Old 01-01-2012, 11:20 AM   #1
DarkJoker
My Ride: 01 330ci
hydraulic vs mechanical clutch setup
Has anyone done this or attempted to do it?
basically instead of a hydraulic slave cylinder you would have a mechanical setup like older Chevy's and Ford's and other cars?
After reading about clutch and flywheel upgrades and then doing it(uuc stage 2 combo) i thought the difference would change marginally in clutch actuation.
While it did change it was not what i thought it would be.
I'm Just curious to see if it has been attempted.
DarkJoker is offline   Reply With Quote
Old 01-02-2012, 12:50 AM   #2
DarkJoker
My Ride: 01 330ci
something along the lines of this instead of a hydraulic line and slave cylinder
http://www.fordmuscle.com/archives/2002/07/clutchcable/
i guess i referred to it wrong im looking to see if anyone has attempted a cable setup
