Thread Tools Search this Thread Rating: Thread Rating: 38 votes, 4.34 average. Display Modes
Old 03-06-2012, 12:56 PM   #221
Tate325xi
My Ride: 325xi 5MT
Will you be rebuilding the blown M54 out of the 325i?
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 03-06-2012, 02:27 PM   #222
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Oh no, this is way above my head right now. Maybe in a few years.
I actually ran the 325 engine and the engine didn't overheat no matter how long I let the engine idle. The only problem was the miss fire and poor idling. When I was working with the engine I realized that the ccv was broken and there was a heavy leaking vcg.
Who knows. Maybe this is the only thing wrong with the engine
sent from HTC EVO
Old 03-06-2012, 02:40 PM   #223
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
^^ DO IT
I have built a few and once you do the first and it runs great you are on a natural high and knowing you can makes you fear little when it comes to a repair
/_________\
O==[][]==O
Old 03-06-2012, 03:17 PM   #224
new//M3fan
My Ride: 77' 924 87' E30
Originally Posted by 330i ZHP View Post
^^ DO IT
Ftmfw! I built the little 4 cyl on my 924. Been to California and back several times. No issues at all.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 03-11-2012, 09:55 PM   #225
flashmeow
Banned User
There isn't really any progress. This past week the weather in OK was horrible. It was raining like crazy and we couldn't get much done. Here are some pictures.
We pulled the 325 inside the garage so we can hook it up to the GT1 and charge the battery
GT1
Our trusted Battery charger. capable of charging Gell, AGM, and traditional lead battery. This charger also acts as a trickle charger. For the same price as the BMW advance charger we bought this instead. I still have my BMW Advance charger but it doesn't work for the e9x model (cigarette lightet socket gets deactivated after 10 mins rendering the charger useless)
The battery wouldn't hold a charge so we ended buying a battery at Autozone. Duralast 49DL fits perfectly. I have this same battery on my 323i
GT1
Look at all of those modules with faults. OMG. luckily, most of the error codes are related to the engine and everything else were either user induced (unplugging modules) or shadow codes
Here is a picture of why BMW is recalling facelift tailights. the grouding pins are burnt/eroded
Old 03-11-2012, 10:01 PM   #226
flashmeow
Banned User
lets start taking this baby apart
I wish everything was easy as the stock airbox
I popped my head underneath and saw that the engine spash guard was damaged. my guess was that some dumb ass tow truck operator didn't know how to hook up the BMW and instead of using the BMW tow hook he decided to hook it to the engine spash shield
removed the DISA and noticed an usual oil residue. my guess is a failing CCV
CCV return pipe was clogged...hmm...most likely the CCV is dead
We pulled out the injectors. We dont' have a way to do a flow test but am going to replace the injectors anway. We have six used injectors (30k miles)
Can you spot Limoncello?
Old 03-11-2012, 10:08 PM   #227
flashmeow
Banned User
We removed the ignition coils so we can remove the valve cover
The engine has no sign of sludge. Not bad for 160k miles. It doesn't matter because this engine is going on display in the garage after the swap
There seems to be an usual oil leak on the plastic splash guard. It was later discovered that the CCV and VCG were leaking
A better picture of the engine oil pan shield. epic fail for tow truck operator
the undercarriage of the car is soak with oil
more oil shots
I decided to remove the fender to prevent it from damages while working on the car. The fender is going into my 323i so i might as well remove it now
some of the fender scew started to stripped so I used my most perfer method (dremeling). I have never once use a drill, EZ out, etc. The dremel method always seem to work for me
Old 03-11-2012, 10:15 PM   #228
flashmeow
Banned User
now do you see why dremeling is most perferred (by me)?
the fenders are also secured by some metal or plastic rivets.
