Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 06-07-2012, 04:44 PM   #201
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by Dan330Ci~ View Post
I have the same radio block off plate, did you mount any dials or displays in yours?
No, I haven't. I used the space below the climate control. If I run out of room I may want to add some gauges up there.
Old 06-07-2012, 08:09 PM   #202
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
255s all around.
Old 06-08-2012, 06:44 AM   #203
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by aggieE46 View Post
255s all around.
Do you rub? In the front on heavy corners? Guess I need to start researching! another issue trhat is hurting traction is my rear camber. I'm considering these what you guys think? http://www.treehouseracing.com/compo...be33d0bb11.jpg
Old 06-08-2012, 08:05 AM   #204
aggieE46
Keep it clean
aggieE46's Avatar
Nope, I've never rubbed. Maybe I'm a pansy driver, though.
Old 06-11-2012, 07:28 AM   #205
xixixi
Banned User
My Ride: 01 330x-xi
dyno today
Old 06-11-2012, 10:41 AM   #206
aggieE46
Keep it clean
aggieE46's Avatar
Woot!
Old 06-11-2012, 11:11 AM   #207
TxZHP04
My Ride: ESS TS2+ ZHP
255 on 18x9 square here as well. No rubbing although the sedan rear fenders needed to be rolled to avoid rubbing in the rear. The key up front is having the right wheel offset, a fair bit of camber, and not going too low (otherwise it can start to rub the outer edge of the fender liner at the top of the arch). How much rear camber are you running?
Old 06-11-2012, 11:38 AM   #208
STORMER
My Ride: AA SC 98 M3
In for numbers
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-11-2012, 02:56 PM   #209
xixixi
Banned User
My Ride: 01 330x-xi
Gonna use a different dyno today. Thinking Shark run then stock tune then 1 run with nitrous.
Old 06-11-2012, 02:58 PM   #210
xixixi
Banned User
My Ride: 01 330x-xi
Not sure tbh, enough so the tires wear noticably more on the inside. I should have it aligned nest weekend.
Old 06-11-2012, 03:00 PM   #211
aggieE46
Keep it clean
aggieE46's Avatar
Nitrous plus shark? Or nitrous plus stock?
Old 06-11-2012, 03:14 PM   #212
xixixi
Banned User
My Ride: 01 330x-xi
I would like to see what the shark does vs stock without the juice of course. 3 completely different pulls. Will have video!
Old 06-11-2012, 03:23 PM   #213
aggieE46
Keep it clean
aggieE46's Avatar
I'd like to see how the Shark handles the nitrous (hopefully you can get a wideband on there).
Best of luck. Did you get my picture?
Old 06-11-2012, 03:32 PM   #214
RKiepper
My Ride: 1999 E46 328I x2
RKiepper is offline   Reply With Quote
Old 06-11-2012, 04:31 PM   #215
STORMER
Hmmm yes shark plus nitrous lets seee it
360+rwhp
Old 06-11-2012, 07:19 PM   #216
xixixi
Banned User
My Ride: 01 330x-xi
graphs coming very soon. along with video!!! The shark was better for the nitrous, afr's looked a lot safer. Spraying sooner made for a much smoother graph.
Old 06-11-2012, 07:34 PM   #217
xixixi
Banned User
My Ride: 01 330x-xi
shark vs stock Look at those AFRs! This is 4 gallons 93 1 gallon 104
Name:	shark vs stock.jpg
Old 06-11-2012, 07:36 PM   #218
xixixi
Banned User
My Ride: 01 330x-xi
first nitrous run didn't work so well.
Name:	n20 run 1.jpg
ID:	455890   Click image for larger version
Old 06-11-2012, 07:37 PM   #219
xixixi
Banned User
My Ride: 01 330x-xi
Final run,Shark +juice. Next week more nitrous. This is only a 50shot.
Name:	stock vs n2o + shark.jpg
Old 06-11-2012, 07:40 PM   #220
xixixi
Banned User
My Ride: 01 330x-xi
Here is the last dyno that was done. It is the shark plus nitrous.
nitrous kicks in at about 24 seconds
