Rating:
Display Modes |
#121 | |
Banned User
no, i haven't pull the engine off yet. this won't be until sometime in FEB since I am mainly working by myself and I am a very etremely slow worker (takes me an hour to change my oil when most people can do it in 15 to 30 mins). |
#122 |
My Ride: have 5 doors and FI
ok...then, when you are ready - drop the engine and trans TOGETHER as one unit along with the front subframe - it is SSSSOOOOOOmuch easier than trying to remove the trans from the engine or trying to pull the combo out
you can do it like i did on the wagon and just loosen to the furthest point the bolts holding the subframe on - that will give you enough room to get the oil pan to clear I repeat - if I do this again (and I am strongly considering swapping the two engines around in the cars...this will put the original engine and trans and stage 2+ back in the sedan...and the stage 3 engine would go in the wagon...since it is more modified at this point...)....so, if I do this again, I will simply drop the engine and trans on the front subframe/suspension
![]() /_________\ OO=[][]=OO |
#124 | |
So a welded on or wire tied OPN, plus a $800 ATI Super Damper is damn good insurance for the driver that really likes to push their Bimmer hard. Good luck.
![]() Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD SUMMIT POINT WV 1:24:229 S.C.C.A. http://www.vimeo.com/8486878 (Dyno Video) ........add a sh!tload of cowbell. |
#125 | |
Banned User
#126 | |
Banned User
Just dont cheap out , get a vaio pump and be sure you wont ruin your engine later. |
#127 |
Banned User
Not only will this happen, It's a royal pita to drop the pan. I got lucky saw the red light shut her down.. Hearing the lifters fill back up with oil and quite down, was the worst noise/feeling ever. clack clack clack clack silky smooth. I welded my nut on after that.
#128 |
i am curious to see how the spot weld is holding up on the stage III motor
#129 |
I screwed up and can't post
LTW flywheels are probably causing a lot of harmonic issues. I'd stay away from those.
In fact, I'm willing to bet just about everyone who had a OPN failure had a LTW flywheel..we should do a poll. In for results, love to see how this will turn out. |
#131 |
Banned User
today's update: I spent the entire day cleaning the engine. First I use a air compressor to blow away as much debris as possible. I then plug each engine opening with a shop towel and then installed double sided tape to prevent water from getting into the engine. I then spray a can of engine degreaser and let it sat for 15 mins. I then use my pressure washer and washed the living **** out of the engine. I let the engine dry and came back and used a can of brake cleaner. I then pressure washed the engine again and then used compressed air to dried it off. I removed the tape and check each engine opening and sure enough no water managed to get into the engine.
![]() Here is a picture of my cat watching me through the his cat door. Normally his liter box is in the garage but since I am trying to clear coat my floor I moved his liter box inside. ![]() I removed the hydraulic tensioner and will used my old one since it is in better conditions. ![]() Using an air compressor to blow away as much grime and debris from the engine as possible ![]() stuffing in a shop towel in each engine opening to prevent water from getting in and use double sided tape as another layer of protection Last edited by flashmeow; 01-21-2012 at 05:51 PM. |
#132 |
Banned User
![]() Dont really need to cover the water pump and thermostat opening but wanted to play it safe. didn't want to get harsh chemicals into the coolant passage way ![]() here is what it looks like when everything is covered. ![]() Using a heat gun to ensure that the tape is fully adhered to the ports ![]() spray some engine degreaser and let it sat for 15 minutes in order for it to work its magic Last edited by flashmeow; 01-21-2012 at 05:56 PM. |
#133 |
Banned User
![]() after soaking, I used a pressure washer to clean the engine ![]() after drying I saw an imediate result. the engine is no longer oil/greasy. there are still grime left but that is what the brake cleaner is for ![]() here is what the engine looks like after using brake cleaner. there is just a small difference in appearances Last edited by flashmeow; 01-21-2012 at 06:01 PM. |
#134 |
Banned User
![]() here is my cat spying on me. He is an indoor cat but he knows better not to go outside. There was plenty of times I left to go to work and forgot to close the garage door. I come back 8 hrs later and my cat is still home and did not run away. ![]() after spraying the engine with compressed air again I decided to pull the engine into the messy garage and let it air dry. Noticed my parking stripes. tomorrow the weather should be hot enough for me to clear coat my stripes but I need to clean and organized the messy garage first. Last edited by flashmeow; 01-21-2012 at 06:06 PM. |
#135 |
Banned User
that is it folks for this week. Next weekend I will do the vanos seal and rattle and replace as much seals/gasket/orings as possible. It won't be until mid or late feburary until I can remove my original engine and drop the new one in.
#136 |
ncie garage
#137 |
Banned User
BTW...thanks to your ZHP Cams for sale thread ( http://forum.e46fanatics.com/showthread.php?t=844130 ) I was able to verify that I do indeed have a ZHP engine. my cams share the same marking as yours
#138 |
np
#139 |
Pro tip,
![]() If you want your pulleys to last you a long time without squeaking pop the rubber dustcap off with a pick and repack it with grease. Even if new.
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#140 |
Banned User
| Tags |
| too many pictures |
