Thread Tools Search this Thread Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Old 01-04-2012, 09:50 AM   #1
paraklas
My Ride: ESS TS2 320ci
Official DIY: Quad Bi-Xenon conversion. Complete with more than 100 pics
THE QUAD BI-XENON - FXR PROJECTOR RETROFIT
After getting used to the "normal" light output of my Bosch Bi-Xenon projectors, I decided to make a "small" modification. To retrofit another set of Bi-Xenon projectors in the place of the high-beam halogens. This will essentially give 4 driving lights and 4 high beams. The only downside to this mod is that the flash-to-pass capability is lost, since when you flash with the lights off, the only thing it will be accomplished, is to open/close the bi-xenon shutters. However, there is a workaround for this which will be covered in a new mod after my hands get well from this one.
Parts List:
1. 2x FXR Bi-Xenon Projectors for RHD Vehicles with 2x 35W Ballasts and 2x 35W D2S Bulbs (www.theretrofitsource.com)
2. Wiring loom (2x Relays, Ground, 12v Power source, Signal Source, 2x 12v Out)
3. High-Beam splitters to feed both Bi-Xenon shutters (I didn't use them as I preserved the original Bi-Xenon source and for the FXR I used the high-beam power source directly)
4. 2x E46 Projector Shrouds with Adapter Rings
5. High Temp Epoxy, High Temp Silicone and Loctite 6. Aluminum tube, 6mm internal diameter
Phase 1: Preparation
Shiny shrouds
Ballast closer
23KV. Enough juice!
Weather-proof wiring loom connectors
High-Beam Bi-Xenon splitters (single source in, dual out)
FXR Projector. The Bi-Xenon shutter does not have polarity therefore 2 Red wires coming out of it.
D2S Bulb Holder
Projector Front
Test fitting the adapter rings
Flimsy plastic brackets (will be removed) to give way to epoxy glue.
Using a dremel with sanding unit on, I roughened both inner shroud surface and adapter ring surface. This was done to ensure proper adhesion of epoxy glue.
Sanded surfaces:
Glue to be used. I really like using this glue as it is very strong, ideal for such work, takes time to harden allowing minor adjustments. Once it settles, it's as hard as metal.
Epoxy all over the place, but we don't care as it will not be visible at all.
To accelerate settling process, I chose to let the shrouds "bake" for 1 day next to my house heater element. I didn't over heat them, I just let them to get warm to the touch.
paraklas is online now   Reply With Quote
Old 01-04-2012, 09:51 AM   #2
paraklas
Phase 2: Disassembly Process
Tools needed:
Before surgery:
1. Remove indicator by loosening screw (1.)
2. Remove lower headlight trim by pulling towards you (2.)
3. Remove 8mm bolts (3. and 4.). One is behind headlight and another one is to the righ side of it. (Other side is mirrored and not shown)
My brake booster aka drug bin cover, underneath of which the relays and connections will be done at a later stage.
Hard disk magnet is good at catching screws that accidentally fell at random spot in the engine bay.
Extensions on my electric screwdriver to reach headlight bolts.
Airbox has to come out as well to give space. Before removing the headlights, don't forget to unplug everything, else you will be looking at buying new plugs from dealer.
My car in "blind mode"
Last view before disassembly process begins
The basic: Take the rubber weather strip out from the 4 prongs. If it's rotten, time for a new one from dealer. www.realoem.com for part numbers.
And onto my work bench:
Remove the headlight cover by lifting the 3 plastic tabs on the top, working your way around it. The pre-facelift cover is not glued and should pop out once all prongs are released from tension.
Also remove the inner headlight trim by pulling outwards you from the 4 corners. Since we only have 2 hands, you can make one side each time.
Remove low beam covers and set aside.
Although not necessary, in order to remove the ballast, you'll need to remove the 3x T20 screws that hold it in place:
Back to the headlight now, D2S plug (twist to remove), D2S holder (twist to remove) and bulb removed and set aside. To remove the high-beam halogen bulb, just twist and remove the corresponding bulb holder plastic prongs. If you can't manage this then it's just better to put back everything in place and forget this mod.
Two power drills are used to rotate clockwise both headlight adjustment knobs until you hear the guides inside reach the end. A characteristic pop noise will be heard.
I set the torque to low so that in case an obstacle was found during this process, the drill would just stop and damage would be prevented.
After finishing the two adjustment knobs, the hardest part of the process is to remove the leveling arm from the headlight lense assembly. Before that, we unplug the little 3-wire connector as seen below. Then we need to pry the arm off and pull the lenses at the same time. It can be done by pushing down or up. Just be careful not to break the white plastic.
After a lot of anger, fear to break things, the headlights finally came apart:
Front view. Surprise, the OEM projector had a layer of dust on it. I let it like that since cleaning would be the last step before re-assembly
Took out the angel eyes
Now it's the moment of bravery. Look (for the last time) the high-beam reflector that you are about to cut. Put the protective gear (gloves, eye mask, breather) and start dremeling around the holder
DONE! If you regreted doing this mod, now you will need money to go back.