removing the bumper is easy
vendor is gone. that vent tube is for water drainage. for the M3 it is also use for ECU/DME cooling (via the side grille)
Next we are going to remove the radiator suppor bracket
Decided to test out the BMW powersteering/ATF hose removal tool that I bought on ebay for $17. These tools (different brand has different model number) goes from anywhere from $25-45. I got mine $17 shipped
http://www.ebay.com/itm/BMW-Fuel-Lin...item3cc014dfdb
it is currently on sale for $16 shipped
here is the tool in action
Old 03-11-2012, 10:20 PM   #229
flashmeow
Banned User
another view of the tool
the passenger fender screw refused to turn no matter what. a little touch of the blow torch was able to break the seal (excess paint...fender was previously repainted). I used a wet towel to isolate the heat just to the fender screw area
fender removed
I decided to cut the water hose to make the radiator removal process easier. the hoses were in such bad condition anway that they needed replacement
another cut hose
AC belt needs replacing
Old 03-11-2012, 10:23 PM   #230
flashmeow
Banned User
the main belt is just as bad
CCV pipe that connects to the dip stick was busted
vacuum line that connects to the SAP valve was busted
picture of the engine bay
the vacuum line that connects the fuel filter to the intake boot is also busted
Need to replace the fuel filter (160K miles)
Can you spot Limoncello ?
this is where the car currently sit.
Thanks for reading. I don't expect to work on the car this week because of the forcasted rain. maybe I might tear down the 323i in the garage while it is raining outside.
Old 03-11-2012, 11:29 PM   #231
lab rat
My Ride: '02 330iT
Nice progress.
Too bad about the front end brace, there goes another $150.
Because sleeper
Old 03-12-2012, 02:49 AM   #232
My Ride: Lexus
Good progress. That's sad that the reinforcement plate got effed like that.
Old 03-12-2012, 01:07 PM   #233
raptorman5174
My Ride: 330i ZHP
Nice progress, love that tool for removing the power steering hose!
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 03-12-2012, 01:15 PM   #234
323I00
My Ride: E46 323I
Love where this Is going Betty .
Functional justification... true. But girls dropping their panties counts for something
BBK on non-supercharged-non-m..... because chasecar
323I00 is offline   Reply With Quote
Old 03-12-2012, 03:24 PM   #235
Master Po
My Ride: E46 no more
What is all that white residue covering most of the engine? Is it fire extinguisher powder?
And what does VCG stand for?
Master Po is offline   Reply With Quote
Old 03-12-2012, 03:35 PM   #236
lab rat
My Ride: '02 330iT
Very Cute Girl
Because sleeper
Old 03-12-2012, 03:55 PM   #237
Russian172
My Ride: e46 sedan e46 m3
That 325 looks sooo well taken cared for
Russian172 is offline   Reply With Quote
Old 03-12-2012, 04:08 PM   #238
flashmeow
Banned User
Great question. anytime you see white residue around your engine block then it is indicative of coolant leaks. The expansion tank blew and the car overheated. the car was barely driveable (head gasket, vacuum leaks, etc) and we were able to get the car for dirt cheap.
the VCG stands for valve cover gasket. the reason why I said ti was leaking because I noticed oil stains on the exhaust manifold heat shield (tell tale sign) and throughout the plastic valve cover area.
Originally Posted by lab rat View Post
Very Cute Girl
lol
Yeah the car was beat up and abused but luckily for us we have a lot of spare parts and willing to put in a few dollars for a major overhaul. Not only are we replacing the engine we are going to work on the fuel system, suspension, etc. The engine that is going into this car is extremely reliable and well taken cared of. almost ever single components, gaskets, vacuum hoses, etc were replaced within the last 20,000 miles.
The car will never turn into a show car but is meant as a reliable daily driver for my husband's little brother.
Old 03-16-2012, 08:33 PM   #239
Russian172
Well I think you should do some turbo testings on it lol well defiantly good luck I hate abused e46's ,what was the case with this one though
Old 03-26-2012, 03:45 PM   #240
flashmeow
Banned User
MINI UPDATE:
I haven't touched the car in the last two weeks since i have been so busy with work. the car was just sitting on the driveway that water from the recent rain flooded the intake ports (ewww). luckily the engine is blown so it really doesn't matter.
Also, the HOA is complaining that the car is becoming an eye sore and asked me to push it into the garage. apparently a few neighbors complained (rolling eyes).
so to help me move the car around I decided to buy the EZ CAR LIFT (http://www.ezcarlift.com/) with rolling casters (so I can push it around).
^^not my picture^^
here is a youtube video
the EZ Lift is a little under $2000 but if you call and talk to the owner he will knock a few hundred dollars off. The rolling casters is purchased seperately but he will give you a discount too.
anyhow, I just have to wait several weeks to get it but in the mean time I need to push my car in the garage. I will post pictures as soon as I get it.
Betty
too many pictures
