Horsepowerfreaks Ethanol Z4M build - Page 15 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-24-2012, 05:24 PM   #281
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I was wondering when that point would be brought up.
Technically, as long as the hardware can handle it, there's no difference. But of course in the real world, you double the work that the coil packs are doing...and there are different results from that.
I'm not sure I'm picking up what you guys are talking about here...care to discuss further? What I'm getting from this is on a turbocharged application you are doubling the amount of work required from the coils? Or is this in regards to different EMS running the coils?
Old 12-24-2012, 09:04 PM   #282
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I'm going to word this to focus on the facts, not a specific product:
If an EMS doesn't have enough ignition outputs, or the software/processor configuration doesn't have the ability to run X ignition outputs sequentially, you can run a "wasted spark" configuration.
This is provided that the engine has an even-fire bank configuration, where for example cylinder #1 on bank A is at TDC at the same time as cylinder #3 on bank B.
Wasted spark on a 6 cylinder engine would use 3 ignition outputs that fire every 360 degrees of crank rotation. In a sequential configuration, 6 individual outputs would fire once every 720 degrees.
Or in other words, every time a piston is at TDC, the ignition fires with wasted spark. Half the time it's igniting a burn cycle, half the time it's firing during the exhaust cycle.
Sequential ignition outputs would fire only during the burn cycle.
So with "wasted spark", you gain the ability to fire more cylinders, but the ignition system effectively doubles the work load on the existing hardware. It has nothing to do with the fact than an engine is turbo charged or not.
The other miss-conception about FI engines is that running more boost puts more load on the ignition system. This is not true. The ignition system doesn't care about cylinder pressure, or whether the signal output to the spark plug does it's job. It just keeps doing it's thing blindly. If the system doesn't have enough strength to light off a high pressure cylinder charge, it's actually easier...because the energy doesn't get expended. (Missed ignition) That's not to say that more cylinder pressure doesn't need a stronger ignition system, because this is usually the case. It's just that as far as load goes, or how much work the ignition does, system life is a function of RPM or simply how many times the system fires, not so much what it's firing into.
Man...I really should write up an article on smart coils, dumb coils, ignitors, and CD systems.
Old 12-24-2012, 09:14 PM   #283
Commanderwiggin
Thanks for the info! I'm sure you know offhand which EMS use which system...so what does each offer?
Secondly I'm sure alot of us wouldn't mind a read up on the above when you get some time after the holidays Merry Christmas
Old 12-24-2012, 09:19 PM   #284
Commanderwiggin
AEM V1: 3 Coil Outputs (Wasted Spark)
AEM V2: 6 Coil Outputs
Interesting...
Old 12-24-2012, 10:20 PM   #285
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Time?
I'd love some of that....
Old 12-24-2012, 10:30 PM   #286
WALKD U
My Ride: Just Fast!
Time?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 12-25-2012, 07:43 PM   #287
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Interesting...
Does the wiring harness takes advantage of this on the V2 kits?
Old 12-25-2012, 07:44 PM   #288
Commanderwiggin
There is no V2 Kits for our cars.
Old 12-31-2012, 04:49 AM   #289
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
Such a sad, depressing and frustrating situation.
I wish you basar the very best of luck in this whole situation. i will communicate with you through pm
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 01-09-2013, 02:21 AM   #290
basar13
My Ride: Z4M, R8, 525xd, STI
We have wired Haltech and it was fine, there isnt any abs etc problems like pro-efi. It was going all good then oil scavange pump failed :@
I need a new pump I wonder how it failed so early?
I will keep you posted.
basar13 is offline   Reply With Quote
Old 01-09-2013, 02:22 AM   #291
basar13
We have checked the wiring and the Pro-efi also uses wasted spark system..
Old 01-09-2013, 09:37 AM   #292
dan avoN7
My Ride: A car
It's because you aren't running the HPF AEM! Oh and now you no longer have a warranty on any of your parts, so that failed scavenge pump isn't covered
All joking aside (or not ), I would add an oil drain sump for the turbo along with a new pump.
dan avoN7 is offline   Reply With Quote
Old 01-09-2013, 12:08 PM   #293
Think0rz
My Ride: 05 AW M3
lololol this post has so much win to it OP I truly admire your patience throughout this whole ordeal, you my friend ARE the bigger man of all companies involved. Glad to see you're finally getting somewhere and will be out your car very very soon.
Think0rz is offline   Reply With Quote
Old 01-09-2013, 01:37 PM   #294
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Those pumps have extremely tight tolerances which makes them very quiet and very efficient. Any tiny amount of debris in the oil line that goes to the pump will cause it to fail. This can happen when a turbo takes a dump and spits out it's guts, but we've also seen it happen when installers use silicon on the AN fittings or when debris gets into the lines prior to installation. We've also had issues in the past where the oil scavenge pumps have bolts that loosen up as well. Sometimes they can be tightened up and it works again, but often they are junk when they fail.
Others may chime in here, but I think they typically have a life expectancy of about 30,000 miles.
Chris.
HPF Chris is offline   Reply With Quote
Old 01-09-2013, 03:27 PM   #295
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
What were the signs / symptoms of the pump failing ? Do u have a sensor or did u just not hear it running ?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 01-09-2013, 03:30 PM   #296
being3
Modded ///Member
being3's Avatar
Chris.
It would be a nice for us the have an estimated MBTF for some of the key parts in the HPF kit so we can add them to a Maintenance schedule for r HPF cars.
Old 01-19-2013, 03:59 AM   #297
basar13
It is on warranty but i have to send it to USA to be checked before they send me a new one.
I still didnt remove it from the car.
Old 01-19-2013, 04:01 AM   #298
basar13
It is not working i cannot hear it and the ALOT of white smoke from exhaust.
Old 01-20-2013, 04:17 AM   #299
basar13
I am going to garage now to remove it. Lets solve this issue.
Old 01-20-2013, 11:22 AM   #300
InDiGlOM3
My Ride: HPF M3 stg 2.5
Chris.
I dont onow how but i got 65k out of mine. It start stopping working on the motor side when it got hot. And the lil tabs with springs that push against the main rod were to worn out to be pushed more
Sent from my PG86100 using Bimmer App