The FXR Projector is an all aluminum construction, which is good. However, the lower parts need to be grinded to allow it to drop within the halogen housing enough in order to fit the shrouds in front. I drilled new lower holes after grinding.
Small cut out was done right at the bi-xenon mechanism to allow wires to come out and to push the projector further back in place.
After a lot of trial and error to get the projector grinded correctly, it finally sit in place. I used the E46 shrouds as guides to sit it flush with the halogen housing.
Drilled 4 holes to allow bolts to pass through.
4 stainless steel bolts with nuts secured on the projector and loctite used. We don't want them coming loose, else a complete disassembly will be required to fix this.
Old 01-04-2012, 09:52 AM   #3
paraklas
This aluminum tube was used to make some adapters, to allow the nuts to sit flush on the high beam outer housing. Self explanatory from the pics below:
Epoxy used on 4 sides to secure everything together as well as high-temp silicone for the middle section. Silicone allows for some elasticity just in case minor adjustments are needed.
European E46 have an additional 5w wedge bulb within the halogen housing, which is now not used. The existing hole is ideal to route all additional wires outside of the headlight housing. In my case, angel eyes and bi-xenon wires.
Refitting angel eyes back and pray that they will still work after all this fiddling.
Phase 3: To put back the inner headlights:
1. Bring both parts as close as possible. Fish the wires out of the hole
2. Align the 2 upper leveling guides with the adjustment knob screws on the housing. Turn the knobs a bit until they catch the guides.
3. Now push the lower middle section of the inner headlight assembly until it pops back in the leveling arm (the one it troubled us before). Use the power tools to rotate both knobs counterclockwise to pull the lenses back now. Verify movement and proceed.
4. Clean everything and blow some compressed air to take away any dust from the lenses
5. Re-install D2S bulbs, holders and covers, to reveal a nasty surprise: the high-beam rubber cover is too big for the D2S bulb.
6. Silicone used to seal gaps and holes, D2S bulbs (now 4) secured in place
Test fitting the front headlight trims to find out that they don't fit as well now.
Marking the trim for cutting.
Proud to see that I managed a perfect cut.
Headlight trim should fit in place now. Clean everything and re-install, paying attention to ensure that the headlight cover is dust-free and clipped all around.
Sit back and admire your work, to find out that you have another headlight to do. (Trick: do both in parallel)
Back side now, to solve the gap problem on the rubber cover, I made the adaptor seen below. Now, what did I use to make that?
When I did a full suspension install, I got these spring pads as well which I never installed. Amazingly the hole in the middle is perfect for the bulb and bulb plug! Only need to reduce the outer diameter to fit inside the existing rubber cover
Cutting takes place with a knife that the sales person at pelican parts accidentally left in my brakes order
Use high-temp silicone everywhere. Once installed, nobody will see it. Also use plenty of PVC tape. The tape I removed for disassembly was cracked and was falling apart. This however left the wires inside intact.
[B]Phase 4: Now back to the car for the installation. [b]
Test fitting
Place that wiring will be placed. Safer than near the headlights for sure!
For a trigger signal to power up the additional xenon ballasts, I tapped on the Yellow-Blue wire as seen below, by removing the existing PVC tape to reveal the wires.
The wiring for one headlight was too short for my liking, so I extended it. I assume it was made short with the intention of mounting the relays near the headlights.
Common ground for relays, headlight signal and constant 12v source straight from battery.
Since the relays were mounted on plastic, I used 1 large washer on the outer surface to distribute the force of the bolt to prevent the plastic from breaking.
Connecting all plugs back
Weather strip back in place along with lower headlight trim. Airbox installed as well!
Indicators back
Red silicone nowhere to be seen!
Tiding wires and sealing any naked ones with tape.
Cover back in place
Old 01-04-2012, 09:54 AM   #4
paraklas
Phase 5: Moment of truth:
Angel eyes on and working!
Moment of truth 2: WE SEE THE LIGHT!
And that's it basically. Further tasks to complete:
1. Aim headlights
2. Remove warning light on dash by using the capacitor mod
3. Re-enable the flash-to-pass feature. I will use a changeover relay, with the following setup:
Lights off -> Provide power to a hybrid halogen-HID bulb (halogen part only, HID is reserved for fog conditions) located in fog lights when driver pulls the stalk for high-beams flash
Lights on -> Disable power to the halogen bulb so that the flash to pass uses the actual bi-xenon projectors.
None of this project could have been possible without the help of many threads that I went through on this site so a big thanks!
Old 01-04-2012, 10:09 AM   #5
toy4to
My Ride: 2004 M3 AA Gen6 1.5
Wow, very detailed pictures of the process. Thank you very very much!
toy4to is offline   Reply With Quote
Old 01-04-2012, 04:49 PM   #6
saladin
My Ride: 2004 325ci
thanks a lot!
saladin is offline   Reply With Quote
Old 01-08-2012, 10:07 AM   #7
J0se
My Ride: e46 coupe facelift
thanks for the DIY !! What's the color temp. of the bulbs? 6000k?
