Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 11-03-2013, 02:05 PM   #1821
Dilon
Banned User
My Ride: 2003.5 M3
do you use the demo version from the pa soft website? or a pirated full version of software?
Dilon is offline   Reply With Quote
Old 11-03-2013, 02:47 PM   #1822
Imanewbie
My Ride: is my crack.
*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Fatal user error.
iOS BimmerApp
Imanewbie is offline   Reply With Quote
Old 11-03-2013, 02:58 PM   #1823
Dilon
Banned User
My Ride: 2003.5 M3
Excuse me?
Old 11-03-2013, 03:05 PM   #1824
Guest021715
Account closed.
Originally Posted by ac_2007 View Post
Would anyone be nice enough to take a screenshot of their SRS Live Data readout?
1) Preferably with you sitting in the passenger seat, to test if the program is able to accurately detect occupancy.
2) With your driver seatbelt buckled in, again to see if the program is able to accurately detect this.
Bump!
Old 11-03-2013, 03:16 PM   #1825
NumbaOneNewb
My Ride: 2003 330CI Silver
I have to say I think there's a particular version out there that once it recognizes the pa soft to be a Chinese counterfeit, it causes these issues. It's either that or you have the wrong drivers and not using the right pirated software that came with the hardware.
I thought I saw somewhere on the chineses website where they said if incorrect software was being used that it would cause the numerous amounts of pop up boxes to populate among other things. You should look into that.
I also thought I saw them coming up with a solution for it by going in and deleting certain or rather all the registry information related to pa soft an redoing it all over again but this time using the right unlocked Chinese software. That's why it's important to make sure you're using either the software that came with the hardware or downloading the one from their website
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 11-03-2013, 06:04 PM   #1826
Imanewbie
^ What he said, if you got the scanner from xcar360 for example, you need to get the software from there site because the software from pasoft will not work.
Old 11-03-2013, 06:45 PM   #1827
dragondrpr
My Ride: 03 325xi
Re: after debading my 330Ci I figured I put the emblem to good use...
diagnostic tools work on safemode..or windows 32bit ...aka windows XP...I found that out by visiting a neurologist...the same should be with scanners...if I am correct
dragondrpr is offline   Reply With Quote
Old 11-06-2013, 01:46 PM   #1828
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Damn, I reformatted my laptop, tried to install it on my win 7 and it's not working. It shows that the drivers are installed, but says the scanner is not connected. Fak
Old 11-06-2013, 02:06 PM   #1829
Dilon
Banned User
My Ride: 2003.5 M3
Run it in XP COMPATIBILITY, right click go to properties and select it
Old 11-06-2013, 02:08 PM   #1830
Dilon
Banned User
My Ride: 2003.5 M3
Service pack 2 is recommended
Old 11-08-2013, 10:22 AM   #1831
BMWRoverFtw
My Ride: 05 330i ZHP, 95 RRC
I got my PA soft cable the other day and I have been able to recode my windows to go up with my key but car indent is not working and most of my options throughout the program are grayed out. Would you know why this is? I have a 05 330i 10/04 build date. Thanks in advance!
2005 330i ZHP
BMWRoverFtw is offline   Reply With Quote
Old 11-08-2013, 10:30 AM   #1832
Guest021715
Account closed.
Post screenshots.
You'll have almost nothing on the 2nd and 3rd pages, aside from maybe Xenons.
I have half of the first page, everything else is greyed out, as it should be.
Old 11-10-2013, 01:25 PM   #1833
markyaeger
My Ride: 2004 330ci
Before I go buying a scanner, I wanted to see if anyone knew if the below options are even something I can change using the scanner and software. I just bought an '04 330ci with sport pkg and my lights don't blink once and twice when locking my car. Also my AC/heater temp gauge doesn't dim with the rest of the car when using the dim dial. Any ideas?
thx!
markyaeger is offline   Reply With Quote
Old 11-10-2013, 01:25 PM   #1834
markyaeger
My Ride: 2004 330ci
thx!
Old 11-11-2013, 10:53 PM   #1835
ti317
My Ride: 02 330ci coupe 5 spd
thx!
The flashing can be set but I am not sure about the temp display but it may be a sign of electrical issues. If I remember correctly, my car did that when the final stage resistor was dying.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 11-12-2013, 12:50 AM   #1836
markyaeger
My Ride: 2004 330ci
OH no, I'm hearing about that. Not odd then that my blower is a little "up and down". Hope that's the only problem, the part is cheap. Any other electrical things to look out for/replace? Fuses, etc? The FSR is apparently notorious for going out
Old 11-17-2013, 07:54 PM   #1837
se93
My Ride: BMW 328ci AW MTECH2
Hello to all
Does anyone have a version of the bmw scanner software that is more recent than version 1.4.0.8?
I need to test a more updated version
Let me know
My email is: mpg5308@gmail.com
Regards,
Mark Perez
se93 is offline   Reply With Quote
Old 11-18-2013, 11:28 AM   #1838
MattVa
My Ride: 325ci 330ci
Issues with IKE EWS connection
See if anyone can help. 325CI 2002...I actually have 2 of them
I have the XCAR360 BMW 1.4 scanner
I get the EWS/IKE connection error and a scan finds NO Modules
I have tried installing this every way possible and on 3 different laptops
Win 7
XP SP2
XP SP3
The hardware and drivers seen to install fine, amber light on hardware indicates power. Green light flashes when PC tries to scan through hardware and interrogate modules
My OBD2 Scanner works fine on both cars.
I have tried updating drivers, searched boards, contacted Xcar360, different install methods...with unit plugged in, without unit plugged in so on and so on in every conceivable configuration
Tried different USB cables, checked adapter solder connections and pin locations as per boards---pins 4,5 7,8 etc.
I am about ready to throw this crap in the trash. I never had issues using MOATES hardware for tuning ford EEC's, sometimes issues with innovate and datalogging, but nothing like this, and its MADE in China too
Any help would be appreciated
02 BMW 325Ci 5spd x2
01 Bmw 330Ci 5spd
99 Camaro Z28 1LE
95 Mustang Cobra Dart 363 18psi Vortech
99 Corvette FRC
01 Superformance Cobra
Ultima Can-Am 355 G50/50 Yellow
Ultima Can-Am 350 G50/50 Orange
MattVa is offline   Reply With Quote
Old 11-18-2013, 01:57 PM   #1839
philliplong
My Ride: 2002 325CI
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
Win 7
XP SP2
XP SP3
I am having the exact same problem on my 2002 325ci, like exactly the same... inpa nor pa soft work with 2 different scanners.
Sent from my SAMSUNG-SGH-I317 using BimmerApp mobile app
philliplong is offline   Reply With Quote
Old 11-18-2013, 03:06 PM   #1840
MattVa
Is yours from Xcar360 also?
Let me know if you get anywhere with yours and I will reciprocate.
01 Bmw 330Ci 5spd
99 Camaro Z28 1LE
99 Corvette FRC
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
