Australia
Old 03-18-2012, 07:49 AM   #41
EMSPORT
My Ride: M///SPORT COUPE
sorry to hijack but im just wondering i got a 320 ci facelift coupe and wanted to know what is the biggest rotor i can go?
will i need to change my calipers ?
thanks
EMSPORT is offline   Reply With Quote
Old 03-18-2012, 04:31 PM   #42
shannon1
shannon1's Avatar
My Ride: 2001, 318i
All depends on your wheels and the inner rim diameter.
Shannon.
shannon1 is offline   Reply With Quote
Old 03-18-2012, 07:01 PM   #43
EMSPORT
They are 19 x 8.5 csl 's
Old 03-18-2012, 07:35 PM   #44
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Still won't be getting any bigger without changing calipers.
(inserts "that's what she said" comment here)
E46 Coupe is offline   Reply With Quote
Old 03-19-2012, 12:11 AM   #45
bmroxm5
My Ride: 135i
When bleeding brakes make sure you do the corner furthest from the brake master cylinder first, followed by second furthest etc...
EG: Brake master cylinder is near the drivers door in the engine bay, you should do rear-left, rear-right, front-left, front-right.
bmroxm5 is offline   Reply With Quote
Old 03-19-2012, 12:13 AM   #46
bmroxm5
My Ride: 135i
135i brakes aka. BMW Performance brakes from the E9X (as linked on the ECS site) aka BMW 6 pot Brembos are very good street brakes, good for occasional track use, but for lots of track use I wouldn't recommend them. The pistons in them are prone to cracking under high heat too.
Old 03-19-2012, 12:56 AM   #47
Turbo BMW
My Ride: BMW
Originally Posted by Goondaddy View Post
Brake upgrades are all fine and dandy, but more importantly, ensure that you have some decent rubber. That will have more of an effect than brakes when it comes to pulling up quickly.
Best advice given so far. Large brakes can only pull up as much rubber will allow it to. Bigger and more ventilated brakes just help reduce brake fade when consistently pushed hard.
Originally Posted by M3_DU View Post
Are you going to track the car? If not just upgrade to some M3 brakes and save yourself a whole lot of money. Pads and discs will be cheaper in the long run too.
This is also good advice. Quality rubber and Tire width is more important.
Turbo BMW is offline   Reply With Quote
Old 10-03-2012, 05:18 PM   #48
Bmw328monster
My Ride: 2000 328i
Is this for $750 alright?
Porsche 996 calipers brake kit
Bmw328monster is offline   Reply With Quote
Old 10-04-2012, 12:20 AM   #49
MBM330i
My Ride: e46 330i
Yeah this is a popular upgrade. Good price too! I'm still looking to get a set and thinking I'll get the ecs set.
E46 318i with transplant 3.0M54 5sp manual
Still have the original washer bottle under the hood
WTB new washer bottle
MBM330i is offline   Reply With Quote
Old 10-04-2012, 04:00 AM   #50
Mitch E46
My Ride: M3 Convertible
I think I have those on my rears, pretty nice calliper..great price for $750.
Mitch E46 is offline   Reply With Quote
Old 10-04-2012, 12:07 PM   #51
johnca
Modded ///Member
johnca's Avatar
My Ride: E46 Slow CSL
Very good price, make sure you will clean the pistons and check if any leak before you use them,
What's the rotors size? I hope they don't look the same as stock. yes you will see how different between stock brake 1piston vs 4 pistons. if you need any help i'm happy too
johnca is offline   Reply With Quote
Old 10-04-2012, 06:52 PM   #52
Bmw328monster
My Ride: 2000 328i
No the rotors are huge. I was tol by the guy who i bought them from to buy hawk pads and racing fluid as well otherwise it would be a waste.
Old 10-04-2012, 08:17 PM   #53
Mitch E46
Here is some motivation...
Brembo GTR 6 Piston Front, 4 Piston Rear:
Old 10-04-2012, 08:23 PM   #54
ating
My Ride: 2004 M3
^ yours Mitch? wow nice. I need a BBK...
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 10-04-2012, 08:40 PM   #55
Mitch E46
yep, same setup as Johnca!
Old 10-04-2012, 09:03 PM   #56
ating
My Ride: 2004 M3
Nice. Mind PM'ing me where you got it from and how much? Thanks.
Old 10-04-2012, 09:05 PM   #57
Davconelectric
My Ride: Mainly cars
Not to sound negative, but unless your racing your car. Their a waste anyways, unless your just after the look. In which case no need to get anything better than stock pads and fluid. What size rotors are they?
Davconelectric is offline   Reply With Quote
Old 10-04-2012, 10:34 PM   #58
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
wow.. for once the australians are answering an American, whos posted in the Aus section, without telling to F**K OFF ..
Good job !!
#LetsAllGetAlong
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 10-04-2012, 11:10 PM   #59
E46 Coupe
E46 Coupe's Avatar
Good job !!
#LetsAllGetAlong
F**K OFF ygo...
Old 10-05-2012, 09:13 PM   #60
johnca
Modded ///Member
johnca's Avatar
Good job !!
#LetsAllGetAlong
It's ok bro I'm sure Australians have better answers than others that's why he posted here ...^^
