Rating:
Display Modes |
#41 | |
Banned User
is the crankshaft seal #5 on realoem (link below)? http://www.realoem.com/bmw/showparts...67&hg=11&fg=10 Do you know how hard is it to install the seal? P.S. Stupid question but how do i secure the engine to the engine stand. I |
#42 |
I know it's a little off topic but your old engine what will you do with that one?
#43 |
Banned User
promise not to laugh? I get attached easily (I am very sentimental)....so after the swap I am going to put the M52TU on the engine stand and put it on display either in the garage or study room.
#44 |
Turn it into a table like on Top Gear.
#45 |
My Ride: cars older than you
![]() Respect Your Elders |
#46 |
#47 | |
It's very easy DIY even with the motor in the car. You just can't do it on the engine stand. You will need 4 long M12 bolts for the engine stand. They go where the 4 big transmission bell housing bolts normally mount.
Because sleeper.
#48 | |
Banned User
with regards to the mounting the engine, it makes total sense now. i am using a lot of PEI330 pictures as reference and here is a picture of his engine mounted on his stand using the tranny bell housing bolts http://my330i.com/forums/showpost.ph...&postcount=116 |
#49 | |
#50 |
do a build thread. im sure plenty of people would love to follow the thread. I cant recall the name of the guy that just did the swap with the s54. I want to do a engine swap one day in the next few years. got 200k on mine
#51 | ||
With a larger displacement, and no other changes I'd expect the mixture to run lean, misfires would occur, the engine would try some enrichment compensating, and then go into safe mode. Maybe a ghetto fix would be just install an adjustable fuel pressure regulator, and slowly up the fuel pressure, until the engine compensation amounts were close to neutral. The mapping probably wouldn't be ideal though, as camshaft and intake properties would throw things off in a few areas. |
#52 |
Do you mean the S54? I mean in all honesty, the S52 is a nice motor but not really an upgrade from the M54. More like stepping sideways-ish...
#53 | ||
Banned User
Original injectors won't put in enough fuel with 330 software when did I say I was running 330 software? wiring going to be different and how will the ECU react to not having all inputs? when did I say I am going to run a MS43 or MS45 engine wire harness and DME? you have no reading comprehension and just came in here with your negativity. I would even say you came in here just to "rain on my parade." next time, I suggest you read the thread before commenting. The only valid thing you said so far is the "lean codes" but I am sure I won't run into that problem. The 2.8L and 2.5L uses the same injectors and I think the stock injectors is rated up to 210-220HP. Anyhow, I might be a "newbie" so I am sure this is why are you are shitting on my thread but what do you have to say about 4ngie and M4TT dropping in a 3.0L engine to replace's their B25 engine. 4ngie ran her car with the MS42 (325 Map) on the 3.0L and reported no major issues. I am already talking to a few tuners to customized my MS42 Map to take advantage of the larger displacement and larger injectors. So if everything fails I will just get a custome tune and hopefully this will silence your non sense and negative views. BTW...since you know it all, can you at least help me and contribute to my thread in a postive manner by answering my question: what is the stock flow rate for the 323/328/325 fuel injectors? I know the B30 uses #24 but can't really confirm the B25. I keep on getting conflicting numbers from #16 to #22 if my project fails then I will be the first one to admit that I was wrong based on a lot of incorrect assumptions. Heck, I will even suck up my pride and ego and come on here and say "you are right." However, at least I can walk away knowing that I have bigger balls then you to try something like this. Last edited by flashmeow; 01-13-2012 at 05:40 PM. |
#54 |
lol, short temper today? I was just chatting about engine stuff. Notice most of the stuff I said had a question mark behind them and not a
?If I wanted to come in hear and annoy you, I'd start putting stuff in bold and saying "YOU HAVE NO READING COMPREHENSION!!!!" EDIT: oh wait, you already did that to me... Last edited by mkodama; 01-13-2012 at 05:55 PM. |
#55 |
Jebus... this is the internets. Calm down, people.
Opinions are like @$$holes. Everyone has one. |
#56 |
M54B30 only
BMW Part No: 13 53 7 546 245 Manufacturer: Siemens Manufacturer Part No: 1439800 Flow rate: 244cc/min or 23.2lbs/hr at 3 bar (43.5psi) 315cc/min or 30.0lbs/hr at 5 bar All M54 and M52tu (excluding M54B30) BMW Part No: 13 53 7 546 244 Manufacturer: Siemens Manufacturer Part No: 1427240 Flow rate: 161cc/min or 15.3lbs/hr at 3 bar (43.5psi) 208cc/min or 19.8lbs/hr at 5 bar Last edited by mkodama; 01-13-2012 at 07:27 PM. |
#57 | |
Banned User
here is what PEI330 wrote on his amazing build thread on my330i With "spark" handled, I turned my attention to fuel. The purple ones are the OEM 24 lb/hr injectors, the maroon ones are new 30 lb/hr injectors: ![]() It appears that the OEM injectors have a directional nozzle that points towards the valves. The OEM injector is on the left, new one on the right: Last edited by flashmeow; 01-13-2012 at 06:58 PM. |
#58 | |
Town Clown
Bay Area Top Dropper Orient Blue 330 Ci Vert ********************** ![]() |
#59 |
#60 |
Flash a couple of things ...
1-Im so subscribed to this thread. 2-I you for the attempt.3-Please document and post pics of every Inch and detail as many 323I owners will be most likely doing this after you do It. 4-Will you be parting any thing from youre 323 ? 5-Have a look at DYNOTUNE...may wanna get a euro flash... Ill be back with more ...
![]() Functional justification... true. But girls dropping their panties counts for something BBK on non-supercharged-non-m..... because chasecar |
| Tags |
| too many pictures |
