Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 204 votes, 5.00 average. Display Modes
Old 03-22-2014, 03:04 PM   #901
Leading Edge
My Ride: M3 Cab
After having had troubles with bad GPS reception on my Dynavin D99+ the problem is now finally solved :-) I had the GPS antenna mounted on the steel bracket under the dashboard but reception was really poor. Took me up to five minutes to get a fix sometimes and I often lost GPS signal after I got it. The accuracy was also really bad. I rarely got more than three or four sattelites in fix. Donīt have to say it was really annoing. To put the antenna somewhere visible was absolutely out of the question.
Today I relocated the antenna up inside the room behind the panel where the external mic is supposed to be in the roof light at the center mirror. The cable is hidden behind the linings and down through the glove box to the unit. Everything completely hidden. It was just like getting a new unit. The GPS get a fix really fast and I get high accuracy very fast and never loose reception. GREAT SOLUTION!! I have a E46 Convertible.
Leading Edge is offline   Reply With Quote
Old 04-03-2014, 12:19 PM   #902
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Verts only, keep in mind there is no roof panel, try that on a sedan and its not likely to work at all.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 07-16-2014, 04:03 PM   #903
mwikina977
My Ride: 2001 BMW 330CI
Originally Posted by jeffb325@NavigationSolutions View Post
I believe it is configurable.....so you can have the backup cam video with the PDC sounds....I think....I will need to confirm.
the first batch of D99 E46 units had an error in the harness that goes to the ibus interface, the white and blue wires are backwards, so swap them and everything should work fine.
Your dealer should have alerted you to this......we fixed every harness we had in stock and emailed instructions on the fix to the few that had already shipped.....
Can you forward me a set of those instructions? mwikina977@gmail.com
mwikina977 is offline   Reply With Quote
Old 07-18-2014, 12:15 PM   #904
J&T Distributing
My Ride: BMW
???? That is for something that happened years ago!? Not at all relevant now.
Old 10-04-2014, 10:05 AM   #905
smileydawg
My Ride: 05 bmw 525i
Exclamation help needed
I have a 05 bmw 525i
ok I installed the d99+ dvn-e60-t but the problem is it isn't playing any sound when I try use sd or I pod it's showing it playing but nothing also it is not picking up the cd changer an if I use the main player it would play but I would have to change it from the deck
smileydawg is offline   Reply With Quote
Old 10-04-2014, 12:05 PM   #906
Gully
My Ride: E46 M3
Thanks for the GPS information "Leading Edge", I will have to give this a try.
Gully is offline   Reply With Quote
Old 10-09-2014, 07:15 PM   #907
cireericd
My Ride: 05 BMW 330ci
My navigation on my d99 has no voice guidance,even after turning it on in the sounds settings,it just beeps. is there a way to turn voice guidance on?or anyone selling a sd card with new navigation software,so i can just replace my existing one,thanks.
cireericd is offline   Reply With Quote
Old 10-19-2014, 09:26 AM   #908
amit710
My Ride: 325 ci sport SSG/SMG
D99+ to n6 firmware
Hi
Iv just seen the n6 software and looks like big improvements. Is thi firmware compatible with the D99+ DVN-E46-T
Amit
amit710 is offline   Reply With Quote
Old 10-19-2014, 12:05 PM   #909
J&T Distributing
My Ride: BMW
No, the N6 is a new unit, its not software....
Old 12-20-2014, 09:28 AM   #910
Gully
My Ride: E46 M3
Dynavin keeps switching on and off.
Can anyone help, for no obvious reason it keeps switching on and off.
It has been working fine for more than two years and now Iam getting this problem,
It will switch on okay and after a few seconds it will go off and then come back on again.
I would be grateful to any ideas on where to start looking for a problem.
Old 12-30-2014, 07:23 PM   #911
cnscm2614
My Ride: 2002 BMW M3
d99
Hi Jeff. is it possible for you to sell me an android sd card with d99 firmware on it.
i bought the head unit a while about 2 years ago but the seller did not give me the sd card. thank you
cnscm2614 is offline   Reply With Quote
Old 05-12-2015, 02:31 AM   #912
Brad Satt
My Ride: e39 & e21
Originally Posted by CTRob View Post
Jeff you star and I appreciate the help even though I have an e39 folks thanks very much
Yes agreed, Jeff you are star
I have same issue with CTRob about PDC indicator on my D99 screen every 60 seconds on my e39
Just install D99 with reverse cam without PDC. Will try your suggestion to use relay. Will back inform the result
Read all 21 pages of threat with thanks it really usefull threat
Brad Satt is offline   Reply With Quote
Old 05-12-2015, 04:54 AM   #913
Gully
My Ride: E46 M3
+1, As requested by: cnscm2614. If a firmware update is available for the D99 unit I would also be interested in purchasing one from you.
Thanks in advance Gully
Old 12-24-2015, 11:38 AM   #914
mwikina977
anyone know where to get firmware updates?
01 330CI SPRTPKG . kw v2 coilvers . mtc fcabs . dynavin d99 . powerflex rtabs ( black series) . Rouge engineering muffler . 18" oem ZHPs. M3 front sway bar
Old 01-19-2016, 09:59 PM   #915
spalyok
Help updating
we dont do group buys, they are always a disaster. Big demand an small supply means the price is the price. This is not the forum for sales inquiries though, email me for that. Thanks.
Just purchased a m3 with the d99 in it. How do I upgrade the firmware? Any help would be appreciated
spalyok is offline   Reply With Quote
Old 05-26-2016, 11:30 PM   #916
Davedoesskids
My Ride: E46 325i
Have asked before - long shot, but does anyone have the extension cable for the d99 to the rear of the e46 sedan?? Have you upgraded and have it sitting around? I would like to purchase it off you! thanks
Davedoesskids is offline   Reply With Quote
Old 09-03-2016, 12:45 PM   #917
30seconds
My Ride: M3 vert
I have a D99 (from Jeff) since late 2013. Great unit. But the navigation keeps coming up "Can't find navigation software" so I figured I would update the unit. Can't find anything on the unit itself (have searched) but only the naviextras. Should I just try that or is there firmware updates?
30seconds is offline   Reply With Quote
d90, d95, d98, d99, d99 navigation system, dynavin, dynavin android, dynavin d99
