Old 12-25-2011, 11:38 AM   #21
e60fan
My Ride: 525i
I decided to go in future if shit happens with oil pump from Greg Smith. I can see warnings with beep in the iDrive and have 117 seconds
You don't know what I done already
About cams - I will simply install 240 with all intake from b30 and have 240/244 and tune, so I will go with TS2 for example with no problems
e60fan is offline   Reply With Quote
Old 12-25-2011, 05:49 PM   #22
Rob43
My Ride: 2003 BMW 331Ci, 5spd
OK, I'll bite.
If it were me, I'd do it like this:
1) Oil pump: keep your stock OE pump & wire tie the nut.
2) Cams: a big NO to the stock B30 cams, get yourself 264/252 copy of the Schrick.
3) Intake manifold: B30 with adapter plate for your original TB.
4) Tune: Shark Injector, 7000 RPM, cheap & simple but very effective. Forget about 7200 RPM.
5) Harmonic Damper: throw out your OE piece & buy the ATI Super Damper.
6) If you don't have all the normal bolt-ons, buy them.
7) Down the road: nitrous. Spend $2500 on a Wizards of Nitrous direct port wet system, you'll make more power for a lot less money. Plus it will work with these cams (264/252) & setup, you won't need a high dollar "tune" to make it work either.
Merry Christmas.
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 12-26-2011, 12:17 AM   #23
e60fan
My Ride: 525i
Originally Posted by Rob43 View Post
OK, I'll bite.
Merry Christmas.
Thanks, but the way to go is FI, nitro isnt for me, I think about 2k-3k used kit. Tune is custom for my setup. Adapter plate is for e46, but I dont need it because I need to change except intake manifold, disa and TB only tube where MAF installed and will have complete b30 intake, e60 m54b25-b30 air box and MAF are identical.
About cams - I dont know where I can regrind it in EU.
For boltons I have K&N filter dropin, SS replica headers, custom catless Magnaflow straight exhaust
with resonated X-Pipe.
Merry Christmas.
