Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 01-30-2012, 09:00 PM   #81
darksideracer69
My Ride: 01 325ci
Amber signals, you fail :p
Sent from my SGH-T959V
IMAG02051
Old 01-30-2012, 09:08 PM   #82
xixixi
Banned User
My Ride: 01 330x-xi
Haters gonna hate!
Old 02-01-2012, 08:42 AM   #83
xixixi
Banned User
My Ride: 01 330x-xi
Morning update got another part I needed today. This is the gas pedal mount, I broke during removal!
Old 02-01-2012, 10:35 AM   #84
murph1379
My Ride: 2006 M3
Originally Posted by xixixi View Post
The Second picture is the wrapped intake tube. I used the Aerolite material from EarlsIndy. It is better than the gold foil, and cheaper.
Is that the dinan intake tube wrapped, or were you able to buy one that fits from another source?
I really wish someone would start making a tube similar to the dinan again, it's just a stupid tube, it should be pretty simple!
murph1379 is offline   Reply With Quote
Old 02-01-2012, 10:55 AM   #85
TrippinBimmer
My Ride: Just Fast!
I will think about it....
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 02-01-2012, 10:57 AM   #86
darksideracer69
My Ride: 01 325ci
Lol its not even that hard. They sell that pipe online, cut to fit and you're done.
IMAG02051
Old 02-01-2012, 12:23 PM   #87
xixixi
Banned User
My Ride: 01 330x-xi
Dinan wrapped tube. I tried to make my own long tube, you need a manufacturing process to do it correctly. Injen has the best intake out in my opinion. But, they don't make one for 330s.
Old 02-01-2012, 12:30 PM   #88
murph1379
My Ride: 2006 M3
Cool, can you link to sources on the velocity stack and filter?
Old 02-01-2012, 12:42 PM   #89
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Take a look, same thing much cheaper.
http://forum.e46fanatics.com/showpos...2&postcount=85
I just got everything today, it looks Exactly like xixixi's photos. I'll take some pics later today, the two pieces fit together perfectly.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-01-2012, 12:53 PM   #90
xixixi
Banned User
My Ride: 01 330x-xi
http://www.bpi-us.com/
http://afepower.com/shop/details_new...sal&brandID=61
I don't want to mislead people, I currently have no inner fender lining on the drivers side of the car. I never run a fog light, I don't have the inner black lower grill part, either. I don't have a brake duct atm for the left side. This IS NOT PLUG N PLAY.
Old 02-01-2012, 12:53 PM   #91
murph1379
My Ride: 2006 M3
Thanks Rob, is it fitting ok? Any cutting required? (that's a no-no per our class rules)
Anyone have a source on a cheaper 3.5" tube?
Old 02-01-2012, 01:00 PM   #92
Rob43
Rob43's Avatar
Honestly, mine is sitting on a chair, it won't be in the car for at least a week or two. So as to making it fit, only time will tell.
Here's your source:
http://www.siliconeintakes.com/
Good luck.
Old 02-01-2012, 01:04 PM   #93
Bimmer0814
My Ride: 2005 325xi
Sexy
Bimmer0814 is offline   Reply With Quote
Old 02-01-2012, 01:14 PM   #94
murph1379
My Ride: 2006 M3
Awesome, thanks for the links. =]
If the pipe were a bit shorter, would it work with the fender lining and brake ducts?
Old 02-01-2012, 01:18 PM   #95
xixixi
Banned User
My Ride: 01 330x-xi
A fog light is 100% out of the question. Possible fender lining. You will need to cut/not run the corner under shields for the bumper. Brake duct no way. This filter is nearly 8inches in places. The shorter the pipe the more issues.
Old 02-01-2012, 01:31 PM   #96
murph1379
My Ride: 2006 M3
So you're saying there isn't enough room if the filter were an inch or two higher, high enough to clear brake ducts?
Sounds to me like the Dinan would be my only option then, without a velocity stack, or even using a Dinan-style filter, but pulling the velocity stack back to near the MAF, with a 3.5" to 6" adapter in front of it. Seems like that may cause more problems in terms of air velocity than it helps.
Old 02-01-2012, 01:35 PM   #97
xixixi
Banned User
My Ride: 01 330x-xi
Ok going to take a picture, gotta jack the car up to even install this thing, phone broke.. I repeat there is no way for the brake duct to work period.
Old 02-01-2012, 01:36 PM   #98
Rob43
Rob43's Avatar
Looking at this data, this simple velocity stack & new filter may really be worth something.
http://www.bpi-us.com/testing.php#test201
Don't tell anyone.
Old 02-01-2012, 01:44 PM   #99
xixixi
Banned User
My Ride: 01 330x-xi
Don't tell anyone.
lol, just don't try and take my refund for adding to the dyno info
Old 02-01-2012, 01:52 PM   #100
xixixi
Banned User
My Ride: 01 330x-xi
pics, really need another set of hands but I did my best! It's not even close. Higher you move that filter up the less room you have. The red circle is where your brake duct is suppose to mount. Any higher that filter will hit the frame.
ID:	435006   Click image for larger version
Name:	modded intake pic.jpg
