Old 01-06-2012, 12:51 PM   #1
Vic328CSi
My Ride: depends on the mood
Installing bigger injectors before tune
Hi guys, I have 24lb/hr injectors in my supercharged 328 currently, and I want to swap them out for 42lb/hr FiveO injectors I just recieved, havent done it yet. Ive also swapped out the stock fuel pump for a walbro 255lph.
I have a shop that will do the tune for it. My question is, will I be ok installing the new injectors and driving the car gently to the tune shop about 15 miles away? The new injectors are quite a bit larger than what its replacing, i dont want to flood my cylinders with gas.
Comments, suggestions appreciated!
Vic
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 01-06-2012, 01:42 PM   #2
hassmaschine
My Ride: '91 325ix
the max fuel trim is somewhere around 15-20%.. your new injectors are almost twice as large as stock. No, that's not going to work.
hassmaschine is offline   Reply With Quote
Old 01-06-2012, 02:03 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I would do all that work, and get it towed to the shop. Clearly it's much cheaper to get towed, than let the shop do that install.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-06-2012, 02:42 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
What's driving your need for larger injectors - you upping the boost?
Old 01-06-2012, 07:06 PM   #5
Vic328CSi
Good luck.
yep trying to do the install myself since its a simple job, think ill just tow it.
did a dyno, running very very lean dont think the injectors are keeping up, been advised I need 38-42lb for the power im making/trying to make. look at my afr, also lack of proper tune.
e46 328Ci 9psi SC
Old 01-07-2012, 12:13 AM   #6
midnighttuning
My Ride: 330ci
Vic
3 options
1. Get a tow
2. Decrease fuel pressure for the trip with a aftermarket FPR, then set back to stock PSI.
Cheers
BarrieM/// BMW Tuner
midnighttuning is offline   Reply With Quote
Old 01-07-2012, 09:19 AM   #7
ZeroSum
My Ride: 05 325
3. Install bigger injectors when you get to the shop - (seems like the easiest option unless I am missing something?)
ZeroSum is offline   Reply With Quote
Old 01-07-2012, 12:58 PM   #8
Vic328CSi
now why didnt i think of that! lol
e46 328Ci 9psi SC
Old 01-07-2012, 05:14 PM   #9
ZeroSum
My Ride: 05 325
lol - don't worry i'm sure you would have thought of that at some point.
Good luck with the tuning BTW
Old 01-08-2012, 08:38 AM   #10
Terrence328T
My Ride: bmw e46 328 turbo
hi guys, did you drop the compression to fit the sc. i just turbocharged my 328 running lean aswel
Terrence328T is offline   Reply With Quote
