E46 Xi Forum
Old 12-28-2011, 12:49 AM   #1
gitchies
My Ride: 05 325xi
Strange shaking, highway speeds,
So, recently....last two trips of (3.5 hours)
Doing about 70 on the highway, everything is good, crusing for a bit, but when i go to give it some gas to pass someone, i get this weird shaking...like the engine is starving so slightly for power and the the engine shakes.....i thougth wtf?....i let off the gas and resume...seems fine....
i do it again, and same result...shaking bad.....seems like the engine is shaking and is almost loud?
this has happened on the last few trips, same highway, same speed....no codes, nothing leaking...
no mods or anything in the engine....
but if i just drive and get it up past the 70 no strange shaking....and not been on the highway for a bit....
any thoughts?
gitchies is offline   Reply With Quote
Old 12-28-2011, 01:15 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
errrm, worn front lower ball joints?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-28-2011, 01:24 AM   #3
e36-2.0
My Ride: 330xi
You need new cv axles. Theyre likely worn and have play in them.
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 12-28-2011, 01:33 PM   #4
TiAgXi
My Ride: e46xi, e46m
yep
TiAgXi is offline   Reply With Quote
Old 12-28-2011, 02:19 PM   #5
GCoop
My Ride: '04 325xi
My internet diagnosis is Dry CV joints.
Check to see if the Joints still have grease in them... If its gone on too long you may need new axles--Like others have said.
On the XI with ANY kind of driveline vibrations this needs to be ruled out FIRST.
GCoop is offline   Reply With Quote
Old 12-28-2011, 06:38 PM   #6
ixtoxi
My Ride: 02 330xi, 88 325iX
I agree with CV axle assessment.
ixtoxi is offline   Reply With Quote
Old 12-29-2011, 12:24 AM   #7
ne.iowa.e46
My Ride: 2004 325xi
yes, CV joints most likely. Also check ball joints.
Like driving the wind...
ne.iowa.e46 is offline   Reply With Quote
Old 12-29-2011, 01:37 AM   #8
gitchies
My Ride: 05 325xi
Thanks guys...i'll have to get this checked out soon....as for getting new cv joints...any ideas where is a good place to get them in Canada?
looks like i have a big overhaul coming....these, fcab bushings....was going to be doing the springs and shocks too over the winter....
Old 12-29-2011, 01:42 AM   #9
gitchies
My Ride: 05 325xi
Dry CV joints?....so if the grease is gone, but wouldn't it really be rattling? i'll have to get the car in to the shop and have them check...would re greasing actually save the cv joint? or am i better off just replacing them? and save the time of re greasing them...
Old 12-29-2011, 10:29 AM   #10
Kubica
My Ride: 2003 325xi
Yeah prob the passenger side inner is out of grease.
Old 12-29-2011, 10:32 AM   #11
gitchies
My Ride: 05 325xi
yep. i feel it from that side, gonna see if i can get her in sometime tomorrow maybe re grease it til i can order new ones.
Old 12-29-2011, 12:12 PM   #12
GCoop
My Ride: '04 325xi
Good point. Its typically the inner joints that cause this issue. With the passenger side seemingly the worst offender for whatever reason.
If this turns out to be your issue and depending on how long the joint(s) have gone without adequate grease you may be able to salvage the axle(s) and get by with just replacing the boots and repacking the grease. If you do end up needing new axles dont skimp on price an go for the cheap chinese axles. The general concensus has been that you will most likely regret it later on. Go with a qulity OE reman'd to be safe. I have read that most are happy with the A1Cardone reman'd units as they are typically refurbished OE parts.
In my personal experience -- I am still on the original axles @ ~110k with all the boots changed out (because of cracks and leaks) @ ~60k. The inners were repacked with grease around ~95k because the clamps started to slack off and allow grease to escape.
Old 12-29-2011, 01:09 PM   #13
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
We have all had this! Regrease inner CV & hope the damage was not too bad, you should be OK though.
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 12-29-2011, 04:21 PM   #14
gitchies
My Ride: 05 325xi
yep, going to a shop tomorrow and seeing if they can re pack it and grease it....i'm just starting to source out some new ones now....fcp groton? i'm gonna look up A1 Cardone. Just not too many options here in canada. i don't even know where i can get re manufactured ones here....
i'll see if i can salvage them for a bit...not sure how long its been going on for...but my guess...maybe 1200kms is when i noticed...
Old 12-29-2011, 08:27 PM   #15
SharkmanBMW
I don't think the inner cv joint will have much damage from running dry, from what I was told, they do not have the same forces/angles applied to the outer CV joints and the wear would be minimal.
There are some threads around about Canadians getting axles shipped & local...
I have had mine removed, cleaned & repacked multiple times now, usually due to torn cv boots, but also had the dry inner joints with violent shuddering on the highway after 30+ minutes.
All good now
Old 02-04-2013, 06:09 PM   #16
ne.iowa.e46
My Ride: 2004 325xi
Anyone who has owned an XI with over 60K has experienced this. Very common for cv boots to fail allowing contaminates to enter the joint. Soon the shaft will become unbalanced causing the vibrations. Need to find a heavier boot that stands up to the abuse.
