Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 01-29-2012, 01:06 PM   #61
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by Rob43 View Post
I laughed really hard () when I read this, because the only reason I "failed" was because it didn't have a side exit !
you gotta stop!!!
Old 01-29-2012, 01:23 PM   #62
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OK, seriously this is what I'd do if I were building an exhaust from scratch.
I would build a 3" directly off the header, this would go back 2 or 3 feet and merge into a 3" "cut-out" electronically controlled from the cockpit. As soon as it exited the "cut-out" on the most unrestricted side, this small length of 3" would be your side exit. The other exit out of the cut-out would go straight back & would be EXTRA MUFFLED, as in totally stock sounding. The way I'd use this is 90% of the time I'd drive around "in stealth mode", until I needed my 3" free flowing side exit; then I'd unleash the FURRY !
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 01-29-2012, 01:41 PM   #63
xixixi
Banned User
My Ride: 01 330x-xi
Would you cut the floor out? So the exhaust would exit the rocker? Or go with an oval pipe (clearance) try to achieve the same exit? Or just run it out before the rear tire? Under the rocker. If you want to draw something up!
ID:	434455   Click image for larger version
ID:	434456   Click image for larger version
ID:	434457   Click image for larger version
Old 01-29-2012, 01:55 PM   #64
Rob43
Rob43's Avatar
I'd run it out right before the rear tire with an oval pipe for clearance issues. I wouldn't bother with cutting into the body, to much time, & a pita.
Old 01-29-2012, 02:04 PM   #65
darksideracer69
My Ride: 01 325ci
Exactly the exhaust I was thinking about. I'm not sure if I want the side pipe to show or not.
Sent from my SGH-T959V
IMAG02051
Old 01-29-2012, 02:14 PM   #66
Rob43
Rob43's Avatar
This.
Make it so you can still jack up the car at that location.
Old 01-29-2012, 02:22 PM   #67
xixixi
Banned User
My Ride: 01 330x-xi
The oval pipe is 2.125" I have about 6.5" to 7" clearance. The pipe would need to be around 3 feet long. ($150) idk, seems like a lot of money really close to the ground.
Old 01-29-2012, 02:38 PM   #68
darksideracer69
My Ride: 01 325ci
You scared? Also, couldn't you essentially just get a 3in stainless pipe heat it up on one end, and make it oval with a hammer or press?
IMAG02051
Old 01-29-2012, 04:12 PM   #69
Rob43
Rob43's Avatar
Make your own 3" oval side exit pipe, clearly you some fabrication skills.
First take a sheet of 8" by 11" paper & fold it to: Cone shaped, then flatten cone into oval. Now since you can visualize what I'm saying, build it out of 18 gauge steel* sheet, one end is 3" round & the other end is whatever flattened oval dimensions you like. As long as it calculates to flowing the same or better than the original 3" round pipe.
*Fixed.
Old 01-29-2012, 04:30 PM   #70
darksideracer69
My Ride: 01 325ci
First take a sheet of 8" by 11" paper & fold it to: Cone shaped, then flatten cone into oval. Now since you can visualize what I'm saying, build it out of 18 gauge steal sheet, one end is 3" round & the other end is whatever flattened oval dimensions you like. As long as it calculates to flowing the same or better than the original 3" round pipe.
Seems like the difference in flow wouldn't even matter since its basically open headers.
IMAG02051
Old 01-29-2012, 07:06 PM   #71
xixixi
Banned User
My Ride: 01 330x-xi
Thanks for the input on the exhaust, finished up the new nozzle location. Gonna post the testing I did to find my spot. I should have the complete intake finished this week, still waiting on the heat reflection material.
ID:	434489   Click image for larger version
ID:	434490   Click image for larger version
ID:	434491   Click image for larger version
ID:	434494   Click image for larger version
ID:	434495   Click image for larger version
Old 01-29-2012, 07:52 PM   #72
darksideracer69
My Ride: 01 325ci
are you using wet or dry?
IMAG02051
Old 01-29-2012, 08:02 PM   #73
Rob43
Rob43's Avatar
Page one pics are a wet nozzle system.
Old 01-29-2012, 08:16 PM   #74
darksideracer69
My Ride: 01 325ci
yea thats what i thought, itz the besst
what muffler are you thinking of using xi?
IMAG02051
Old 01-29-2012, 08:24 PM   #75
xixixi
Banned User
My Ride: 01 330x-xi
I don't know on the muffler? Haven't really thought about it. What you guys thinking?
Old 01-29-2012, 09:29 PM   #76
darksideracer69
My Ride: 01 325ci
I was thinking of this, for me lol. But now it says out of stock hope they make some more.
http://store.edelbrock.com/edelbrock...tdesign-1.aspx
IMAG02051
Old 01-29-2012, 11:06 PM   #77
xixixi
Banned User
My Ride: 01 330x-xi
Nah, nothing like that. Thinking single pipe with a round muffler JDM style!
Old 01-30-2012, 07:06 AM   #78
darksideracer69
My Ride: 01 325ci
:screwy:
You're gonna wake up the cows over here in Texas with that shit.
IMAG02051
Old 01-30-2012, 12:55 PM   #79
Rob43
Rob43's Avatar
xi,
You want the quietest muffler possible if you go with my idea. You can of course still weld good looking tips on.
Old 01-30-2012, 09:14 PM   #80
xixixi
Banned User
My Ride: 01 330x-xi
xi,
I really like your idea, I'm still up in the air on the whole thing though! Got some updates today. Those lil rubber washer's were from the VCG. I took them and used them as bushings for my nitrous bottle mount. (saving $$$) The Second picture is the wrapped intake tube. I used the Aerolite material from EarlsIndy. It is better than the gold foil, and cheaper. Yes, the "real" gold foil that Ferrari uses/F1 cars etc is better. But it costs a zillion dollars! Third/Fourth pic is possible LWT carpet mod? Yes, I can sew and iron! Picture 5/6 are the intake installed. This was a long day, broke some things cut a hose too short... etc 2 steps back 1 step forward. Enjoy!
ID:	434709   Click image for larger version
ID:	434710   Click image for larger version
ID:	434711   Click image for larger version
ID:	434713   Click image for larger version
