today, and all of a sudden it can't read the IKE, it gives out an error saying it can't read the ZCS FA coding data upon startup of bmw scanner. I never had this problem before. It's been months since I last used the scanner. Any idea what the cause could be? My instrument cluster works fine
robin325ci is offline   Reply With Quote
Old 10-30-2013, 02:58 PM   #1810
JuniorT
My Ride: 01 325i & 06 330 ZHP
Originally Posted by bimmeupscotty View Post
What was the fix?
I had gone into the Coding/Programming not sure which one. But I had set the mode to transport mode. I forget now but I think I set it to Passenger... Idk. I forget. But look in all the modules and see if they give you a "mode" and transport/passenger and a few others should be on there.
JuniorT is offline   Reply With Quote
Old 10-30-2013, 03:18 PM   #1811
IROCa325
My Ride: 90Z/02 525i/03 325i
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Originally Posted by robin325ci View Post
Hi guys,
Be sure your following all the steps right, plug into obd, ignition to on position, plug USB to laptop, run software. Other than that ???
Sent from my C771 using BimmerApp mobile app
Thirty was so strange for me. I've really had to come to terms with the fact that I am now a walking and talking adult. C. S. Lewis
IROCa325 is offline   Reply With Quote
Old 10-30-2013, 05:54 PM   #1812
se93
My Ride: BMW 328ci AW MTECH2
Hello to all
I picked up a BMW Scanner V1.4 off of ebay and got it a few days ago. I must say its been a nightmare. First off i started to get IKE and EWS errors and had to close the software. Then i started to get privledged instruction error messages and repeatedly. After uninstalling and doing a fresh install i get a hardware faulty message
Ebay seller said his engineering dept said i had to solder pins 7-8 of the 20 pin OBD connector Well it has 2 wires soldered and when i use it for INPA it recognizes ignition and battery and works fine
I have used about 4 different downloaded software versions and the same thing
Am i missing something or am i correct to say that this unit is defective out of the box?
Regards
Mark
Regards,
Mark Perez
se93 is offline   Reply With Quote
Old 10-30-2013, 11:59 PM   #1813
NumbaOneNewb
Are you using the pa soft installation that came with disc and not a downloaded off the internet version? Also I've noticed that if you guys have USB 3.0 it might cause issues although I have gotten it to work with it before just use an USB 2.0 port
Old 10-31-2013, 04:10 PM   #1814
Guest021715
Account closed.
Would anyone be nice enough to take a screenshot of their SRS Live Data readout?
1) Preferably with you sitting in the passenger seat, to test if the program is able to accurately detect occupancy.
2) With your driver seatbelt buckled in, again to see if the program is able to accurately detect this.
Old 10-31-2013, 04:32 PM   #1815
jM2.me
My Ride: BMW
I can assure you that program displays correct output if seatbelt is buckled in. At least it does in for my.
However, I can't say the same about passanger seat occupancy sensor because mine is long gone.
jM2.me is offline   Reply With Quote
Old 10-31-2013, 05:46 PM   #1816
Guest021715
Account closed.
Only my passenger seatbelt displays that it's plugged in.
Also purchased a Occupancy simulator for the passenger seat, and its not showing that anyone's in the seat. (it should, since it uses a resistor that signals the seat is always in use)
Old 10-31-2013, 09:33 PM   #1817
Importjunkie
My Ride: 00 Prelude
Everyone here who got the scanner from xcar360, how long did you have to wait for delivery? It's been over a month now..
Importjunkie is offline   Reply With Quote
Old 11-01-2013, 12:06 AM   #1818
jM2.me
My Ride: BMW
I got mine in under a week. However, my scanner was sent from california and I live in oregon...
Old 11-01-2013, 07:46 AM   #1819
robin325ci
Hi guys,
It turns out my bmw scanner is the culprit. Tried scanning my friend's E46 today and we encountered the same IKE ZCS FA coding data error. My scanner worked fine on his car before. It's not the software either since I used two laptops just to be sure.
Old 11-01-2013, 08:49 AM   #1820
David McMahon
My Ride: '99 E38 740iL
Yeah, same here. I'll see about getting another, I'd rather try and find a better built one from somewhere!
David McMahon is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
