Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 01-17-2014, 03:59 PM   #1901
mikeetastic
My Ride: lots of 3
Originally Posted by eneka View Post
After a bit of googling I found that many people had this problem as well.
Had to solder two pins together and works perfectly now.
http://www.bimmerfest.com/forums/sho...d.php?t=745541
here is my e46fanatics thread..
http://forum.e46fanatics.com/showthr...376&highlight=
and the scanner i got is $22 shipped from here: http://www.ebay.com/itm/Scanner-For-...item2a31f85f9f
HTH
mikeetastic is offline   Reply With Quote
Old 01-19-2014, 02:10 AM   #1902
78Silvershadow
My Ride: 330ci
Hey Guys,
Thank you for this thread, ordered my scanner from Xcar360 a couple of weeks ago and while I waited, I got myself a used XP laptop from CL. The scanner arrived quickly. It was truly plug and play and no issues. I was able to clear my errors and fixed a turn signal light.
Starting to figure out how to use it.
Ss
78Silvershadow is offline   Reply With Quote
Old 01-19-2014, 02:36 AM   #1903
agd320i
My Ride: E46 320i
I would like to recode my Euro LCM to US LCM so that I can have the dimmed corners on with the low beam headlights. I have checked the LCM settings using the BMW scanner but I couldn't find it.
Thanks for the help
2001 E46 320i
1981 Porsche 924 Turbo
1979 Ford Capri Ghia
agd320i is offline   Reply With Quote
Old 01-19-2014, 09:11 AM   #1904
BM330
My Ride: BMW 330Ci
HTH
I just payed for this one too.It means that I have to solder pin 9 and 10 to get ir work propertly ?
BM330 is offline   Reply With Quote
Old 01-19-2014, 09:21 AM   #1905
Foxtrot_Uniform
My Ride: 325Xi
Try it without soldering the pins first... If nothing then solder.
Foxtrot_Uniform is offline   Reply With Quote
Old 01-20-2014, 09:28 PM   #1906
Xoutas
My Ride: '02 325i, '04 Pathy
Just got my scanner last week & got it working with windows 7 thanks to this thread (PA SOFT 1.4 Windows 7 64bit BMW Scanner How to install DIY HELP) - worked perfect. But a few questions, cause I'm kinda confused with all the threads that I read.
- the top two lines don't come up (engine & trans) am I supposed to solder pins 1 & 2 & 7 & 8 together to get this feature? Besides that all else worked great & was able to see why my airbag light is on. A pic of what my scanner looks like. Also looks like pins 5 & 7 are soldered together.
- seems that the scanner turned my ses light on (wasn't on before I plugged the scanner in), I drove a little with the light on, then the car pretty much sat for a day. I went out the next day and the light was off and hasn't come on since. Just wondering if anyone else experienced this?
Thanks in advance.
Xoutas is offline   Reply With Quote
Old 01-21-2014, 08:18 AM   #1907
scottk706
My Ride: 2003 black E46
Could anybody upload or send me a copy of the software? I purchased my online the software is no good. Would be a huge help, Scott
scottk706 is offline   Reply With Quote
Old 01-21-2014, 08:19 AM   #1908
scottk706
Hey, could somebody upload or send me a copy of the software? I purchased mine online and the software is not working. Corrupter version. Thanks, Scott
Old 01-26-2014, 11:47 PM   #1909
eatsleeplax
My Ride: ..
I have a 2005 BMW M3 and I want to activate my alarm module. Noticed this thread is a little old, is the general consensus on these http://www.xcar360.com/bmw-scanner-1...scan-tool.html fake PA Soft scanners / software still that they work fine? About to pull the trigger on one. Also, are you guys hooking your cars up to a battery tender when you use these? If so, at what amperage? Thanks for the help!
eatsleeplax is offline   Reply With Quote
Old 01-27-2014, 12:52 AM   #1910
scottk706
Most of the software works. Your need windows xp or windows 7 (64bit) to run it. Send me a pm when you get your software I'll walk you through activating your alarm. Super easy.
Old 01-27-2014, 12:59 AM   #1911
eatsleeplax
My Ride: ..
Thanks. After failing with the bmcables.com ebay setup (as a computer engineering student, that software is a crapshoot) I've decided to go this route for now and just setup NCS Expert when I have more free time. I'll shoot you a pm when my order comes in.
Old 01-27-2014, 09:57 PM   #1912
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Hey, I am having some problems with the scanner. It is version 1.4.0.7 and I am receiving the "Error with IKE" message. My car is a 10/99 and I have to use the 20-pin adapter under the hood to connect it. Even so, I am still having "Error with IKE" show up on my screen. What should I do?
lllRazorlll is offline   Reply With Quote
Old 02-26-2014, 07:56 AM   #1913
Dan1el
My Ride: E46 320i '99
Send a message via MSN to Dan1el
Has anyone managed to get this working on Windows 8.1 (64bit)?
Dan1el is offline   Reply With Quote
Old 02-26-2014, 10:51 AM   #1914
jM2.me
My Ride: BMW
My works on Windows 8.1 64bit just fine.
However, there is driver issue with devices that use counterfeit cp210x chip. I didn't check if bmw scanner cable uses it or not, but I do know that cables for inpa/ediabas use it. My inpa/ediabas has counterfeit cp210x chip and driver for it doesn't work.
Volcano Red M3 Bumpers, Fenders, Quarter panels 19" 8.5ET35 225/35 | 9.5ET35 255/30 Custom Quad Exhaust Good old M54
jM2.me is offline   Reply With Quote
Old 02-26-2014, 10:53 AM   #1915
BM330
My Ride: BMW 330Ci
Hello ! After installing drivers I get this error !
It's on win 7 ultinamte
Old 02-26-2014, 11:11 AM   #1916
Xoutas
Do you have the scanner plugged into the car while you are running the software? I made that mistake when I first got the scanner.
2002 325i - 116500 - 'Molly'
2004 Nissan Pathfinder LE 4x4 - 157,000
Old 02-26-2014, 11:26 AM   #1917
BM330
My Ride: BMW 330Ci
no,it's only connected to USB port on my PC
Old 02-26-2014, 11:41 AM   #1918
Xoutas
Well there's your problem, it needs to be connected to the car when you run the software, that's why you got that error. The engine doesn't have to be running but you have to turn the ignition on to positions 1 or 2 so the software can scan your car.
Old 02-26-2014, 12:31 PM   #1919
BM330
My Ride: BMW 330Ci
ok,will test it !
Old 02-26-2014, 04:26 PM   #1920
morningisbad
My Ride: E46 M3 Vert
ok,will test it !
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
