Old 12-31-2011, 12:52 PM   #1
jay328ci
My Ride: 00 328ci
00 328ci idle drop
First starting the car when cold, it will idle around 1000 i think then drop to around 700 rpm like normal.
after a few seconds it drops to around 400 rpm almost stalling out and jumps back to 900 and settles at 700.
After it gets to normal running temp the idle smooths out and doesnt bounce around.
Besides maybe the icv and the intake hose which im going to check out could it be anything else thats causing this?
jay328ci is offline   Reply With Quote
Old 01-02-2012, 01:51 AM   #2
cbederio
My Ride: 2000 328ci
Hope this helps.
cbederio is offline   Reply With Quote
Old 01-06-2012, 04:36 PM   #3
s2kenny
My Ride: 328i
I have the same exact problem. Cold start, kind of rough at idle, a 500 rpm drop, then back up to idle. Usually doesn't stall but once in a while it will.
I haven't addressed this issue in my car yet since it only occurs during cold starts, but the research I have done leads me to think it's the VANOS seals. I would search it up.
2000 328i
s2kenny is offline   Reply With Quote
Old 01-06-2012, 04:38 PM   #4
wertyu78
My Ride: '04 ZHP
It could be a number of things. More than likely the VANOS though. One of my very first e46's was a 2000 328i. I had the same issue on cold starts. After rebuilding the VANOS and cleaning the MAF the problems went away.
wertyu78 is offline   Reply With Quote
Old 01-06-2012, 09:48 PM   #5
Vic328CSi
My Ride: depends on the mood
had the exact same symptoms on my '00 328ci, replaced vanos orings with those from besian and problem is gone, idle is rock solid even in cold.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 01-06-2012, 10:44 PM   #6
Hornung418
My Ride: '04 MB ZHP
I'm also in agreement. Replace the VANOS seals and your issue will disappear
Hornung418 is offline   Reply With Quote
Old 01-08-2012, 01:56 AM   #7
jay328ci
My Ride: 00 328ci
Lastnight i changed the plugs and was looking over the engine at vacuum lines. I found a hose going to a sensor under the front of the intake manifold wasnt clipped in right. Got it fixed and fired it up... idled perfect.
Today i fired her up and back to the idle drop again.
Old 01-08-2012, 01:57 AM   #8
jay328ci
My Ride: 00 328ci
coincidence maybe.
i might just try the vanos seals.
Old 01-08-2012, 02:41 AM   #9
abnpx
My Ride: 328ci
I am getting the same thing. I'm getting ready to hit the 100,000 mark. ;o) Right window went out already LOL, but hey you either love them or you hate them!
abnpx is offline   Reply With Quote
Old 01-08-2012, 10:50 AM   #10
s2kenny
My Ride: 328i
Originally Posted by cbederio View Post
Hope this helps.
Great video, exactly mirrors my symptoms.
