Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 204 votes, 5.00 average. Display Modes
Old 01-16-2014, 04:11 PM   #881
JJR4884
My Ride: BMW
i have an old sh*tty model
i'll have a new one in the next couple months, hate to say it but this thing has seen better days. i need a new one that has better interface and can run bluetooth with navi. are there any available that have XM/Sirius or coming out soon?
JJR4884 is offline   Reply With Quote
Old 01-23-2014, 11:35 PM   #882
Jsshiver
My Ride: 2002 BMW 325i
Just installed the D99 last weekend. Still can't figure out why the radio won't pick up ANY stations? Fuse #7 is fine... Connections at the aerial amp on the C-pillar have been checked... I've tried toggling the RDS, the Auto Ant., Area, and the AMP settings on the dynavin factory settings menu... This is driving me absolutely crazy. I use bluetooth for audio mostly but it still kills me knowing I can't listen to radio if I wanted to.
Also, I got a pencil-looking tool, which I'm assuming is a stylus... but I can't figure out why I got a 3V lithium battery with the unit. What do I do with this?
Jsshiver is offline   Reply With Quote
Old 01-24-2014, 12:31 PM   #883
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
read my FAQ, you probably have the old style antenna....OR your antenna adapter is damaged. If you get NOTHING its more likely the latter.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 01-24-2014, 12:42 PM   #884
Jsshiver
My car was produced in January 2002. How Do I know that I need the Metra adapter? And if the antenna adapter that I already have is damaged (my radio worked fine with the business cd 2 weeks ago), do I need to buy the Metra adapter anyway?
And what is this lithium battery for?
Old 01-24-2014, 01:01 PM   #885
J&T Distributing
My Ride: BMW
Which antenna adapter did you use? If you used the short round adapter then you have the early type antenna system, if you used the square plastic plug you have the later style antenna system
To see if an antenna adapter is ok you can use a multimeter to check for continuity on both the center pin and the outer ground at both ends of the adapter (there should be continuity), then check between the center pin and the ground (there should NOT be continuity)
The battery is for the remote. Based on your questions I assume you bought this unit second hand?
Old 01-24-2014, 01:05 PM   #886
Jsshiver
I used the plastic plug. and the battery is not a coin cell-- its a round cell... can't be for the remote. I'll have to run out and get a multimeter to check the continuity I guess.
And no, I actually bought the unit from you, J&T Distributing.
Old 01-24-2014, 01:19 PM   #887
J&T Distributing
My Ride: BMW
Before you run out and buy a multimeter just visually inspect the adapter for damage...bent/short center pins etc....email me about it, no big deal, I can get another one to you.
No idea what that battery is in there, probably just got dropped in there somewhere along the line. It doesnt have anything to do with the dynavin.
And for future reference, If you bought it from us then just email me if you have issues like this, no need to post here where I may or may not see it when you can contact me directly.
Old 01-24-2014, 01:25 PM   #888
Jsshiver
Ok, I'll take a look at it... and I actually went to contact J&T last night and realized that I was reaching the same person. As I posted on here first, I just didn't send the email.
I'll shoot you an email when I get the chance to look at the adapter.
Old 02-23-2014, 08:55 PM   #889
latreille
My Ride: e46 m3/ s2000
I just bought a dynavin d99 off a member and can't seem to get the steering wheel controls working. Any Ideas, the ibus box is connected.
latreille is offline   Reply With Quote
Old 02-23-2014, 08:56 PM   #890
latreille
Old 02-27-2014, 01:49 PM   #891
J&T Distributing
My Ride: BMW
check your wiring......if that checks out then it should be working unless your car or dynavin has issues elsewhere....being used its hard to say.
Old 02-28-2014, 07:25 AM   #892
latreille
The wiring is good, my ibus light is on, and my steering wheel lights work so they should be good. The previous owner says he flashed the ibus for his back up camera. Could this be the culprit and how would I flash it back to factory settings.
Old 02-28-2014, 12:00 PM   #893
J&T Distributing
My Ride: BMW
This is an E46 unit? Are you sure its a Dynavin and not a knock off? The E46 dynavin does not have its camera trigger controlled from the ibus box but some of the knock offs do so flashing the box for camera reasons is not making sense to me......flashing the box for PDC reasons WOULD make sense though......maybe just a misunderstanding?
This is going to sound dumb but also make sure the ibus box is plugged in all the way, sometimes people think its plugged in all the way but its not.
Old 02-28-2014, 04:54 PM   #894
latreille
Its not a knock off and the ibus box light is on. May be I miss understood what he was saying about the reflash.
Old 02-28-2014, 05:50 PM   #895
J&T Distributing
My Ride: BMW
email me about this and I can email you the reflash tool for the ibus box so you can give it a try.....
Old 03-02-2014, 01:27 PM   #896
kdoubt
My Ride: 330i
I just recently purchased my car and have something similar (but not dynavin I believe) running wince6 however It appears the screen is locked. Does anyone know how to unlock this? I dont believe I have the remote, but I do have a harmony if anyone can tell me what frequency/channel/etc to set it to?
I cant get anything done properly with the message. Any time the Navi side is on, it pops up and blocks everything. Take trades towards an andrioid?
Edit: I reset the HU to factory. Appears gone now. Almost checked myself in to the hospital.
kdoubt is offline   Reply With Quote
Old 03-02-2014, 08:47 PM   #897
latreille
Pm sent
Old 03-03-2014, 08:58 PM   #898
latreille
Still no luck, must be something with my car.
Old 03-08-2014, 12:18 AM   #899
SeanMiller
My Ride: 04 BMW M3
Few questions concerning my D99 bought in December 2012 for a 2004 M3. When setting the radio presets, I hold down the button a few seconds, and the station is captured, but on the button display it captures the artist name that is currently on the station. I would like for it to capture only the station frequency. Also, my M3 did not originally come with the nav screen, so I do not have the ability to see any of the OBC on the factory stereo (obviously), and was wondering if there is a way to see more on the Dynavin than just the temperature of fluids, and liters of fuel (gallons would be nice too), most of the info does not display. And my last question, and the reason I am actually posting questions, where, if any, are the firmware updates for the non Android D99?? I have heard there are some updates for functionality, but I haven't seen anything. Oh yea..and sometimes a small portion of the screen goes blank, or I get a pixelated effect in a small area, thus why I am looking for some updates. Thanks in advance for any help.
SeanMiller is offline   Reply With Quote
Old 03-20-2014, 12:02 PM   #900
J&T Distributing
My Ride: BMW
when you set a preset it will "capture" whatever text is in the RDS text display area, the idea is that you can "name" your presets by setting them when the radio station name is displayed.
The OBC screen displays what is available on the ibus, that varies by car.
The android ROM is on Dynavins website, no need to reflash it if yours is working.
The pixelated thing you are describing has nothing to do with android, its actually related to the ibus interface box firmware. It can be updated, contact your dealer for assistance.
d90, d95, d98, d99, d99 navigation system, dynavin, dynavin android, dynavin d99
