Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-01-2012, 07:49 AM   #21
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Originally Posted by MJM Distributing View Post
Yes, any aftermarket sport spring with a more aggressive spring rate than your stock springs can certainly blow your OEM dampers (dependent upon a few factors). Obviously the type of spring you're running (i.e. a mild Eibach Pro-Kit vs. H&R Race) will determine how fast, or if at all, your shocks decide to go. In addition, the mileage and condition of your stock shock, as well as how you drive, will always factor in to these things. Fact is, your stock shocks' valving just isn't equipped to handle that of an aftermarket performance spring. Are there thousands upon thousands of cars running the street today with aftermarket lowering springs mated to stock shocks? Yes, there are; tons and tons of them. Just give it some time, though; they'll eventually (with time) start to feel harsh and the ride start to get worse and worse. Obviously if you put a set of performance springs on a new car (or one with low mileage), your window of opportunity to drive on it like that is much bigger.
Best answer so far. OP, this is the definitive answer you were looking for. Also remember that a heavier wheel and tire combo will wear your shocks quicker, too.
Originally Posted by Mango View Post
reputable name brand only. no non-name, made-up name ebay teen baggy pants stance meets sideways stickers baseball caps neon sunglasses coilovers
LeMansteve is online now   Reply With Quote
Old 01-24-2013, 11:41 AM   #22
MJM Distributing
Past Site Sponsor
My Ride: TOO MANY TO LIST
Send a message via AIM to MJM Distributing Send a message via Yahoo to MJM Distributing
No problem. Glad we could help.
MJM Distributing is offline   Reply With Quote
Old 01-24-2013, 01:39 PM   #23
KrasivataSabine
My Ride: 323Ci
Wow, seeing as how this thread cam back to life, I feel obliged to deliver results.
I went for an H&R cupkit, a matched spring/shock package. I recently added hotchkis sway bars on top of that, so I definitely got the handling feel I was looking for It's not a technically ideal setup but damn it feels good.
My advice to anyone asking the question I was asking a year ago in the OP is this: springs and shocks must be tuned together to manage weight transfer and body roll effectively. If you simply get lowering springs (which are usually slightly stiffer, little lower) you may perceive a benefit in handling due to the stiffer feel of the car. The truth, however, is that the car will probably be oversprung, which can cause excessive body motion and oscillation compared to the OE setup. An oversprung suspension is also less effective in controlling weight transfer- bad handling.
Ultimately, I am of the opinion that, yes, one can run "sport" springs on OE shocks if the drop is mild. One wouldn't want to- real benefits in handling are gained when the suspension components are tuned and dialed-in together. Please consider a matched spring/shock package. Or, if you just want more responsiveness and reduced body roll, go for sport sway bars! ( just remember that stiffer sway bars actually increase weight transfer to the outside wheels and reduce total grip).
KrasivataSabine is offline   Reply With Quote
Old 01-30-2013, 10:03 PM   #24
MJM Distributing
Past Site Sponsor
Eibach markets their Pro-Kit Springs (maybe the most "mild" springs on the market in respect to drop and spring rate) as a spring designed to work with stock shocks. Of course, that is completely subjective, as it really depends on the condition of your shocks, thus why we don't advertise them as such. You obvious do not want to run them on a shock with 100K + miles on them and/or are worn and torn to heck.
Something else that many people do not know is that many dealers selling "OEM Sport Springs" (i.e. TRD with Toyota, NISMO with Nissan, VW Motorsport with Volkswagen, etc) are none other than an Eibach Pro-Kit repackaged in a factory box. Of course, neither the dealer or Eibach advertise that for obvious reasons, but it's the case with many, many springs out there with select "OEM Sport Springs." Yes, Eibach works with many auto makers out there.
