Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 02-01-2012, 03:00 PM   #101
murph1379
My Ride: 2006 M3
Originally Posted by Rob43 View Post
Looking at this data, this simple velocity stack & new filter may really be worth something.
Yeah, that's basically what the aFe is.
murph1379 is offline   Reply With Quote
Old 02-01-2012, 03:01 PM   #102
murph1379
My Ride: 2006 M3
Originally Posted by xixixi View Post
pics, really need another set of hands but I did my best! It's not even close. Higher you move that filter up the less room you have.
Ahh I see, thanks for the pics!
Old 02-01-2012, 03:07 PM   #103
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by murph1379 View Post
ahh i see, thanks for the pics!
np
Old 02-01-2012, 03:59 PM   #104
murph1379
My Ride: 2006 M3
btw, sorry for the big threadjack, you're definitely on the right track with your build, but don't forget the suspension! (psst... I have a set of AST 4200s for sale for a good deal...)
When Vorshlag starts working on the custom catted downpipes for the shorty headers I'm planning to use, I'll try to update with that info, for the benefit of everyone else. =]
Old 02-02-2012, 07:11 PM   #105
xixixi
Banned User
My Ride: 01 330x-xi
Guess we are gonna go OT, I've been trying to get some measurements... are you talking about TMS shorty's? I think they will fit, would just require some fabrication to get them to merge? I'd love to be educated more on this topic Tiny teaser update. Also took off the bumper today so everyone can see better.
ID:	435188   Click image for larger version
ID:	435189   Click image for larger version
Old 02-02-2012, 07:33 PM   #106
murph1379
My Ride: 2006 M3
Yeah, the TMS shorties, which were designed for the E36. They should bolt up ok, and I think they'll fit, and Vorshlag is planning to work on some custom catted downpipes for them for me. They should help with torque (ok, not hard vs. stock!) which is what I need for autocross purposes, as we don't spend much time at high revs.
Some recent emails I've received indicate I may not need to go quite that exotic, but we'll see, awaiting clarification from the appropriate rules folks...
Old 02-02-2012, 07:48 PM   #107
xixixi
Banned User
My Ride: 01 330x-xi
Good info, I was thinking the same on fitment. Please keep me up to date on whats going on with that. Very interested.
Old 02-03-2012, 05:59 PM   #108
xixixi
Banned User
My Ride: 01 330x-xi
Finished maintaining the fuel system. Parts otw are oem radio block off plate. Gas pedal mount. (broke the last one ) few nitrous jets. Lots of body plugs. This is the only update today. What do you guys think? Run a 90 degree fitting off that T towards the motor? Or just a line will be ok?
Old 02-03-2012, 07:00 PM   #109
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Finished maintaining the fuel system. Parts otw are oem radio block off plate. Gas pedal mount. (broke the last one ) few nitrous jets. Lots of body plugs. This is the only update today. What do you guys think? Run a 90 degree fitting off that T towards the motor? Or just a line will be ok? Fuel rail, using the Shortest possible 3an braided fuel line to the fuel solenoid. Again, use the Shortest possible 3an line from the fuel solenoid to the nitrous/fuel single nozzle.
I see no difference in either choice, they're both being fed from the same fuel pump/system. A single nozzle spraying up to 75 hp should never need a separate dedicated fuel system. If you go to a DP system, then you could start to entertain the idea of a stand alone 1 gallon fuel cell with its own pump & regulator.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-03-2012, 07:30 PM   #110
xixixi
Banned User
My Ride: 01 330x-xi
Good luck.
Agreed no secondary system required. Guess I'll just run a line to that fitting as planned. Are you implying I should have tapped my rail? Instead of after the filter and before the rail?
Old 02-03-2012, 07:32 PM   #111
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
excited to see this up and running...
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 02-03-2012, 07:36 PM   #112
Rob43
Rob43's Avatar
Agreed not secondary system required. Guess I'll just run a line to that fitting as planned. Are you implying I should have tapped my rail? Instead of after the filter and before the rail?
I can't see a difference, we're only talking about a small amount of fuel usage.
Am I missing something ?
Old 02-03-2012, 07:37 PM   #113
xixixi
Banned User
My Ride: 01 330x-xi
No, I misunderstood you.
Old 02-03-2012, 07:38 PM   #114
xixixi
Banned User
My Ride: 01 330x-xi
me too
Old 02-03-2012, 08:49 PM   #115
xixixi
Banned User
My Ride: 01 330x-xi
I got some cheap fuel hose at auto zone rated for 3.5 bar.. Think I'm asking for trouble? Kinda bugging me, I think I should get some oem line? The oem line had two layers and seemed stronger.
Old 02-03-2012, 09:02 PM   #116
BimmerBrakes
The Brake Newbie!
Depends on what pressure you planning to see...
Old 02-03-2012, 09:05 PM   #117
xixixi
Banned User
My Ride: 01 330x-xi
I'm gonna go to oem lines just to be safe. I just realized, I have several feet of that hose from all the fuel rails.
Old 02-06-2012, 10:46 AM   #118
xixixi
Banned User
My Ride: 01 330x-xi
Little update, ordered a Single Probe EGT, CHT, dual guage. From The Sensor Connection. Spoke to a man this morning, very polite and entertained my game of 20 questions Peak hold, with alarm. Should have them in by the end of the week! Anyone wanna save me some driving/testing on which cylinder is the hottest? https://thesensorconnection.com/cart Edit: Fed ex man just showed up with these! I now have 55 to 175
Old 02-06-2012, 03:32 PM   #119
Rob43
Rob43's Avatar
EGT / CHT, great safety device, very useable with a nitrous application.
Question: did you buy the one with the single analog EGT/CHT gauge which only has a "LCD Pointer Resolution: 50F". Or, did you buy the one with two separate single Digital displays that have a "Resolution: 1F" ?
Old 02-06-2012, 04:31 PM   #120
xixixi
Banned User
My Ride: 01 330x-xi
http://thesensorconnection.com/egt-p...yrometer-gauge