J0se is offline   Reply With Quote
Old 01-08-2012, 12:37 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Nice! My only suggestion is that you should have bought the ZKW clear lenses for your OEM projectors.
Old 01-08-2012, 01:44 PM   #9
paraklas
4300K, OEM Osram Xenarc D2S bulbs
Do they have a better cutoff than the Bosch?
Old 01-17-2012, 11:06 AM   #10
Tate325xi
My Ride: 325xi 5MT
Great DIY!
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 01-24-2012, 09:51 PM   #11
328redleather
My Ride: 328ci white/red
omg!! love it
2000 328ci alpine white on tannin red leather
328redleather is offline   Reply With Quote
Old 02-24-2012, 02:23 PM   #12
manzrik
My Ride: e46 320d
you are great!!!nice work!!!
i have retrofitted bixenon in my car ,but i have build two circuits that control shutter of bixenon and halogen of highlight...
great man...i saw your work of carpc...i had thinked of make it similar...but i have mod a radio 1 din7' and now it's like the dinavin!
very compoliment to you again
manzrik is offline   Reply With Quote
Old 02-24-2012, 05:54 PM   #13
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
as always, your DIYs amaze me. great step by step instructions and lots of pictures!
wonderful!
G-Hots is offline   Reply With Quote
Old 02-25-2012, 12:29 PM   #14
paraklas
Thanks! The full power of this mod can be noticed when traveling at very dark roads, with the high-beams on, it's like daylight
This week I plan to retrofit some hybrid bulbs on the fog light housing. I now have 3000K HID for fogs, which will be replaced with a hybrid 3000K Xenon / Halogen bulb. The xenon part will be for the fogs whereas the halogen part will be for the flash-to-pass, meaning it will be connected by a splitter with the OEM high-beam source. More to come
Old 03-19-2012, 09:10 PM   #15
bufu-m3
My Ride: 01 M3
I've been waiting for this DIY for a while now. Were all parts purchased through theretrosource? If so, which wire loom did you order also, I have halogen hi-beams, would I still need the hi-beam splitter or would I just tap the hi-beam to the 2 red wires coming from the FX-r?
bufu-m3 is offline   Reply With Quote
Old 03-19-2012, 10:10 PM   #16
WALKD U
My Ride: Just Fast!
Nice diy!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 03-20-2012, 02:11 AM   #17
paraklas
Yes everything through retrofitsource, Andrew or Matt are great guys and very helpful to get the correct parts. I didn't use their high-beam splitter, I just plugged the solenoid 2 red wires straight to the high-beam source. Forgot which wiring loom I ordered, it was the standard one I think, 2 relays basically nothing weird or so. Could had easily done it myself but their loom is more tidy.
Unfortunately, one of the FXR high-beam solenoid has gone bad after 3 days of use which will force me to take everything apart to replace it
They shipped me a new solenoid under warranty of course without any hassles.
Originally Posted by TrippinBimmer View Post
Nice diy!
Thanks! Getting ready to order another set of FXR to replace my stock low-beam bosch projectors now as I really like the new cutoff. Will also make the setup cleaner in regards to wire management.
Old 03-20-2012, 03:40 AM   #18
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Awesome thread! Thanks for the detailed pics
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 03-20-2012, 03:55 PM   #19
trizzuth
My Ride: 234k, 16yr old B3AST
This is just crazy, and I thought I was a boss back in the day creating my own DEPO projectors with angel eyes from scratch!
Items of note however:
God I hope you don't get any condensation build up inside those lenses ever, and have it be due to the silicone somewhere rather than the lens gasket.
WTF is up with your angel eyes? They dip below the plastic headlight shroud so they don't even look good?
This is a LOT of work, for something that historically, has always given me problems until I finally got some LED angel eyes so no more one out one day, one out the other... etc. I admire your courage to just start cutting things left and right, now that is committment!
trizzuth is offline   Reply With Quote
Old 03-21-2012, 04:16 AM   #20
paraklas
No condensation whatsoever, have in mind I let the silicone dry completely before sealing.
Angel eyes, yes they go below the shroud because it was not in place correctly That caused more issues as I tried to adjust the headlights and the angel eye hit the shroud putting stress on the mechanism causing the adjustment knob to pop out of place Will be corrected in the v2 of the project as I'm replacing the low-beam bosch with the FX-R 3.0 lens! Just waiting to sort some things with the guys at retrofitsource (i.e. if I can re-use my OEM shrouds etc).
I have these CCFL angel eyes since 2006 without an issue at all so I'm a bit reluctant to swap to LED without reason. Sure, the LED are brighter and don't require ballasts, but I'm working with the logic if it aint broken, don't fix it. Besides I'm still not convinced about how reliable the LED are, as a single burnt diode will probably look ugly
