pulsating idle when AC is on - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-05-2010, 01:14 PM   #1
antoniostarr
My Ride: 2002 325Ci
When I am sitting at a light and turn on the AC the engine starts to idle erratically. I fI turn the AC it instantly begins to idle as normal. I've done a but didn't find anything specifically related to rough idle only when AC is on.
Any suggestions on fixing this?
antoniostarr is offline   Reply With Quote
Old 06-05-2010, 01:31 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Do you have an automatic or an aux fan in front of the radiator? You might have a vacuum leak as well.
Old 06-05-2010, 01:35 PM   #3
antoniostarr
My Ride: 2002 325Ci
forgive me I don't know the difference between the two. It looks like this fan
Old 06-05-2010, 01:36 PM   #4
antoniostarr
My Ride: 2002 325Ci
I was thinking vacuum leak as well but after I drive with the AC for a while the pulsating stops.....
Old 06-05-2010, 02:01 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
That's an electric fan, mostly on manuals. Idk, I'd say a vacuum leak over everything else right now. I'm not really sure what else can cause it. Does the rpm drop or rise?
Old 06-05-2010, 02:07 PM   #6
antoniostarr
My Ride: 2002 325Ci
both! It goes up and down a few hundred rpms
Old 06-07-2010, 06:47 PM   #7
325myAZ
My Ride: 2001 325i
Could it be the Idle Control Valve?
I ask/suggest this only because I'm experiencing the same issue. The RPMs are only affected while the AC is on. Otherwise I idle fine. Sometimes while the AC is on, it drops down to 500 RPM or lower, then picks up again.
Of course it's happening now, while it's 105 here in Phoenix.
325myAZ is offline   Reply With Quote
Old 06-09-2010, 04:03 PM   #8
antoniostarr
My Ride: 2002 325Ci
Thats exactly what I get! I will look into that ASAP.
Old 06-13-2010, 02:41 PM   #9
mdrd
My Ride: E46 M3/E30 M3/LR4
my issue is when u first start up it idles roughly sometimes u have
to start it twice b4 it kicks in after few second car runs fine. Same
with the AC on idles roughly rpm goes up & down. Btw I have
06 M3 competition package with on 26k mls.
mdrd is offline   Reply With Quote
Old 08-19-2016, 04:11 AM   #10
mike6
My Ride: 328Ci
Just did a search for this because I'm experiencing the same thing. Did any of you end up with a solution?
mike6 is offline   Reply With Quote
Old 08-19-2016, 09:29 AM   #11
nutnut
My Ride: 330Ci
yesterday it started happening to me too
only happens when the engine is warmed up
nutnut is offline   Reply With Quote
Old 08-20-2016, 09:03 PM   #12
ericsonp
My Ride: 04 330i ZHP
I had this same issue 2 months ago, 04 ZHP...it went away after I replaced the MAF with an $270 OEM one (almost everything stopped((RPM)), Tensioner Pulley, Cleaned out IAC with Carb cleaner, pulled DISA and replaced orange circular o-ring, 6 new BOSCH ignition coils, and 6 new spark plugs ....
Oh, and MAKE SURE your A/C system is FULL, a lack of FREON will case an erratic idle every time you use the A/C and the Fan will stay on HIGH also, electric version!!!
ericsonp is offline   Reply With Quote
Old 09-12-2016, 05:33 AM   #13
nutnut
My Ride: 330Ci
a clarification: it happens whenever the engine gets heat soaked
the AC on is unrelated
it is just more likely to be on on a hot day when also the engine can get heat soaked easily
Old 12-01-2016, 02:21 PM   #14
Anthr76
My Ride: Alpine White 325Ci
I as well somewhat have this problem. It happens to me if I'm coming to a stop. The RPMs will dip and rise and you can hear a faint 'grind?' some type of noise I'm assuming coming from the compressor because it only happens when the A/C is on. It doesn't matter the temperature. I recently replaced my pulleys. I have a AUX fan
Anthr76 is offline   Reply With Quote
